Question about Fuji FinePix 2800 Zoom Digital Camera
I have camera fuji finepix 2800zoom. it give card error problem?what i should do?
Posted by muhammad_850 on
5 Related Answers
Anonymous
SOURCE: Card not initialized
While the camera is on, press menu and go all the way to the right. Choose "Set-up" and it will take you to a window with several tabs. Choose the tab called "1" and then choose to format the card here.
Posted on Jun 11, 2007
Anonymous
  • 6966 Answers
SOURCE: Memory full
As you posted, both cameras have their memory full then you need to free up the internal memory either by deleting the contents or transferring them (the pictures) to your computer.
To transfer to your PC, you would need the installer/driver CD that came with the cam as well as a USB cable. You need to run/install FinePix Viewer prior to the USB connection. Follow on screen instructions. When asked to connect the cam do so. All others are explained with illustrations on the User's Manual. A copy od the A700 User's Manual is available here.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Dec 14, 2007
Anonymous
SOURCE: Fuji Finepix Z1 Zoom Error
hey
i had the same problem with my z1 camera aswell
and it got really frustrating so i tried different things, like turning it off and on again, taking the battery out etc
but i think ive found the solution to this problem,
when you turn it on you get the zoom error grrr
what i did was open the slide and as the camera is turning on hold down the 'take picture' button at the top and the camera is like normal
it worked for me anyway
hope it works
Posted on Jun 26, 2008
Anonymous
SOURCE: fuji finepix a400 focus error
Hi
I have the same camera and have devised this solution. Remove batteries, leave for about 10 mins then replace batteries ( make sure they are in good condition, Cover the aperture whilst switching it on and it should work - mine did on the 2nd attempt.
Good Luck
Posted on Aug 14, 2008
SAFFOTO
Jeff
  • 78 Answers
SOURCE: Finepix J20 Digital Camera- says:PROTECTED CARD!
My bet is that the little switch on the SD card is in the "lock" position. Switch it off and try again...
Posted on Jan 29, 2010
Testimonial: "Hi I left the comment about the Fine Pix Fuji J20 camera, and I am not sure where the sd switch is on the camera. please if you can let me know.Thanks"
S 5600 finepix fuji camera - card error
Test the card in another device(computer)to see if it works.If so the card capacity may be too large for the camera.
Sep 22, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
When trying to initialize the card it just says card error
Fuji finepixs FinePix A400 says card not initilized
HI, I have been using my camera Fuji finepixs A400 for 2 yrs. Then suddenly it pops up with "card not initlilized".
Jul 31, 2009 | Fuji FinePix A400 Digital Camera
CARD ERROR message
have you formated the card? and if the card has heavy usage it may be trashed.
Apr 27, 2009 | Fuji FinePix Z10fd Digital Camera
Does the Fuji FinePix F45fd camera accept 4Gig SDHC cards?
I had the same situation.. I also bought memory card (4 GB) and my camera came up with an error...Maybe this card is not suitable for finepix F45f?
Dec 30, 2008 | Fuji FinePix F45FD Digital Camera
Write error
I have a brand new fuji finepix 1000fd and was having the same problem (tried two different cards). I contacted Fuji service and they said only Sandisk and Fujifilm SD cards are guaranteed to work. I bought a Sandisk Ultra II 2 GB card ($20 at Office Depot) and after 20 pictures I haven't had an error.... yet.
Hope this helps.
Sep 18, 2008 | Fuji FinePix F460 Digital Camera
Card
when I put my card in the camera I get a card error
Aug 08, 2008 | Fuji FinePix A360 Digital Camera
Fuji 2800zoom. pc says malfunction not reconised
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Apr 13, 2008 | Fuji FinePix A345 Digital Camera
Fuji Fine pixs Z1 write error.
try formatting the disk in windows or via the menu on the camera
may be a dud memory card - they are known to have a short life
Mar 25, 2008 | Fuji FinePix Z1 Digital Camera
Missing Download Disk, Thrown away with Camera wrapping
software for 2800: go to fuji site for download. also, you can remove the memory card and insert into a reader avail for about $8.00. your computer should not need special software to read a memory card from a reader. if your computer has a usb 2 port, use a usb 2 reader to save time. mark
Nov 24, 2007 | Fuji FinePix 2800 Zoom Digital Camera
Fuji finepix a120
You need to Format the new cards in the camera - see the manual
Apr 27, 2007 | Fuji FinePix A120 Digital Camera
Fuji FinePix 2800 Zoom Digital Camera Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Rob Hill
Rob Hill
Are you a Fuji Camera Expert? Answer questions, earn points and help others
