Question about Amphion Mediaworks T-365 System
Dvd does not play without the remote pressed play constantly to no avail. what can I do to remedy this?
Posted by dlcproc1 on
David Dunn
    Brigadier General:
  • 8,546 Answers
Something is overriding the Play function. Perhaps on the remote itself or in the machine's hardware switches. Hide all the remotes. Try the front panel Play button. Works? Figure out which remote is causing it.
Still not working? Turn it OFF. Manipulate all controls to make sure they're not 'stuck'. Try again.
Be aware of this:
http://www0.epinions.com/review/Amphion_Mediaworks_T_365_System/content_440913202820
"Recieved unit as christmas present 2007, setup unit enjoyed playing remote radio function, family member shutoff unit using main power button when going to bed, the next day unit does not come on period...the unit was stacked upon vcr and satellite units thought problem was due to electronic heat, but upon further exams, have yet to determine cause...during internet searches, found others having same/or multiple problems..further check tells me company out of business...recommend buyer beware...as repair nearly impossible...unless electronically [email protected]"
Posted on Feb 05, 2011
Dvd dolby
generally auto plays without remote
if there is interactive menu then its a problem.
get another remote
Aug 05, 2014 | LG Electronics - DP132 Multi-Format DVD...
Apex DVD/Tv combo GT2015DV won't play dvd's
Something is wrong..crbr799 your DVD-TV has a TV-DVD button on the right front to switch from TV to DVD play...OPEN button on left side ,place DVD in tray, close & press PLAY...
I something simulator that needs the remote control for the SPECIAL functions....by the way the ORIGINAL r\c is $135 to $155, a replacement ($35) will turn the TV\DVD on ( which you can do without the r\c) and NOT function with anything else.
P.S. they will try to sell you universal r\c that work with the CABLE boxes, the ones that you pay a monthly fee!!
Aug 11, 2011 | Apex Digital Televison & Video
How to get unit to play without remote
You can probably use the front panel buttons (STOP PLAY OPEN/CLOSE etc) manually, the only thing you cannot do without the remote is access certain DVD menus, including subtitles/language/special features etc. You can always obtain and use a universal remote for basic menu functions later on if necessary.
To play a DVD movie without the remote, simply load your preferred disc, wait for the player to finish reading its contents, then to skip copyright warnings and/or the 'play movie' menu screen, press STOP, then PLAY, or simply press PLAY button where 'play movie' (or whatever function) is highlighted in the menu. These buttons should be on the front of the main unit. Doing this should encourage the player to detect the appropriate title (the movie) and play it (basic playback operation may not be possible with some DVD releases due to the numerous interactive menus and title pages, such as film trailers).
If basic manual operation is not completely possible with some DVD titles, consider a universal remote for your player if you have either lost your original, or the player was purchased/received without one. Such remotes are relatively inexpensive to purchase, and are available just about everywhere.
Apr 22, 2011 | Panasonic Televison & Video
Phillips Portable DVD Player DCP750/37 says "Wrong Region"
To change the region on the Philips dcp750
1. Press the Open button on your remote control to open the drive tray
2. Press the Setup button on your remote control
3. Press the Right button on your remote control
4. Press the Right button on your remote control
5. Press the Right button on your remote control
6. Press the 9 button on your remote control
7. Press the 6 button on your remote control
8. Press the 5 button on your remote control
9. Press the 3 button on your remote control
10. Using the Up and Down buttons on your remote control, change the region to 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
11. Press the Setup button on your remote control
Mar 13, 2010 | Philips Televison & Video
How can I play a Region 1 Dvd in Australia?
power on the tv and dvd without any dvd in tray
open disc tray
press pause then 0000000 on remote
region menu shows on tv screen
select ur region
press pause on remote
then power off
Jan 26, 2010 | LG RH177 DVD Recorder/HDD Recorder
Romote control not working
1. The owner's manual is available online:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-ES35VS
Download the manual under Operating Instructions.
2. To remedy "SET1" problem, Press 1 & Enter at the same time.
Hope this helps
Aug 10, 2008 | Panasonic DMR-ES35VS
Jsi js4110
The only operations available on the JSI JS4110 without a remote are play, pause, stop, and eject. Since this DVD player "remembers" position of the movie, a different DVD would have to be inserted and played to start that movie over from the beginning. As for fast-forward, this is only available with the remote.
May 13, 2008 | Philips PM3S Remote Control
Using DVD player without remote
yes when you get to the dvd menu press play
Nov 21, 2006 | Sony DVP-NS315 DVD Player
Amphion Mediaworks T-365 System Logo
64 people viewed this question
Top Amphion Mediaworks Audio Players & Recorders Experts
Marvin
Marvin
jakesaints
Level 1 Expert
Tom Chichester
Are you an Amphion Mediaworks Audio Player and Recorder Expert? Answer questions, earn points and help others
