Question about Nikon FE 35mm SLR Camera
SOURCE: shutter won't open and film won't advance
You might have a dead battery. Check that.
Philip
Posted on Sep 29, 2008
SOURCE: Film Advance Will Not move
Hi,powerpe. The mirror release rod can be located in the bottom of the body once the plate has been removed.(there are three screws on the old k1000's) There is a gear train on the left side when viewed turned over.The mirror cockong rod is towards the rear and a little right of the main shaft.You might need to move a little silver pawl with a pin or micro driver then you can push the mirror **** in to release the reflex mirror.the mirror cocking rod is about 1/8" dia.Hope this helps
Posted on Apr 17, 2008
SOURCE: nikon fm10 cannot get shuuter release button to
The film lever is also a switch. If you had advanced the film lever, **** it outward a little. You will feel the detent click somewhat when doing so. Leave the lever outward and see if the shutter will work. The detent is for appling an closed circuit for the light meter. When the lever is fully pushed back in it shuts the power to the meter on off to conserve battery power
Posted on Jan 01, 2010
SOURCE: pentax me super mirror in up position
If the batteries are flat or missing you wont get LED's to light up and it will set itself to 125 naturally. I know as I have tried it. It could be that the shutter has got stuck on its way down and it is preventing the mirror from coming down as a result this is a mechanical issue, not battery related. The best way I found to release the mirror was to gently, really gently stroke the shutter nearest to the film down towards the groove it goes home in. Recommend a cotton budd so you don't damage the shutter leaves or get grease from your fingers on the movement. This should release the mirror. The next thing to do is try preventing the shutter getting stuck again by removing the bottom plate which will allow you access to the cogs for the shutter. it is tight in there and it is recommended by some that you remove some of the movement to see and clean them up. I did this but it is tricky and it involves winding on the camera and rocking parts out with itself. Not easy to do. The shutter cogs are brass (or look like it) and they may have old oil stuck inbetween the teeth which needs cleaning out with a tooth pick and then lubricate but not with WD40 which gets sticky with age. Use a cotton budd again with the lubricant on so you don't affect other sensitive parts around this section. Alternatively send the camera for a good service. I just had mine done, got it sorted with a warranty for 12 months to and cost me just £45. They cleaned everything up, new light seals and sorted issues common to this model of camera. The photos are instantly back to their best. Compare a good service to a series of wasted film with an inconsistent camera. Peace of mind too, it is worth it and so is the camera!
Posted on Jun 02, 2010
