RTO W4 A.O Smith Gas Hot Water Heater Draft Inducer Logo
Question about RTO W4 A.O Smith Gas Hot Water Heater Draft Inducer
Pilot hard to lite when lites stays on about 15 minutes goes out this is on reliance gas hot water heater 101
Posted by wimpy50 on
Anonymous
  • 528 Answers
The thermocouple has gone bad or in this case is going bad to the point that it is useless.
The thermocouple is the pilot's, well, co-pilot! It is the electronic device that senses if the pilot flame is hot enough to ignite natural gas or propane fuel to the burner. If the thermocouple thinks it's safe, then it keeps open the main gas valve located in the pilot assembly. If the thermocouple does not sense enough heat from the pilot flame (such as when the pilot is out), then the thermocouple shuts off the gas valve to the burners.
How the Thermocouple Works
So what is this thing and how does it work? Well the thermocouple (technically called a thermocouple junction) is a device that contains two metal wires welded at the ends and placed inside a protective metal case. The thermocouple sensor is found at the business end of the pilot flame and is designed to be placed in the hottest part of the flame. The other end is connected to the pilot valve body. As the thermocouple heats up, it produces a small amount of electricity and when it gets hot enough from the pilot, send a signal to open the gas valve by using a solenoid operated by a 24 volt transformer. The thermocouple calls the shots, and by converting heat to an electrical signal, it allows the gas valve to open or close. Once the gas valve is open, gas is then constantly supplied to the pilot and as required for the gas burners (as called for by the thermostat). If the pilot goes out, then the thermocouple gets cold and produces no electric signal to open the gas valve's solenoid and the gas valve shuts off the gas supply to the pilot and burners. Neat huh?
Posted on Feb 04, 2011
My reliance 502 gas water heater . The pilot is lite but no hot water coming out of tap?
After lighting the pilot, you must turn the gas valve knob from 'pilot' to 'on' at whatever temp setting you prefer.
2answers
What pilot light assy. do I need to buy for model# 640y0rt4, water heater ??? please wont stay lit
check that the flame sensor is clean. It would be a stiff piece of wire that would sit right over where the pilot lite is. If it is dirty...it wont sense if there is a flame....and if it dosnt sense a flame....it wont let the pilot lite to turn on.
Why does my pilot light on my hot water take not stay lite
It depends on many factors, including brand, type of heater, age, gas pressure, maintenance, venting, proper installation of thermocouple, bad thermocouple, air intake cleaning, if the flame is clear blue etc.
Copy following link to read more:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#pilot
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
Reliance 606 Hot water Heating element (Pilot light) won't stay lit
Gas water heaters don't have elements, so I am confused about what type water heater you have..
Look on the side of tank for the label.
Find the brand, and type. Does it show BTUs? Or does it show wattage?
Then re-post question with this information, for best possible answer.
Also post question on Tank forum.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Reliance 606 natural gas water heater - model #640YORT - water does not stay hot. pilot has to be clicked to heat and then u can use hot water til tank empty and it will not continue to heat water.
If I understand correctly, the pilot light is not staying lit.
You light the pilot and water in the tank reaches temperature.
Once hot water is gone, then pilot light has to be lit again.
Gas pressure is good, and gas is flowing.
Thermostat is working at high end because it cuts off heating.
Vent is working because tank heats up.
Air intake is working.
Gas control thermostat might not be reading low temperature. Replace gas control valve.
Pilot tube might be dirty. Clean burner parts and combustion chamber, and air intake, and vent.
Backdraft might be blowing out pilot. Check for constant updraft by running water heater 5 minutes, and then light match under vent hood and see if smoke goes up.
Very hot air can put out pilot, especially when water heater located in attic. Add ventilation.
Improper vent might have water dripping back down into combustion chamber and putting out pilot light and rusting out the parts. Inspect for rusted parts and water.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
I light the piuolot button and when i let go of the pilot button the pilot goes out does not light burner wont stay lit
When you light the pilot lite you have to hold the button down until it gets the element hot enough to stay lit. If you hold down the button and lite the pilot and let it go right away it will go out. What to do is hold down the button and lite the pilot and continue to hold the buttn down for about 45 seconds to a minute then let it up very slowly and you will see if it is going to go out by the flame getting smaller as you let up on the button. If it does start to get smaller conitnue to hold it again for a few seconds and repeat the process of letting it up slowly. when the control element gets to the right temperature it will stay lit then turn your valve to "ON" and the fire will start up and continue to heat the water.
1helpful
Reliance gas water heater, pilot will not stay lited
sounds like you have a worn thermocouple or maybe a blocked jet
Top RTO Water Heaters Experts
Mike
David Shaub
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
