Question about Haier HDP18PA Stainless Steel Free-Standing Dishwasher
I had problem like this...one day the washer stopped, still half-full of water. Then, we tried to run again and we could hear the little engine working but it wouldn't let water in OR out, just error beaps.
Then my boyfriend took off the back and gently tapped the water inlet valve solenoid with his screwdriver, and now it works! Starting FILLING actually, not draining, but completed a full cycle finally!
Must have shaken loose a blockage in the mechanics in that solenoid, probably have to replace before long. But for now, success!
Here is a website that helps: http://www.searspartsdirect.com/Haier/dishwasher/model-Esd301-repair/categories/dishwasher-repair/symptom/dish004.html
(See "REPLACE WATER INLET VALVE", half-way down page)
Posted on Nov 19, 2014
You maybe right but before doing machine reset button, you need to clean the machine be sure there's no jam in mechanical parts. also not all machine have reset button outside, some are hide and inside the power supply module so look for it and be careful.
Posted on Feb 04, 2011
Oct 25, 2016 | Dishwashers
Feb 08, 2014 | Smeg Dishwashers
Nov 05, 2013 | Haier Dishwashers
Mar 05, 2011 | Haier HDC1804TW Dishwasher
Feb 09, 2009 | Ariston Technologies L63 Free-Standing...
Feb 02, 2009 | Haier ESD300 / ESD301 Built-in Dishwasher
Jan 25, 2009 | Haier HDP18PA Stainless Steel...
Aug 08, 2008 | Haier ESD200 Built-in Dishwasher
On another site, someone posted this: "I called (website), where it was purchased from, and they gave me the number for the manufacturer. Some standard troubleshooting did the trick and my dishwasher is working perfectly again. The troubleshooting involved tilting the dishwasher backwards at a 45-degree angle and letting any excess water drain out. They said ocassionally the water intake will be blocked and this process helps move anything that may have gotten in the way"
I was having the beeping problem too, and decided to give it a try, tipped it for a few, and found it to work!!! Hope this maybe helps!
Jun 09, 2007 | Haier HDP18PA Stainless Steel...
457 people viewed this question
