Question about Kwikset Powerbolt/Electronic Deadbolt- Polished Brass
I have a kwikset deadbolt model 898 keyless entry.i need to change pin number on keypad outside
Posted by k_dogg34 on
Jan Berardi
    New Friend:
I had the same question as my son installed the lock. Instructions should be printed on the cover you remove (inside the house). They need to make removing that cover MUCH easier, I'm always afraid I'll break it. Anyway, you press the button once for the first number. To enter a "guest" code, press the button twice then enter the 2nd code in the keypad and press the lock button. Now try both main # and guest #, both should open ttthe lock.
Posted on Sep 30, 2011
Coaltowner
  • 963 Answers
I was searched but was unable to find any information on the model 898 keykess entry set.
I therefore suggest that you call Kwikset's Customer Service; I'm sure they can help you:
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Kwikset Corporation
Consumer Service
19701 DaVinci
Lake Forest, CA 92610
Kwikset Customer Service
Call: 1-800-327-LOCK (5625) Fax: 1-800-713-7080
Support Hours: Monday-Saturday
7:30am-4:00pm PST
Closed Sundays and Major Holidays
Posted on Mar 10, 2011
  • Jack InTheBox Aug 03, 2011
    The programming instructions are inside the back of the unit...
Need a video how to program my keyless entry deadbolt lock
Which manufacturer made the keyless deadbolt lock? Make sure that the batteries are good in the unit.
I have an older Weiser Powerbolt deadbolt lock that is programmed by taking off the cover on the inside of the door. This model has handheld remotes and the keypad. Inside there are three yellow buttons. Two match the cover's lock and unlock buttons. Press and hold the third button (in the center of the set of buttons). Then enter program in the code within a few seconds and press the enter button to set the code. If the unit beeps again, the code is set. If the unit doesn't beep, retry from the press and hold the Program button step.
Another model of the Weiser Powerbolt lock has the Program button either on the top left or lower right hand side of the board (depending on the way the door opens) under the cover. Press the Program button once and then enter the 4-8 digit code. Press the Lock button to set the code. If you hear a long beep, the code was accepted; otherwise try to program your code again.
Kwikset Powerbolt locks are programmed the same way as the second Weiser Powerbolt described above.
Kwikset SmartCode locks have their Program button in the center of the bottom of the control board. Otherwise the programming is the same as that given above for the second version of Weiser Powerbolt locks.
MiLocks have three buttons in a horizontal line. The left-most button is the Set button. Press this then enter the code followed by the Unlock button. The code must be entered within 5 seconds of pressing set.
Baldwin Hardware's Boulder series of keyless entry deadbolts are programmed just like the Kwikset SmartCode units.
I don't know of any videos. Most manufacturers do have PDF files with the programming instructions.
I hope this helps. Please add more information about your deadbolt for extra assistance.
(I end up replacing the batteries often on the lock I have; it seems like they last 6 months or less.)
Oct 20, 2013 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
How do you take the cover off to change batteries in Keyless kwikset deadbolt 907
Here is a link to the installation instructions. You will find the answer there:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
If you cannot display them properly, you need to download and install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
Good luck, and please provide feedback if this helps!
Oct 31, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Just installed keyless entry lock. Lock button works fine, enter code and deadbolt only partially retracts. Worked fine the first time, will not completely unlock since. Key works to fully unlock. Tried...
Your lock is under one year warranty, with a lifetime warranty if the problem is mechanical or the finish.
Here is a link to the website warranty information, and from there you can contact them for technical and warranty assistance:
http://www.kwikset.com/Customer-Support/Warranty-Information.aspx
Good luck-and please provide feedback if this helps!
Oct 11, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
How do you change code on Kwikset 907 keyless deadbolt
For troubleshooting:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Notice that the above may be a .PDF file type. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
Good luck--and please provide feedback if this helps!
Jan 06, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Why doesn't the back lights work on my Kwikset 907 Power 1000 Keyless Entry Deadbolt? Are there any other batteries beside the four 1.5 alkaline batteries?
Installation instructions for the Kwikset 907 link:
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
This is the link to Weiser Customer Support Page, where you will find the appropriate number for your location:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
Oct 21, 2010 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Kwikset Powerbolt/Electronic Deadbolt- Polished Brass Logo
1,237 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Charles Tidwell
ray gallant
STEVE SPAM REMOVER
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
