I have a Magic Chef MCWC50DBT wine cooler that doesn't cool. When it was first given to me the fan ran but the compressor didn't. I replaced the PTC starter relay and overload and the compressor now runs, gets warm to the touch, but there is no cooling taking place. The inside temperature stays approximately the same as the outside ambient temperature. When I open the door it is obvious to me that there has been no cool air entering the box.
I don't know if it makes any difference, but the model # is MCWC50 DBT. The cicuit diagram on the back panel of the cooler shows a transformer in the micro computer controller and connections to a defrost sensor and a temperature sensor. The fan runs continuously as soon as I apply power.I don't know if it makes any difference, but the model # is MCWC50 DBT. The cicuit diagram on the back panel of the cooler shows a transformer in the micro computer controller and connections to a defrost sensor and a temperature sensor. The fan runs continuously as soon as I apply power.
Sorry, I goofed when posting my reply to you. I don't know if it matters, but the model # is MCWC50 DBT. The circuit diagram on the back panel shows within the micro computer controller circuit a transformer and connections to the interior light, a temperature sensor, and a defrost sensor.Sorry, I goofed when posting my reply to you. I don't know if it matters, but the model # is MCWC50 DBT. The circuit diagram on the back panel shows within the micro computer controller circuit a transformer and connections to the interior light, a temperature sensor, and a defrost sensor.
You can't post conmments that contain an email address.
Re: I have a Magic Chef MCWC50DBT wine cooler that...
There a couple of power supplies that run the fan, and you probably have a bad power supply, that needs replace or repair, try changing out the lectronlytics caps on the power supply modules .
Check nand see if the voltage are going toio the fans, if the fans do run it will not cool.Check nand see if the voltage are going toio the fans, if the fans do run it will not cool.
Mr. Lindquist: We are experiencing essentially the same problem. Have tried replacing the temperature control board without change. Would be interested to know if you get a solution.
if its clicking every few min. its the ptc relay.left of compressor is a shield with 1 screw.behind it on top is the relay with 1 wire going to it.wiggle it out to the left .go to repairclinic.com..part#1206838...
if its clicking every few minutes its the ptc relay.located to the left of the compressor behind shield with 1 screw.go to repairclinic.com...part# 1206838
its your ptc relay.its a very simple fix.to the left of the compressor is a plastic cover with 1 screw.take it off.youll see a small box on top with 1 wire going to it.wiggle it off.pulls straight out left of compressor.go to repairclinic.com..type in part #1206838.its about a $27.00 fix. mines been running fine since.hope this helps
its the ptc relay go to repairclinic.com...type in model #...its a cheap and easy fix.if you see what the part looks like on line youll find it on cooler.should be left of compressor behind black plastic cover with 1 screw
the magic chef is probably the ptc relay.to the left of compressor is a shield with 1 screw behind it .on top is the relay with 1 wire.wiggle it off .go to repairclinic.com...part#1206838
You need to replace the Ptc unit attached to the compressor. Go to REPAIR CLINIC.COM and order the following part. 1206838
Ptc relay. They also will show you were it is located and how to replace it. Compressor tanks very rarely go bad. It is an $11.00 dollar part
All the wine chiller set 2 temp red and white, red wine temp only for 18- 20 oC , your using white wine don't set red wine temp , set only for white temp mode,white and red wine set temp are different temp
