BAd you have problem with the back light most of the times caps that are preheated do this problem but some the the inverter its the bad part open it look for bad capacitate if not exchange the inverter and the power board and it will be ok
Please follow the steps below with you Sky remote.
TV,
RED + SELECT (flashes twice)
TV
0056
Try the volume button if this works then press the SELECT button on the remote. If not press the TV button and try the volume again. repeat this step until the volume works the tv then remember to press the SELECT button to save the code to the remote.
If for any reason this does not work then what I would like you to do is take the battery cover off the remote. You will see a label on there stating what REV 4,6,8 it is. The numbers indicate how old the sky remote is. If your LG telly is a newer tv then you may need to purchase a newer Rev sky remote.
The above should sort you out no Problem Kenny
When it does please leave a thumbs up
