Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
I have a uniden dect 6.0 cordless phone and I was wondering how to change the answering machine, can you help me?
Posted by ashlynnebeal on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
Since you neglected to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Posted on Dec 18, 2012
  • kakima Dec 18, 2012
5 Related Answers
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: remote retrieval of messages, uniden dect 6.0 cordless
30 seconds with a search engine got this page http://www.uniden.com/index/manuals_results.cfm?cat=59
Put in your model number and you're good to go.
Carl
Posted on Aug 27, 2008
Anonymous
  • 3 Answers
SOURCE: "i have a uniden 6 0 dect2080 3 answering machine how to check the messages from a different phone"
The default security code is "80". If you have not reset that code, you will use 80.
This is all from the manual:
1) Call your telephone number and wait for the system to answer. If the answering system is off, it will answer after about ten rings and sounds a series of beeps.
2) During the greeting or the beeps (if answering system is off), press 0 (zero) and enter your security code within 2 seconds.
3) The answering system announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero" followed by a beep.
Then the manual lists all the remote commands. If you need those, you can go to uniden.com and download a manual.
Posted on Apr 26, 2009
Anonymous
SOURCE: Will Uniden 2085 DECT phone work in india
Caller ID standards are different in India,so caller id won't display ; need to buy a converter which converts from DTMF to BellFSK standard
Posted on Aug 24, 2009
consultel1
george peters
  • 860 Answers
SOURCE: my cordless phone says
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
On the handset, press and hold # until the handset beeps and displays Handset Registering.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
Posted on Dec 21, 2009
KingDWS
Dave King
  • 1606 Answers
SOURCE: How do you change the number of rings before
Here is how to kill two birds with one stone.
http://www.uniden.com/products/productlisting.cfm?cat=Cordless%20Phones%20DECT%206.0http://www.uniden.com/products/productlisting.cfm?cat=Cordless%20Phones%20DECT%206.0
That is the page for Uniden DECT phones. www.uniden.com.
There are 6 pages to flip through and all you need to do is look at the picture for you phone. Click on it and it takes you to the phones page. On the upper right sid there is a link to download the owners manual in pdf form. Unfortunetly I can't tell your model from the information so I can't tell you the page or how to do it. Hopefully the manual will get you sorted out.
Posted on Mar 23, 2010
HOW DO YOU RESET ANSWERING MACHINE ON 6.0 UNIDEN PHONE
Answering Machine - Uniden Support
unidensupport.com/AnsweringMachine
Get support for your Uniden Answering Machine. ... For models that have an */envelope key on the handset: ... How To Change The Record Time & Ring Time.
Customer Support
mycusthelp.net/UNIDEN/_cs/AnswerDetail.aspx?sSessionID=&aid=270585 How Do I Set The Greeting On My DECT 6.0 Cordless Phone Answering System? Question: Answer: To record your greeting on the DECT Single-Line Models, please do the following: 1. ... features your model may have can also be found in your owner's manual. ... http://www.uniden.com/index/manuals_results.cfm?cat=1
I have a Uniden phone/answering machine, DECT 6.0, number ...
www.justanswer.com > Electronics Question > Phone Problems I have a Uniden phone/answering machine, DECT 6.0, number BK20033715. I purchased it about a year ago. I need to change the message on the answering ...
[PDF]owner's manual - Uniden Australia
https://www.uniden.com.au/RESOURCES_MAIN/pdfs/DSS7955_1_OM.pdf Terminology used in this Manual . ... Answering Machine Features . ..... change global settings at a time, and you have to make sure the phone is not currently ...
Owner's Manuals - Uniden
https://www.uniden.com/product-information/owners-manuals Owner's Manual. Search for an Owner's Manual. The product name/model number is on the product's ID label on the back, bottom or in the battery compartment ..
RESET ANSWERING MACHINE ON 6 0 UNIDEN PHONE Google Search
Apr 20, 2017 | Uniden Lands Phones
How do i change the date on my answering machine of a Uniden Dect 6.0
Select the model of your Uniden DECT 6.0 system from the list beginning at scat/dectphones_mnl">http://www.uniden.com/scat/dectphones_mnl to download a copy of the manual.
Sep 20, 2014 | Uniden DECT 6.0 Cordless Phone ID
How can I change the number of rings to six before it goes into answering machine on my cordless Uniden 6.0 phone?
Nov 25, 2012 | Uniden DECT 6.0 Cordless Telephone...
I have lost my manual and i dont know how to record a personal message on my answering machine and how to enter the code to retrieve my messages from another phone.
From your handset, you just have to press the mute button, your phone should start telling you the time, date, ect. press the #5 key and then the #8 key and start recording your message. When finished press the # 8 key again. Hope this helps
Mar 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
Answering machine picks up after 3 rings .
Jun 20, 2010 | Uniden DECT 6.0 Cordless Phone ID
How do you change the number of rings before answering machine picks up? Use to be six but has changed to two. Uniden DECT 6.0. Numbers on bottom of answering machine are BH00155264 and 1C513C-UC518. Have...
Mar 23, 2010 | Uniden DECT 6.0 Cordless Phone ID
Uniden dect 6.o
What model Uniden DECT 6.0 phone/answering machine?
Mar 11, 2010 | Uniden DECT 6.0 Cordless Telephone...
How can you change recording
Since you declined to specify the model of your Uniden DECT 6.0 system I can only suggest that you select it from the list beginning here to download a copy of the manual.
Dec 18, 2009 | Uniden DECT 6.0 Cordless Phone ID
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
14 people viewed this question
Top Uniden Lands Phones Experts
k24674
Marvin
Marvin
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
