Question about Emerson Car Audio & Video
I have a dvd player for my car. Emerson PDE-2722. I need a power cord but I can't find the model # to order it. The serial# K0600014550006195.
Posted by aroberts351 on
5 Related Answers
AvioriX
ExpressFiX
  • 689 Answers
SOURCE: Need a car power cord
Depend on your location you can get it from Best Buy, Radio Shack, CompUSA and Local IT stores around several dollars.
Posted on Nov 11, 2008
Anonymous
SOURCE: emerson PDE 2717
I also needed a new screen to screen power cord. Call 1-866-553-7521 and give them the model # PDE 2717. Ask specifically for the screen to screen power cord because the first cord the see when they do a look-up is the car to screen cord. The cost was $6.00 but adding in shipping brought the total to $15.99. Expect the delivery in 7 to 10 business days. Thanks and enjoy!
Posted on Jan 13, 2009
Anonymous
  • 265 Answers
SOURCE: POWER CORD
hi there,
Search ebay for it.
you will proberly find other models use the same cord :)
Posted on Feb 16, 2009
Anonymous
SOURCE: need to order a new car cord that goes with the
hi,we can provide you portable dvd player,they are good quality and price,please contact me:MSN:[email protected]
Good day !!!!
Jorsph
Posted on Jul 09, 2009
Joed911
JDTec
  • 4338 Answers
SOURCE: lost power cord to emerson
You can probably find it locally in an office suply store. Power cord is very common item. If not try these sites:
http://www.trianglecables.com/expowcab.html
http://quail.com/index.cfm?gclid=COWV5YvG2qUCFSpj7AodMRUmkw
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Dec 07, 2010
Emerson M2000 turntable speaker
yes you can , ask to the company or stores where did you buy your DVD.
God bless you
Aug 02, 2012 | Televison & Video
My tv losses the signal. Emerson DVD Video compact disc digital audio Model #LD195EMX September 2009 Serial #DS1A0940323332 What should I do?
open the t.v look rca input in the board if have looses of solder and the rca cord in your emerson dvd check if have problem.. or replace rca cord that all thanks
Jul 15, 2011 | Emerson Televison & Video
Looking for a code to use on my Dish Network (Universal) remote in order to operate my Emerson Model EWD2202 Combo VCR/DVD player
Hi my nameis Mike Houston of DISH Network and I was going over your post and see whereyou want the codes to program the DISH remote to the Emerson DVD/VCR. We do nothave the three digit codes to enter however we do have what we call a PowerScan and it will allow programming the remote to the Emerson player, I willsend a link to help with these steps. http://www.dishnetwork.com/SupportSection/power-scan-instructions
Oct 31, 2010 | Emerson EWD2202 DVD Player/VCR
Daewoo VCR/DVD combo not turning on
check you power button it might be bad
Aug 24, 2008 | Funai Emerson DVD/VCR EWD2004
Emerson PDE 2717
Apr 04, 2008 | Car Audio & Video
Emerson PDE-2717 portable DVD won't read disc
i believe it is related to power as this issue started on one of these after turning on both screens. i am still dealing with millenium 3000 over a purchase of the same unit. i am going to be trying a 4th unit 'when new stock arrives' but i doubt it.
Jan 15, 2008 | Televison & Video
Emerson PDE-2725N DVD player
My PDE 2625n worked on the way to Mimi's and starting on the way home it displayed "Disk Loading..." then errord out with "Bad Disk". I dug through the internet and over 3 days found the answer.
Your laser is tired. Since the DVD player is cheap, replacing it is not worth the $$. Fix it! Remove the back cover (about 10 small phillips screws). It is important to know that their is a back plate AND a back panel; remove the PLATE which should have a model number sticker.
Now you should see a circut board with a set of polished rails which holds the read head. On the read head (by a ribbon cable ) are two very, very, very small flat blade POT screws. These control the amount of power sent to the laser. Turn the right most one CLOCKWISE about a 1/8 to 1/4 turn.
You can test your handy work by popping in a DVD while the cover is off and seeing if it loads. If all is ok, put it back together. If not turn it a little more. I used a car battery charger to run my test since it's about 25 degrees outside.
Be aware the more power sent to the laser, the faster it burns out (according to my research). By feeling is the DVD player is broke, so what? Am I going to break it? What the hell;) and I cranked away.
BTW I just got this fixed this morning. My kids are screaming with joy for DVD's in the car again! I'm thrilled that I don't have to spend $100 or more to replace this unit.
Cheers!
Ap
Nov 16, 2007 | Car Audio & Video
Open Questions:
What is a good lock radio to get these days? I got this thing a couple of days ago to replace an older model with pretty much the same features auto set, dual alarms, that had started to randomly reset the time zones - not good for making it to work... I noticed that it had been updated and the control redesigned, so there were some more bells and whistles. Big mistake - HUGE! The instructions were too small to read, so found the manual on-line, enlarged it to 200%, which I could then see, but it wasn't written in any kind of logical order. Altogether completely and unnecessarily counter-intuitive and complicated. Took me HOURS to set up, and I'm no dummy. I have to go back to the instructions just to change the alarm or even change a radio station. Back it goes. So now I'm trying to find a suitable replacement - auto set and dual alarms are required, and it would be nice to have digital tuning instead of a dial. Don't want or need projection, a weather report, presets, a usb port, or an iPod charging station. There are some units out there that seemed ok, and were well-reviewed, but all the negative comments were about the directions, difficulty of set-up, multiple-function, unmarked buttons that needed to be pushed in particular combinations to get anything to work, and the complexity of changing settings. Sorry for the long rant, but I've been searching all day, and the 5 - 10 top-rated models all have this same issue! Any suggestions or solutions out there that don't cost $300+, or are only to be found used on ebay? Many thanks for your help! Marianne
Feb 28, 2017 | Emerson SmartSet Dual Alarm AM/FM Clock...
Car Audio & Video Logo
Top Emerson Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you an Emerson Car Audio and Video Expert? Answer questions, earn points and help others
