Question about Stihl Ts400 Cut Off Saw Carb Carburetor Air Filter
I fitted a new carb kit to my stihl ts400 also new piston,rings,barrel,plug and all filters and still will not run has good spark but also has strong kick back for some reason
Posted by david88pears on
Spud Howell
  • 66 Answers
Are you using new fresh fuel ?
Posted on Feb 08, 2011
Why Do I Not Have Any Spark From The Ignition Module When Spark Plug is in The Cylinder
Search Results
    Stihl TS400 / TS420 Ignition Module Repair - YouTube
    ? 7:06
    https://www.youtube.com/watch?v=AvPv88SELXs
    May 1, 2011 - Uploaded by donyboy73
    Learn HOW TO REPLACE The Ignition Module in your StihlTS400 / TS420 ... I have a homelite 33cc Ranger it has no sparkat the plug but if I put a ... a good spark and there is fuel getting into the cylinder head also what are ...
    All comments on Stihl TS400 / TS420 Ignition Module Repair
    https://www.youtube.com/all_comments?v=AvPv88SELXs&lc...
    Donyboy73, I hava a Stihl TS 420 and just replaced the pull rope (not sure what's ... a good spark and there is fuel getting into the cylinder head also what are your ..... Hi mate, i have no spark to my plug?? i have tried a brand new plug and still ...
    Small Engine Ignition: Ignition Wires, Chainsaw Spark Plugs ...
    www.hlsproparts.com/small-engine-ignition-parts-s/149.htm
    66 results - HL Supply has the small engine ignition parts that will get your ... parts right here: ignition wires, chainsaw spark plugs, ignition coil sets, ... Please don't hesitate to contact us if you have any questions. ... Stihl TS400 (3-bolt old style), TS460 ignition coil with wire and cap ... Fits: Stihl TS410 and TS420 cut off saws
Feb 08, 2016 | Stihl TS420
Fuel is running through carb flooding out when pulling to start
The float valve is stuck open. It's time to rebuild the carburetor.
Jul 12, 2014 | Stihl Ts400 Cut Off Saw Carb Carburetor...
No fuel to spark plug stihl ts400
could be fuel pipe bent/hole in fuel pipe or yes could be carb
May 20, 2014 | Stihl Concrete Cutoff Chop Saw Clutch...
Stihl TS400 stone cutter not working (no compression) so replaced piston rings, new gasket kit and clean for carb new spark plug (good spark when engin turned over) cleaned all air filters, replaced all...
You did not indicate whether or not you have compression now that you have changed out the gaskets and piston rings. If not, it seems to me that the problem could be a) cracked head or block, b) bad valve(s) or even c) a warped head.
Sorry for the bad news (if I am right).
Apr 23, 2014 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Stihl ts400 quick cut won't draw fuel. New carb installed same problem exists. I am now getting beyond frustrated. It will start and run for a moment on carb cleaner but when its out of carb cleaner i
Check the boot between the carb and the cylinder, it could be an air leak. also check the compression. If the piston rings are damaged then it wont have the compression to pull the fuel through. Could also be a damaged fuel line, or plugged filter.
Dec 10, 2013 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Starting ts410
This might be an ignition problem... Try setting in new fuel if that doesn't work take it to the shop.
Nov 21, 2013 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Stihl ts400 starting problem
sounds like your getting air leak around a gasket
Jan 30, 2018 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Rebuilt a Stihl TS400 concrete saw, and now it wont cut, the engine dies down and has no power but revs up? Ive tried everything!
All these people are missing a basic thing: check the compression. If you did all thus work yourself, you may have reused the head gasket or not installed the new one correctly. It will run with no load, but once force in exerted, the pressure finds the leak and exploits it. There is a reason 2-cycle engines run at 130-160 psi normally.
Dec 27, 2012 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Stihl ts 400 wont start
If there is good fuel in the tank and the plug gets wet with fuel, and there is a good spark stating the obvious it should go, if not there could be a mechanical issue, piston scored, rings worn etc,
Apr 16, 2012 | Saws
Stihl Ts400 Cut Off Saw Carb Carburetor Air Filter Logo
1,172 people viewed this question
Top Stihl Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Stihl Saw Expert? Answer questions, earn points and help others
