Question about Kenwood FP110 338 Cups Food Processor
I wish to replace the drive belt of my Kenwood food processor, how do I get inside it?! I have the replacement belt.
Posted by gallery530 on
Ronald Rebulanan
    Sergeant:
  • 422 Answers
You can do it just use the right screw driver. some unit use cross philips screw other unit use flat screw type. so check it out before doing that.
Posted on Feb 04, 2011
Need to remove external covers so i can replace a gearbox on kenwood chef km001 mixer! any ideas?
Dont know what the problem is, you didnt say.
Merely take the screws out. Usually on the bottom
of the unit. Heres your big hint, possibly. Some screws
are hidden under the rubber feet.
Jul 31, 2014 | Kenwood KM336 Chef Food Processor
Kenwood KM336 no power to beater or slow speed outlet
Hi. You have a broken gear in the gearbox either the first motion gear is loose on its shaft or less likely the vertical big gear is loose on its shaft. independent spares for the gearbox are available or complete gearbox
Aug 02, 2012 | Kenwood KM336 Chef Food Processor
I have an old model Kenwood food processor deluxe - model A530 and am distraught that i cannot find where to purchase attachment replacements - mine have all become brittle with age and falling...
As another South African citizen I can sympathize with you when it comes to finding service & after care support.
Kenwood S.A.'s website tells you to take it back to the store where you purchased it. Great help that is?
They do however give a JHB number where you can contact them:
011 474-0153
Let me know if you have no joy from this number.
Best wishes,
Graemevm
Mar 24, 2011 | Kenwood Food Processors
Is there actually any one person in the entire world who knows how to take a Kenwood FP510 processor apart to change the drive belt? There are lots of queries on the internet but no solutions. Somebody...
I have solved it at last! Remove the 5 screws on the bottom. There are 2 more screws (which may be blackened with oil) located through the grille directly below the motor. They're stumpy little things with gripping washers. I had to bend the plastic grille thingys to get screwdriver in. Once released, these will enable the whole base to be removed. Then there are 3 screws to get the plate off to put the new belt on. Put the belt around the big cog. Replace the 3 screws of the plate. The motor drive is loose now so you can angle the drive cog to attach the belt to this. Using gravity by turning the processor on it's edge you should with some fiddling be able to put the stumpy screws back in - took me a couple of goes. Replace the 5 screws and robert is a very close relative.
Jan 29, 2011 | Kenwood Food Processors
The motor just humms loudly when I try to start it. If I give it a push it will start spinning, but boggs down if I put any food through it
Take the bottom plate off to expose the motor, drive belt, and pulleys (pull the power plug for this). Remove the drive belt and turn the motor shaft by hand--does it seem to turn freely? Do the same with the driven pulley--it should turn freely also. The pulleys and belt are likely cog-type and not prone to slippage. If either pulley shaft is excessively hard to turn, then investigate the reason,and replace parts if necessary. With the belt off, the motor should accelerate almost instantly. If relatively slowly, the motor may need to be replaced.
Jan 31, 2010 | Kenmore KFP-70 Food Processor
Kenwood FP110 338 Cups Food Processor Logo
583 people viewed this question
Top Kenwood Food Processors Experts
Ross Keen
ADMIN Canada
ADMIN Canada
Are you a Kenwood Food Processor Expert? Answer questions, earn points and help others
