Question about Schiller Welch Allyn Cardiovit At 2 Interpretive Ekg Machine
How does ECG machine find that signals are good for printing (in auto mode)? some ECG machines take up to 20 second time for printing start
Electro Med Services
  • Schiller Master
  • 6,694 Answers
When the at2 is in auto mode, first of all it check the leads are properly connected or not.Then it will acquire the ECG and store the same in its memory then only it starts printing. that's why it takes that much time to give a printout. When its starts printing you can remove the connections from the patient because it have already memorized the ECG.
If interpretation is in on position it will compare the acquired ecg with the standards in its memory (allready programed by the manufacturer). and will give a detailed report with ecg.
ok
Posted on Feb 06, 2011
  • Anonymous Feb 06, 2011
    Thank you for your response, I agree with all you mentioned but that was not my purpose exactly:
    Some good ECG machines, if signals have no good quality for example EMG artifact, reject stored data and initialize the storage again before printing. What are the criteria for rejecting bad signals for printing? (Does machine calculate correlation between different channels or it judges on Baseline artifact or else?)
    Best regards,
    Alireza Davari
  • Electro Med Services
    Electro Med Services Feb 07, 2011
    hi,
    The word artifact is similar to artificial in the sense that it is often used to indicate something that is not natural (i.e. man-made). In electrocardiography, an ECG artifact is used to indicate something that is not "heart-made." These include (but are not limited to) electrical interference by outside sources, electrical noise from elsewhere in the body, poor contact, and machine malfunction. Artifacts are extremely common, and knowledge of them is necessary to prevent misinterpretation of a heart's rhythm.
    1.Pacing spikes:
    These are seen in someone whose implanted pacemaker is firing.
    The sharp, thin spike is an electrical signal produced by an artificial pacemaker. The wide QRS complex that follows it represents the ventricles depolarizing. We say that the "(artificial) pacemaker captures" when it is able to successfully depolarize its intended target. If a pacing spike is not followed by its intended response, we say that it has failed to capture.
    2.Reversed leads / misplaced electrodes:
    Electrode/lead placement is very important. If one were to accidentally confuse the red and white lead cables (i.e. place the white one where the red one should go, vice versa), In this ECG, we can make out a normal sinus rhythm with all of the waves upside-down. When this happens, you are essentially viewing the rhythm in a completely different lead.
    One must also make sure that the lead wires are actually plugged into the machine. If your talkative patient shows asystole, you should suspect this. Many machines are "smart" in that they can sense common errors of this nature, but many such errors aren't always readily apparent.
    3.AC interference:
    Alternating current (AC) describes the type of electricity that we get from the wall. In the United States, the electricity "changes direction" 60 times per second (i.e. 60 hertz). (Many places in Europe use 50 Hz AC electricity.) When an ECG machine is poorly grounded or not equipped to filter out this interference,. If one were to look at this ECG line closely, he would see 60 up-and-down wave pattern in a given second (25 squares).
    4.:Muscle tremor / noise:
    The heart is not the only thing in the body that produces measurable electricity. When your skeletal muscles undergo tremors, the ECG is bombarded with seemingly random activity. The term noise does not refer to sound but rather to electrical interference.
    Low amplitude muscle tremor noise can mimic the baseline seen in atrial fibrillation. Muscle tremors are often a lot more subtle than that shown.
    5.Wandering baseline:
    In wandering baseline, the isoelectric line changes position. One possible cause is the cables moving during the reading. Patient movement, dirty lead wires/electrodes, loose electrodes, and a variety of other things can cause this as well.
    6.Absolute heart block:
    Absolute heart block (or 4th degree heart block) results from over-exposure to imported-liquor advertisements in magazines. QRS complexes are wide and bottle-shaped and show no relationship with the P wave. It occurs very rarely, and even then, only in fictional settings. This should not be confused with the real arrhythmia complete heart block.
    ok
My ECG machine is not functioning because of open signal is alert all the time when i was start up the ECG machine
hi,
You have to check the patient cable of your machine . If any one of it lead is oppen then it will indicate open signal.
ok
Aug 05, 2011 | Life Science Bionet Cardiocare 2000 12...
I have an at1 schiller it starts to print in auto mode for like 6 seconds and then stops sometime it prints the full report and sometimes it dont can u assist
hi,
You have to check two things. First you have to check the patient cable, and have to check is its electrodes are properly cleanded or not. if any one of the lead or the electrode have some problem then the machine will stop printing.
Second thing the battery inside the machine. its a 12V 2.3AH battery. If availabel try to replace the same. To replace the battery you have to oppen the machine.
ok
Jul 06, 2011 | Schiller Cardiovit At 1 Ecg Machine
I have a Sharp AL 1631 it won't print. It shows an H-4 in the menu screen
Press "Clear" then "Exposure Mode" then "Clear" then "Exposure Mode" quickly like within 4 seconds. The exposure mode key is the far left key.
If you do this correctly the display will go blank.
Key in 14 as if making 14 copies
Press the print button.
Short version: C, far left, C, far left, 14, print
The machine should reset and run fine. This is a common "false" code on these machines.
If it comes back after a couple of tries the you have a thermal fuse or heater lamp failure.
Nov 18, 2009 | Sharp AL 1631 Copier
The printer stop when you request to print out and in auto mode print only seconds time
check to see if the power light goes off when that happens. it sounds like the battery will need to be replaced.
[email protected] www.overstockme.com. Jeff Watson
Nov 06, 2009 | Schiller Welch Allyn Cardiovit At 2...
Schiller AT-1
I have a problem with ECG Schiller AT-1. In auto mode, it prints nothing but in manual mode it works properly. Could you help me solve this problem
Oct 16, 2009 | Schiller Cardiovit At 1 Ecg Machine
The schiller at 2 plus ecg machine not printing ecg
Does it work in auto mode ? are you putting paper correctly means , there is a black mark on paper which is sensed by paper sensor .If you put paper up side down then paper sensor won't be able to sense any paper & gives you error for rifilling paper .If this doesn't help you then You need to replace battrey . Thanks
Jul 15, 2009 | Schiller Welch Allyn Cardiovit At 2...
SCHILLER AT 2 EKG ISN"T PRINTING ON AUTO PRINT I NEED TO KNOW HOW TO RESET IT. I'M LOOKING FOR A MANUAL.
my machine now printed 2 paper in auto print mode, i want this print one paper .Can you help me solve this problem?
[email protected]
Apr 07, 2009 | RTO Schiller AT-2i Electrocardiograph -...
Schiller Welch Allyn Cardiovit At 2 Interpretive Ekg Machine Logo
901 people viewed this question
Top Schiller Medical Experts
ray gallant
papoonick
Level 1 Expert
Are you a Schiller Medical Expert? Answer questions, earn points and help others
