EnGenius EOC-3220 (EOC3220) Logo
Anonymous Posted on Feb 04, 2011
Took unit out of storage. Cannot access 192.168.1.1. Have set proper IP address. Keeps asking for username and password, and admin doesn't work. Lost my created username and password. Please help
Chris Crabtree
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 05, 2013
Chris Crabtree
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
354
Points
Thank you and I tried what you suggested first though holding the reset in for at least 30 seconds as suggested by Andrew Calhoun did the trick and I was able to use admin admin to get in.
Anonymous
Level 2:
New Friend:
  • Expert 108 Answers
  • Posted on Feb 04, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
108
Questions
0
Helped
34600
Points
364
Just try this. reset the hardware EOC-3220 then,
in your internet explorer browser type, 192.168.1.1 when you get in, it will ask username and password
put admin in username and leave the password blank. or put admin in username same in password.
hope it will help you.
  • Anonymous Feb 04, 2011
    only Internet explorer can browse.
Hmm
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Help me with my wep key please
2helpful
I just received a new modem from my cable company and now my router doesn't work. I tried resetting it and it still doesn't work. What do I do next
Wanted to set password om my linksys
192.168.2.1
192.168.1.1
1helpful
New password wifi
How 2 put the password?
I looked on line to get a password, but it won't accept it. I have an I pad that works everywhere else.
I keep getting the error 323. I forgot my name and pass to the router and i cant get on the internet through 192.168.1.1 because its not admin i changed that to. can u help and tell me what to do. i have...
2helpful
Forgot my password and cannot reset?
All D-Link Dir configuration done but I can't access internet,why is that?
192.168.2.1
192.168.1.1
Top EnGenius Computers & Internet Experts
john h
Krzysztof Tomasz
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
