Question about Canon PIXMA iP90v Printer
How to set a MG5220 printer to do 2-sided copies?
John Y.
    Loyalty:
    Visited the website for 30 consecutive days.
    Dedicated:
    Visited the website for 20 consecutive days.
  • 3 Answers
The Canon MG5220 has a built-in auto duplexer and can print 2-sided documents. On a Mac, click print, and in the print dialog box select Duplex Printing & Margins (drop down options below Printer and Presets). Check the Duplex Priting box, and selected the Stapling side. Then click Print. That's it!!
Posted on Oct 18, 2012
Chris Hingee
  • Canon Master
  • 32,281 Answers
This model Canon printer does not have a duplex unit and therefore cannot print double sided documents automatically.
You can print double sided documents, but one page at a time. For instructions on how to print double sided documents, click on this link and follow my instructions :-
http://www.fixya.com/support/r7325259-double_sided_printing_using_single_sided
Posted on Feb 05, 2011
1 Related Answer
Libb
SOURCE: how to get a Canon
If you have a Canon MG5220 you certainly can print two-sided. I have one and I print two=sided pages. When you bring up your print menu underneath "Orientation" is a small window that likely says "layout". Click that window and you will have various options to choose from; color matching, paper handling, cover page, quality media color options. borderless printing and duplex printing & margin. Choose Duplex & Margin. Once you've clicked that you'll see a check box for duplex printing, click that box. You have other options for for reduced or normal printing (your choice) and then if you're stapling there's options for the side you'd prefer but the point is once you've checked off that box for duplex printing you're set to go.
Posted on Jul 09, 2013
My Canon printer MG5220 printer says that there is a paper output slot - paper jam
It means one of the sensors did not send a movement of paper, when needed. Could be a sheet of paper, a scrap of paper, but sometimes something just dropped into the printer, like a paper clip. So carefully look (with a torch or other bright light) if you can find anything where the paper should go. also open and close the printer as if you replace cartridges an see if you can find anything that does not belong in a printer.
If you can't find a thing and when you unplugged the printer from the mains for a few seconds. and then switched it on and the error keeps coming back, contact a service centre or buy a new printer.
Jan 13, 2015 | Canon Pixma Mg5220 Wireless All-in-one...
How do I reset the ink cartridge for my canon mg5220
Yes, you will get that message. You may be able to buy a "chip resetter" for your carts. I've had good experience with this supplier of resetters, refillable carts and refill ink:
Sep 12, 2014 | Canon Pixma Mg5220 Wireless All-in-one...
Copy files to sd card from computer
it is so easy
1- plug the printer into your computer via usb cord .. Install canon pixmaMG5220 software which allows you to acces to SD card
2-plug the sd card in your card reader than plug the card reader into the computer .. go to my computer than to the SD folder .. and start copying
Good Luck
Jul 04, 2014 | Canon Pixma MG5220 InkJet Printer
My printer prints a yellow background when copying or scanning but not when printing a document from the computer. How do I fix this?
if you only when you scan printed in yellow or create a copy, the scanner unit is damaged, you must replace it.
Apr 29, 2014 | Canon Pixma MG5220 InkJet Printer
How to print on postcard size paper?
Most domestic printers have a variable paper tray in which you can adjust the size manually, simply put the paper to the correct corner and print.
Oct 18, 2012 | Canon Pixma Mg5220 Wireless All-in-one...
How to load photo paper in paper tray canon mg5220
For front or front tray loading printers, shiny side down... for rear/back loading printers.., shiny side up. Pictures should be visible coming out of the exit slot. Using pre-cut photo paper requires some technique, if the paper holder does not have an adjustable paper width feature. Feed paper in one sheet at a time to prevent jambs.
Aug 27, 2012 | Canon Pixma MG5220 InkJet Printer
Reset to factory settings MG5220
turn off the printer.
Press and hold the resume button and click and hold the power button.
While continuing to hold the power button, release the resume button.
Still holding the power button, click the resume button 2 more times.
Release both buttons.
Click the resume button 4 more times.
Turn the power off then on.
Sep 27, 2011 | Canon Pixma MG5220 InkJet Printer
How to get a Canon MG5220 printer to print 2-sided copies
Feb 05, 2011 | Canon imageCLASS MF7480 Laser Printer
Canon PIXMA  iP90v Printer Logo
627 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
