Question about Hitachi Deskstar 7K250 80 GB IDE Hard Drive
I have delete the logical drive in disk management. my hitachi 40GB IDE hdd is not detected in diskmanagement, and i cannot format that drive. ple. help me
Posted by lion_raj_sin on
Menandro de Leon
  • 1,138 Answers
The hard disk is not detected, inaccessible or unreadable because of possible hardware failure, corruption and/ or I/O errors.
To troubleshoot this issue, restart the computer or rescan the disk to try and return the disk to Online
To rescan the disk, open Computer Management, and then click status. Disk Management. On the Action menu, click Rescan Disks.
Just make sure ide cable is fixed properly to the hard drive when scanning.
Posted on Feb 11, 2011
Sata drive is not detected
DO YOU MEAN YOU CAN'T SE THEM IN COMPUTER.
THE DRIVES HAS TO BE INTIALIZED FIRST.
GO TO ADMINISTRATORS TOOLS -COMPUTERMANAGEMENT -
STOREMANAGEMENT-DISKMANAGEMENT (LOCAL).
RIGHTCLICK ON THE DISK AND FORMAT IT.
Feb 09, 2014 | HP 5188-5622 NODUS-M3 GL8E SYSTEM BOARD
I connect hitachi hts424040m9at00 40GB HDD with usb case but it not working plz help give me driver for xp
I assume this is an internal hard drive. If it is not being detected by windows, you need to go to disk management. refer to this link to learn more about disk management : http://www.theeldergeek.com/disk_management.htm
When you are in the disk management menu, you need to create a partition and format this partition (if the disk is new). If the disk already has data in it, then disk management will make Windows recognize the drive.
Mar 19, 2011 | Hitachi Travelstar 4K40 (HTS424040M9AT00)...
Hard disk prolem'
Probablel corrupt partition. Please advise which OS you are using. In windows you can access the drive from disk managerment from where you can re-partition and format it. Keep me posted
Jul 26, 2009 | Seagate HDD 40GB 7200RPM ATA100 2MB...
Hdx avastor drive not seen on pc
please swith of the computer and the hdd connectthe cables then turn on the computer if it dosent detect stilll please right click the my computer and go to manage and then go to diskmanagement in the diskmanagement u should see the hard disk as unalocated or forign .\
then u go to hdd drive if forign please click on the left hand side and say import forign hard disk it shoul work if shows unlocated then u shoul right click on the hard disk name an d say format after formating is over it should get it on the my computer..
Thanks
Nov 10, 2008 | Avastor Computers & Internet
Hard disk drive not detected
firstly check your cable connections, then log onto your bios setup menu during startup and check whether the Hard drive is detected by your bios, if it is then you can try to format the harddrive using the ntfs system (use the long formatt) if you are using windows xp or later if using any earlier os then formatt with the FAT32 system.
If your HDD is not detected by the bios then try to download bios updates for your motherboard and install thed in windows. is this does not work then its time to get a new HDD. thanks
May 27, 2008 | Hitachi hts548080m9at00 80 GB Hard Drive
How to detect two IDE drives with same brand
You need to set one of the drives to be 'master' and the other to be 'slave'.
This is done by positioning jumpers on the back of the harddrives.
Pretty sure that on the drives is explained somewhere how to position the jumper, for several options.
Good luck,
Please post some feedback.
Apr 23, 2008 | Dell OptiPlex GX280 PC Desktop
Harddisk
Check the jumper settings on the back of the drive, if this is the primary HD, set it to master, if secondary, set it to slave, if secondary still does not recognize, switch the ide cable so that the two drives are not on the same one.
Nov 19, 2007 | Computers & Internet
Hitachi Deskstar  7K250 80 GB IDE Hard Drive Logo
239 people viewed this question
Top Hitachi Computers & Internet Experts
Marvin
Marvin
Davit Mamyan
Davit Mamyan
Michael Thomas
Michael Thomas
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
