Question about Samsung SCX 4521F All-In-One Laser Printer
Need samsung scx-4521f scanner driver - Samsung SCX 4521F All-In-One Laser Printer
Posted by t_prasannave on
Chintu-KPV
    Novelist:
    Champion:
  • 202 Answers
Here are the drivers:
Printer: http://downloadcenter.samsung.com/content/DR/200912/20091217112644875/SCX-4x21.zip
Scanner: http://downloadcenter.samsung.com/content/DR/200912/20091217112644875/Samsung_SCX-4x21_Scanner.zip
I hope you got the answer. :)
Posted on Feb 06, 2011
theeban08
    New Friend:
I need samsung SCX-4521F scanner driver for xp
Posted on Mar 30, 2011
5 Related Answers
Anonymous
  • 33 Answers
SOURCE: how to download samsung SCX 4x 16 series scanner
goto www.samsung.com and use the search box at the top right and type in the exact model, the x to substitute for numbers/letters isnt helpful so type the exact model in there and it should have a page to download the drivers
Posted on Oct 08, 2009
Anonymous
SOURCE: Printer Samsung sCX-4521f CRU Fuse Error
Posted on May 29, 2010
Anonymous
  • 6 Answers
SOURCE: The OEMCFG.dll on Samsung needed
GO TO SAMSUNG/SUPPORT.COM
TYPE IN YOUR MODEL# AND DOWNLOAD THE DRIVERS YOU NEED.
Posted on Jul 15, 2009
Anonymous
  • 22 Answers
SOURCE: Driver for scanner Samsung SCX 4100
It can be downloaded from this Samsung Support Site. Link provided: Click Here!
Posted on Jul 22, 2010
RockTheHood
  • 176 Answers
SOURCE: Samsung SCX 4521F Scanner locked.
is a switch under the scanner, change position
Posted on Mar 10, 2011
Unlocked samsung scx 4521F scanner
PLEASE REFER TO IT MANUAL. IF NOT FOUND IT PLEASE CONTACT THE NEAREST MANUFACTURE IN YOUR AREA
Sep 11, 2012 | Samsung SCX 4521F All-In-One Laser Printer
Samsung printer scx-4521f need smarthru4 scanner software
need a reliable site to download smarthru4 scanner software for Samsung printer scx-4521f
Oct 10, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Finding drivers for samsung scx-4521f for windows xp
You can download the Samsung printer drivers from theirsupport WEB site. Please click on this link
and select your model printer todownload :-http://www.samsung.com/au/support/main/supportMain.do
Apr 28, 2011 | Samsung SCX 4521F All-In-One Laser Printer
I want samsung smarthru scanner drivers model no:scx-4521f
go to samsung web page and write your printer model in the little window then download the newest drivers from the download page, you will need 1. driver for the printer, 2. driver for the scanner, 3. driver for the fax and last samsung Dr. Printer
Apr 17, 2011 | Samsung SCX 4521F All-In-One Laser Printer
I have a mac os x version 10.6.6, and a samsung scx 4521f all purpose printer, can I download a driver?
Feb 06, 2011 | Samsung SCX 4521F All-In-One Laser Printer
I Lost my software for Samsung Scanner printer scx-4521f
Dear
The software can down loaded from samsung website at support and download select your printer model and OS type UNIVERSAL driver may download, The files to be down load are printer driver,scanner driver,and additional application for easy use smart panel and smar thru.
Printer Support SAMSUNG India
Thanks.
Jan 10, 2011 | Samsung SCX 4521F All-In-One Laser Printer
SCX 4521F scanner driver will not configure. Have tried repeatedly to download driver, download looks ok, but scanner never appears. SCX 4521F works fine as a printer/copier.
The problem is the firewall of your computer because its blocking the scanner to work better. Check the firewall of your computer from it is control panel if its on. If it is on, click the exception tab then check the network scanner tool and scan to pc box. Just put acheck on all scan or scanner word.
Jul 16, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Jul 15, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Problem scanning with samsung scx 4521f
Sorry to have missed your initial posting...
In any case, to my understanding, this particular printer is likewise capable of USB connection. Perhaps you can try connecting it pure USB and go through the installation again. this might simplify interface and communications between notebook and scanner/printer.
If for some reason you would want to retain Printer/Parallel to Notebook/USB, you need to check your Imaging Devices in the notebook's Device Manager and verify that all drivers are installed for the Samsung SCX-4521F. There should be no yellow or red marks. If there are or if the Samsung SCX-4521F instance is not present, you may need to reinstall using the Add Hardware Option in the Control Panel. You may need to manually select the imaging device/scanner. This holds true if you are using Windows XP.
If you are using Vista, you may need to download all the Vista drivers from the Samsung website. Further, pls be informed that to my knowledge, Vista has certain issues with USB ports. Microsoft has issued a patch/update specifically for this concern. It may be downloaded from here or here.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 05, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
3,014 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
