Asko W6021 Front Load Washer Logo
Question about Asko W6021 Front Load Washer
Asko W6021 Front Load Washer error detected "F3 Outlet Blocked". How to solve this problem?
Anonymous
  • 403 Answers
The drain access is at the bottom left of the washer. Insert a screw driver in the right side of the cut-out and and gently pry open. Open the drain pump. You will need a small container and a towel to help catch the water that will be coming out. After letting all the water out, clean out any objects in the drain pump. After cleaning out drain pump, put everything back together and restart washer.
Posted on Feb 18, 2011
  • jgodsey Jun 22, 2011
    where is the pump trap filter? Do you have any illustrations as to where it is located? My machine has no little door on it, which is where everyone says it is.
How do I turn on my washer .. I cant read swedish
Hi dear.Please follow the link below to dowload the quick start guide.
http://safemanuals.com/user-guide-instructions-owner-manual/ASKO/W6021-_E
I hope that solves your problem.Thanks.
tip
Asko W6021 would not fill with water
Our W6021 front has had a couple of instances where it would not start the fill cycle as usual. Normally it would be switched on,the relay would operate and the water would begin to enter the bowl. We tried a number of things including checking the hose and inlet filter for blockage. We then checked the outlet drain pump trap and found a coin and a drill bit lodged in the entry hole to the trap. Once the foreign objects were removed ,the machine operated as normal once again. I will be very careful in future to empty my pockets of metal things.
1helpful
My Asko Front load washer model W6021 Prewash
hi you need to replace the inlet valve,take off the top panel and you will see the valve behind the soap drawer with the black hoses.you can get a book from asko.com.au
Washing machine wont drain, door is locked, and cant get clothes out of machine, says F1 and F3 error. wat do i do?
sounds like a safety check is on. check the pump to make sure nothing is stuck in there. read the manual for checking pump on that Asko machine..
The washing machine stopped on the rinse (6) with an F-3. Now what do I do?
"F3" on Asko means the machine detected an interuption in the drain sequence. could be as simple as a coin or some other debris causing the fault, but it may be the pump is faulty as well. first things first.
**UNPLUG the unit from the dryer, or from the wall, which ever applies to your set-up**
in the lower left corner on the front of your washer is a "pin catcher/lint filter" for the pump (a pump insert asko calls it). unscrew this insert, clean out whatever is obstructing the pump and you should be fine to continue. unless the pump itself is at fault. **you will need to drain whatever water is in the unit into a drain, or pan thru the little drain line from the pump (refer to your manual if you have access to it).
hope that helps,
good luck
2helpful
ERROR F3 - WHAT DO I DO?
hi the error shows bcoz of ur door problem...
replace the door lock and ur problem will be solved...
Asko Washer W6021 Problem
CHECK THE BRUSHES ON THE MOTOR, FOR BEING WORN DOWN!
REGARDS........TREVOR. FLEETWOOD UK.
Asko 7005 and washer 10505
1) there is a reset button on the back panel of you dryer it is in the middle black rubber...
2) you really can't the asko washer needs a 240v to run... You can hire an licenced electrician to wire a 240v plug for your asko washer if you do not want to plug it into the dryer
1helpful
Asko W6431 Quattro front loader
Unplug the machine. Remove the filter, take a flashlight and get your head down to check if something has fallen deeper in filter and pump housing which block the pump turbine. Also, make sure to check if the outlet hose isn't clogged or jammed with something too.
F3 error
CHeck outlet filter, and draining system. Seems to be something that is stuck in the pump.
Top Asko Washing Machines Experts
mark warfield
mark warfield
Marvin
Marvin
vince
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
