Question about Delta 473-WHSD-DST Saxony Diamond Seal Technology Single Handle Kitchen Pul...
Looking for simple installation instructions for a rp50587 valve assembly into a 16997-sd-dst faucet.
Posted by farmerjack on
Paul Beyer
  • 528 Answers
My Delta 16997-sssd drips how can I fix it
there are either springs and seals that need replaced or a cartridge
Jan 24, 2018 | Plumbing
I have a Delta kitchen faucet Palo 467 series. I am having a difficult time switching between spray and stream on the wand assembly. Occasionally it will "lock" into one position or the other and...
Are you using a softener in your home? Sometimes hard water deposits can clog up the cartridges and create the problems you such described. Im not sure about the lock/button issue though since I have never used this particular Delta faucet myself, but with one problem, it can usually cause many others.
Try replacing the cartridge on the Delta faucet first, Here is a link to the replacement one from the Delta site. http://www.deltafaucet.com/repairparts/details/RP50587.html
Here is a link to Delta warranty and lifetime guarantee. http://www.deltafaucet.com/customersupport/warranty.html
Here is a link to the Delta page with lots of useful information on your product. http://www.deltafaucet.com/kitchen/details/467-DST.html
Ex-Plumber
Hope this helps-
J.Sper
Mar 06, 2011 | Delta Faucet Delta 467-SSSD-DST Palo...
Delta Faucet Company 467-SSSD-DST Palo Diamond Seal Technology Pull-out Kitchen Faucet, Stainless, 3 years old and is beginning to drip unless we position the handle just right. Is there a washer? I've...
I hope this will help please go to this web site for a downloadable parts link. If it is leaking from the spout replace the seats and springs to correct the problem. Turn water off and remove handle with a 1/8" allen wrench and remove retaining collar to access the ball assembly to remove the seats and springs.
The parts page on this link will give you a break down and hope this will help.
http://www.deltafaucet.com/kitchen/details/467-SSSD-DST.html
Dec 30, 2010 | Delta Faucet Delta 467-SSSD-DST Palo...
Delta faucet 470-ss-dst is leaking from the spout. steady stream not just drips.
easy fix, shut-off water at under-counter angle valves and water meter, pop-out the blue and red insert located on the front of the handle of the faucet, turn faucet on to relieve pressure, loosen allen screw under red and blue insert, pull handle up, remove nut under handle, remove plastic insert gasket and stem under the nut, notice two rubber gaskets.... remove them and the springs behind them and replace, when putting the insides of the faucet back in pay close attention to the notches and grooves,,,, the parts only go back one way....
Dec 28, 2009 | Delta Faucet 470-DST Signature Diamond...
Need to take the hose assembly out of delta 470 faucet
you need to disconnect from under the faucet and then pull it all the way out just like if you were pulling it out to use the spray. There may be a big weight on the hose to help it back into the spout when placing the head back....you will also have to take that off to pull it through.
Oct 04, 2009 | Delta Faucet 470-DST Signature Diamond...
Delta Kitchen Single Faucet 470 suddenly would not give water
Debris in the valve is a fairly common cause for stopping water flow in single lever valves. You can first check the aereator and remove any debris that may be there at the faucet itself. Then you can try to remove the ball at the control lever. You have to be careful and make sure that you do not drop any parts. Especially if this is a recent installation, you may find a large piece of something there.
Jun 15, 2009 | Delta Faucet Delta 470-BL-DST Signature...
Replace the seal on the 470 DST single handle pull out faucet
Turn the water off at the faucet, remove the handle and the retaining nut that is apart of the trim. You will see where you can use a wrench to remove it. The ball assembly will come right out and you can replace the washers right below it. Put it back together and if needed, tighten the tension ring that is on the retaining nut (usually grey or white in color) so it won't leak water around the ball stem. Good luck.
Apr 02, 2009 | Delta Faucet Delta 470-BL-DST Signature...
Delta 473-WHSD-DST Saxony Diamond Seal Technology Single Handle Kitchen Pul... Logo
1,515 people viewed this question
Top Delta Plumbing Experts
Bill Johnson
Bruce Robin
Mike
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
