AOpen MX4GE Motherboard Logo
Posted on Feb 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am wondering if I can put a Intel Pentium 4 Processor 3.20 GHz, 512K Cache, 800 MHz FSB into a AOPEN MX4GE motherboard, the socket type is the same but I am not familiar with the FSB settings to determine if it would work. The AOPEN site only shows up to Pentium 4 2.8 ghz
Anonymous
Level 2:
Novelist:
  • Expert 136 Answers
  • Posted on Feb 04, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
136
Questions
0
Helped
21856
Points
428
I would guess not, but If you already have them both, then try it. If not then I'd get a cpu or motherboard to match the other. I once got a 2.8ghz p4 and wanted to swap it for a 3.2ghz I had lying around, quickest way was to try it out, it didn't work so I swapped them back and put the 3ghz in another pc later on, both still worked perfectly.
Hello sir i have hp narmada tg33mk mother board,it will support i3,i5,i7 processor
you posted a statement of fact not a question.
it will support
not
will it support(a real question)
well NO
and NO PC stated, only mobo.(lost the PC ?)
nor that this PC was mobo bought in India?
YOUR mobo is core2, not core(tm) processor
they are not even the same class nor socket
no
here is the list of core i3 (all are LGA
your mobo is core2. (older )
all are over 1000 pins, LGA1156 (gen 0)
you can not stuff 10 pounds(or kg) of mud in 1 pound sack.
no can do.
Intel Celeron Cpu 430 1.80ghz audio driver download
https://downloadcenter.intel.com/product/29735/Intel-Celeron-Processor-430-512K-Cache-1-80-GHz-800-MHz-FSB-
1helpful
Sony Vaio PCV-RX660 processor Upgrade
It should fit. Check the motherboard manual to see which CPUs will work in it.
1helpful
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Downgrade intel 41 cn to support processor intel p 4 541 3.2ghz/1m/800/04a l723b 071
You need the motherboard user guide for clock settings etc but first ensure that the socket set (number and distribution of pins) on the new CPU matches that on your board. You should find a user guide on the manufacturers website, follow links for support and downloads.
Here's the page for your CPU on the intel website:-
http://ark.intel.com/products/27468/Intel-Pentium-4-Processor-541-supporting-HT-Technology-%281M-Cache-3_20-GHz-800-MHz-FSB%29
According to this, *********** board needs to have a PLGA775 CPU socket.
Assuming so, its a case of setting the clock jumpers to match the processor speed.
I have ATXmodel intelceleron1.2Ghz cpu1.2 cache 256KB Intel 810E chipset motherboard can i upgrade my processor to pentium 4 and ram to 512mb
No, u can't. ur motherboard is designed for pentium III processors with FSB -133 MHz, Socket-370 type. Pentium 4 processors have 400 MHz FSB, 423 Socket at least. But yes for memory, u can upgrade it to 512 MB.
I bought a pentium 4 3.0 ghz 800 mhz & my
The motherboard chipset of the Dell Dimension 2300 Desktop PC, will not support a processor with an 800MHz Front Side Bus frequency rate.
Only Intel Pentium 4's that use a Socket 478, 1.75 Volts, and a maximum of a 400MHz FSB.
The Intel Pentium 4 HT 3.0GHz processor has an 800MHz FSB, (As you have already stated), and uses 1.475 to 1.55 Volts.
The motherboard chipset for that Dell Dimension 2300, is an Intel 845GL.
This list on Wikipedia, shows you parameters the Intel 845GL chipset supports,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_Chipsets
Not a good outcome, sorry. Just stating the facts.
Clean bios password
You need to remove the CMOS battery located on the motherboard a nd re insert again..it will reset ur BIOS password...
Upgrade processor problem
http://support.intel.com/support/motherboards/desktop/D875PBZ/sb/CS-021825.htm
This website is the details of your motherboard from intel site you can have look in to that the processor 3.2 ghz is supported but L2 cache must be 512 kb only(you are trying with 1mb one it is not supported) your processor doesnt suits the motherboard specification as i have told it previously ..
here are list & details of supported processors below:
intel® Pentium® 4
3.40 GHz 800 MHz 512 KB P20 or greater All board revisions support these processors. 3.20 GHz 800 MHz 512 KB P06 or greater 3 GHz 800 MHz 512 KB P05 or greater 3.06 GHz 533 MHz 512 KB P02 or greater 2.80C GHz 800 MHz 512 KB P05 or greater 2.80 GHz 533 MHz 512 KB P02 or greater 2.66 GHz 533 MHz 512 KB P02 or greater 2.60C GHz 800 MHz 512 KB P05 or greater 2.53 GHz 533 MHz 512 KB P02 or greater 2.40C GHz 800 MHz 512 KB P05 or greater 2.40B GHz 533 MHz 512 KB P02 or greater 2.26 GHz 533 MHz 512 KB P02 or greater
so just try changing this processor to 512 kb L2 cache processor ..........
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
Top AOpen Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Alfredo Mtz
Alfredo Mtz
SmartAviator
SmartAviator
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
