SOURCE: Maytag Neptune Gas Dryer "do" code
sonds as if you have abad door switch assy, uint not reconozing the door closed
SOURCE: Neptune dryer model 4000, <10 y.o., hums, but won't start.
I wouldn't know about the warranty, but the dryer motor may need only a start relay, which is usually attached to the motor. Usually, this is a centrifugal device. By that I mean the contacts on the relay are normally closed to give the motor extra starting capacity when you first turn it on. The contacts open after the motor get up to full speed.
SOURCE: Maytag Neptune Dryer smells like burning rubber or plastic...
could be the board, could be a motor, could be a belt but i would run it intill something just stops or try your best to take it apart and look through things and see if you can see an indication.
SOURCE: Maytag Dryer won't start withouth me turning the drum.
Good day. Ugly problem.
My first choice would have been the motor, but.......
Here is the process, it might help you.
The power to the motor goes first to and thru the door switch. It then returns to the timer.
When the timer is turned to any running position, power leaves the timer where it is split into 2 leads.
One of the power leads goes directly to the centrifugal switch Which is the switch on the motor with all the wires. If you spin the drum, you also spin the motor, and if spun fast enough will close the contacts on the cetrifugal switch, thus sending power to the motor, allowing it to run. I guess you have done that.
The second lead out of the timer goes to the push to start switch, it then leaves and goes to the centrifugal switch but on the power side, so it is directly connected to the main winding in the motor.
That is why when you press the press to start switch, the motor runs, and if held in it will continue to run.
In fact, at this point, the motor had 2 sources of power, either of which can run the motor.
Thus releasing the push to start switch doesn't matter, since it runs off the other source.
Possibilities.
The centrifugal switch is not wired right. Please recheck. (or the motor was bad out of the box. Happens).
The push to start switch is bad, and needs replaced.
Or, the wiring going to or leaving the push to start switch has broken or making a bad connection.
Lastley, I said the power comes out of the timer and splits into 2 circuits. Not always true, in some models the timer sends 2 seperate wires out carrying the power, with the possibility the timer could be bad.
Hope this helps.
and thank for using FixYa
Testimonial: "Jack was a great help. Really took the time to help me with my problem in depth. Thanks again."
SOURCE: Maytag dryer makes an electrical buzzing noise when start button
It sounds to me like the motor is not turning, but the heating element is coming on. with no air flowing over the element, it is getting too hot. Can you operate the start switch with the top tilted up so you can see if the motor is turning but the drum is not, and just where the buzzing is coming from. Also, I would try the dryer on manual setting and on air dry to see if any setting works. Good luck
