Question about RCA P52926 52" Rear Projection Television
Peoples heads are cut off on reg tv not in hd
    Scholar:
    New Friend:
  • 70 Answers
Since your tv is cutting the heads off durring regular or analog signal but not high deffinition sounds to me like you have to set the aspect ratio different or such as going to your picture format from the main screen. Play with the settings from zoom, full screen, no overscan, cinerama and see if this helps.
Posted on Feb 04, 2011
6ya staff
SOURCE:
Screen resolution - Picture too big for screen
the resolution from the source is set too high, also check the settings in your television it may be set too high.
Oct 25, 2008 | Televison & Video
How to set up for cable
do you have a HD cable box or reg?..HD box you need the cable w/ 3 wires red/blu/green........reg just need the coaxial cable...lets start with the HD plug cables from (out) the box to in (tv) most likely this will be the component (source, it can also be your digital) on the tv when you are viewing....the reg set up is coaxial cable out (box) to cable in (tv) set the source to cable on tv...also not the tv must be on Ch 3........
feel free to rate the help
Aug 05, 2010 | Digital Lifestyle FA1B32Z 32 in. LCD...
Cuts peoples heads off, doesnt autoformat
uncheck format , format manually. use "full" or "panorama" setting
Jan 02, 2010 | RCA HD52W59 HDTV Projection Television
The heads of people are cut off no matter how i set the veritical
When you say "set the vertical", Do you mean your using the tv remote to change the aspect ratio or format?
May 21, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
My Vizio TV screen cuts of heads.
have you tried pushing the "zoom" button?
Mar 20, 2009 | Vizio L32 32 in. LCD HDTV
Picture too tall
first to change format push the arrow button to the left or right. if you go into piicture in the menu then go to avance picture settings then turnoff or uncheck autoformat.
Jul 04, 2008 | RCA HD56W66 56" HDTV
Can't view entire screen
make sure that you tv is set to the "standard" format and then try changing the aspect ratio on the cable box.
Jan 26, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Top inch and a half of tv picture cut off.
Hi JDRJR35,
Here is the internet address on the usewrs manual for your LCD TV.
http://tv.rca.com/RCATV/RL/1652880A.pdf
Now I will read through it and write down the procedure t be sure you get what your need.  See my next post in a few minutes.
Oct 16, 2007 | RCA L32W11 32 in. HD-Ready LCD Television
RCA P52926 52" Rear Projection Television Logo
144 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
