Pentax Optio M30 Digital Camera Logo
Posted on Feb 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
IT TAKES A LONG TIME TO TAKE A PHOTO FROM WHEN YOU PRESS THE BUTTON
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Pentax Master 102,366 Answers
  • Posted on Aug 25, 2012
Pentax Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10473111
Points
622693
This is a common situation with many compact point&shoot cameras. Larger and more expensive dSLRs have additional hardware that eliminates this "shutter lag".
You can eliminate much of the lag by anticipating the peak of the action. Press the shutter release button halfway to focus and meter, and hold it there until the moment, then press the shutter release button the rest of the way.
My Fujifilm Finepix XP21 takes pictures but always blurry and not focusing? Any body
Have you tried focusing before you take a photo? To do this, press down the shutter button on your camera but don't push it far enough to take a photo. This enables the camera to focus on what it's about to photograph before you press the shutter button again and take the photo.
Olympus SP800UZ Digital Camera takes a long time to focus and take shot
Could be the settings need adjusting.....to help you should check these settings and set to!
ISO to High ISO Auto.
AF to Auto
When taking the photo press the shutter button halfway till the window shows a green light (if the window red then not focused so release button and try again) then continue to press the shutter button till the picture is taken!
let me know how you get on!
Oct 19, 2014 • Cameras
Please...which is the wrench button? vivitar x327 trying to set up date/time. for the 1st time
The "wrench" is NOT a button, it is an icon in the menu.
Press the MENU button. Press the Right/Left button to select the "WRENCH" icon The Setup menu appears in the center of the LCD. 3. Press the Up/Down buttons to select the Date option in the Setup menu. Press the MENU button. Press the Up/Down buttons to select a Date option from the Menu that appears: On selecting "On" the date will appear on the photo once it is taken. • On selecting "Off" no date will appear on the photo. • On selecting "Set Date" the Set Date settings screen will appear. You will be able to • change the date settings that will appear on the photo once it is taken. To Set the date: Press the Up/Down button to enter Set date option. 1. Press the MENU button. 2. Press the Right/Left button to select and highlight the Year, Month, Day, Hour, Minute, 3. Second and Date Format type. Press the Up/Down button to set the Date, time and
2helpful
My samsung s630 camera takes more time in processing after capturing photo
You can follow these steps below.
First, do the POWER RESET:
- Turn off camera
- Remove batteries for a minute
- Reload batteries
- Turn on camera
Second, do the MASTER RESET
- Be in AUTO mode
- Press on MENU button
- Press on the right button until you see SETUP 2
- Scroll down until you see RESET
- Press the right button to pick up on YES or NO
- Press on OK/MENU button for changes to be saved
- Turn off camera for a few seconds so that settings will be refreshed
*******2nd solution
It may require a firmware upgrade. That will involve going to the Samsung website, following links to support/downloads and checking to see if there's an update for your camera.
My Nikon Coolpix L3 takes a good few seconds to take a photo. By the time the camera takes a photo the moment is gone. I'm sure it wasnt always like this. Can you help?
This is a common situation with most compact point&shoot cameras. This "shutter lag" is because the camera has to do so much work when you press the shutter release button: focus on the subject, meter the light for proper exposure, and switch the electronics from viewing on the LCD to recording to memory. Larger (and more expensive) cameras have additional hardware to reduce this lag.
You can reduce the lag somewhat by anticipating the action. Press the shutter release button halfway to focus and meter. Keep it pressed halfway until the right moment, then press it the rest of the way to take the picture.
2helpful
Hi , i have tried what you mention for hb88rc let say i am doing the programing and it is currently 10 am. (example) i want it to be on at 7am and off at 7pm for the entire week i do as the instruction...
You happened to catch the same guy that answered before.
Lets go through the exact programming steps:
Your schedule is ON at 7am and Off at 7pm ALL week.
1) Set the clock to current time:
Hold down clock button while doing next steps
Press Hour button until correct Hour am-pm shows (10:00am for example)
Press MIN button until correct minute shows.
>>> Now wait, the manual seems to leave off a step here... it doesn't say to enter current day.
OK, lets make sure current day is set.
I guess you press Day button until current day shows.
Now release the clock button.
2) Program the timer to your schedule:
Press and release PROG button.
press it once and Program1 ON is ready to be programmed
The screen looks like the picture below:
3) Ready to set Program1 ON:
The display shows the number 1 and it shows the word ON.
Press DAY button as many times as it takes until all days show at top of display.
Press Hour button until 7 am shows in display
Double check that the time is AM
Press MIN button until :00 shows in display
4) ON time for Program1 is set
We are ready to set OFF time for Program1.
5) Press the PROG button until the display shows Program1 OFF just like photo below
Notice that the number 1 and the word OFF appear on display
6) Ready to set Program1 OFF
Press Hour button until 7 pm shows in display
Double check that the time is PM
OFF time for Program1 is set
7) Programming is complete, and we are ready to use the timer
(If you want more programs, press PROG button until program2 ON shows in display)
8) To exit programming, press the CLOCK button.
Current time show in the display.
The timer should be operating correctly now.
Add a comment, if you want to contact me directly.
1helpful
I have turned camera on and set up to take a photo and the shutter release button will not press in to take the photo. I used the camera yesterday and it worked fine!
Turn the camera on and look into the view finder while you try to press the shutter button. Check the information in the view finder to see whether you are getting an error message. If you see an error message in the view finder, remove the lens cap and proceed to take a photograph but, instead of pressing the shutter button this time, press the button near the top of the camera on the back which says "AF/AE. If the camera takes the photo it means you have somehow initiated the auto focus/auto exposure lock which the camera will not override when attempting to take a photo using the shutter button. When you use the AF/AE button, you override this system. To remedy this issue, when you get the error message try pressing the shutter button again. Also, remove the lens to see if the shutter inside has frozen in the "locked" position. If you find this to be the case you will need to contact Nikon Customer Support. The link for Nikon Support is below. The numbers are half-way down the page.
http://support.nikonusa.com/app/answers/detail/a_id/238
My fuji fine pix z1's flash doesnt work. i dont even remember it worked ever. the pics are blurred most of the time
1) Check you're settings are all on "Auto".
2) The button you press to take the photo is a 2 stage button. Press half way, if you're gentle you should feel a slight resistance. Pause at this stage, just for a moment to allow your camera to focus properly. Then proceed with the action until photo is taken.
3) It takes a little practice to get used to it, but with any luck you photo's should be crisp.
4) If this doesn't work and you bought it less than a year ago, take it back to the shop and comlain.
1helpful
When I "click", it takes forever to actually take the picture
You must press the shutter button half-way to allow the camera to lock in the focus and then you can press it the rest of the way for an almost instant picture.
The camera takes too long to take a photo. What should I do?
Press the shutter button halfway and hold it to set the focus, then press it the rest of the way down to take a photo. If you press the shutter button down all the way at once, it takes time to focus and set the exposure before the shutter releases. It may take longer than when pressing the shutter button in two steps.
Top Pentax Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Pentax Camera Expert? Answer questions, earn points and help others
