Dewalt d55151 factory reconditioned emglo heavy - duty 2.5hp 4 gallon Electric hand carry compressor Logo
Posted on Feb 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dewalt emglo d55155 air compressor-what type of oil? this machine is electric
  • Anonymous Mar 13, 2014
    what type oil should be used in the DeWalt D55155 Emglo air compressor
Anonymous
Level 2:
Scholar:
  • Expert 150 Answers
  • Posted on Feb 06, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
150
Questions
Helped
74038
Points
485
Need to use air compressor oil it is available at you local hardware store in the tools department.
How much oil does the Dewalt emglo d55155 air compressor use?
Without knowing the exact model number, it looks like 4 oz. You can buy here for less than $6.00.
Bostitch CAP2000P OF Air Compressor Parts
What type of oil to use
Use 30 wt oil and fill it up till it comes 1/2 way up in the bubble.
How do i start a dewalt d55155 compressor
Its switched automatic on when the air-pressure in the tank comes to a lower level .
Other is by hand but there can be build on a circuit breaker on your type if the powercord was manual used by hand without pressure relief by switch.
I have a D55151 Dewalt comp. that wont pump past 40lbs. What can couse this??
I don't what you mean by a "cold start" valve? Too much typing for a guess.
1helpful
I want to know where the oil goes on this machine?
ON a d55155 compressor, you will find the dipstick on the left side as you are facing the control panel. Notice a small black knob on the end-bell of the pump. Pull out the dipstick and notice the oil level line just up from the tip of the stick. Over-filling will cause oil to leak. Use 30wt non-detergent oil or compressor oil. Good luck
1helpful
Dewalt d55155 compressor runs to 60 lbs then acts like not enough power and shuts down
Looks like it's an oiled style compressor. Is it getting pretty hot by the time it hits 60psi? Might be low on oil, or the oil has been contaminated with water from condensation. If that's the case then what is happening is the compressor is causing too much resistance for the motor to turn it because of the excess friction. This is could be what is causing it to shut down prematurely.
1helpful
It is an electric motor Dewalt Emglo Compressor model#D55151. What type of oil should I use in it?
Dewalt recommends using synthetic pump oil, however if you only use the machine occasionally and not in a commercial setting, standard compressor oil will work great and save you money. Synthetic oil will last longer and can take much higher temperatures without breaking down. Lowes sell the kobalt brand of compressor oil and sells for about $3 for standard and $7 for synthetic. Home depot sells campbell hausfeld brand but equally as good. Auto parts stores also sell a line of compressor /pump oil just watch pricing for your needs. If you can't find compressor oil, non-detergent motor oil works just fine. Good holidays
4helpful
I want to change my EMGLO D55155 compressor oil. What type and how much oil should I use? Thank you!
The compressor tanks 4 ounces of oil.
You want to use a synthetic oil in this unit. We like to use Mobil 1 full synthetic 10w30 oil.
Here is a link top the owners manual:
http://shoppingcart.msservicecompany.com/msservice_net/product_files/D55155/D55155_OM.pdf
Dewalt/Emglo D55155 compressor screeching and breaker blown
Sounds like it isn't getting oil on the bearings. Take it apart yourself,after you get a diagram of it and find a parts source.
Top Dewalt Air Tools & Compressors Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
