Panasonic RR-US470  Handheld Digital Transcriber / Recorder Logo
Posted on Feb 04, 2011
The red recording light is activated when I am recording - everything else seems to be working normally. When I go to replay there is no sound. Other earlier recordings are working. I've checked the VAS is switched off.
Davey-sydney
Level 1:
Cheetah:
An expert who has answered 20 or more questions within one hour.
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 63 Answers
  • Posted on Oct 21, 2013
Davey-sydney
Contributor
Level 1:
Cheetah:
Night Owl:
Answers
63
Questions
0
Helped
23110
Points
64
Have you tried a hard reset?
1 Related Answer
CosmaP
Cosma Papouis
  • 409 Answers
  • Posted on May 28, 2009
SOURCE: red record button will not depress to start recording
Check that you have not knocked the record tab out of the tape you are using.  Try a new tape.
I have an ONKYO HT-S3305 which transiently 'cuts-out' the sound - lasting only seconds (hooked up to TV/satellite HD receiver) Seems to start after about 1-2 hours after switching on. Not the signal...
It sounds to me that some part of the circuit possibly an IC is overheating after several hours and develops a fault.
This will be a very tricky thing to track down. So maybe best to take it to an authorised service agent.
2answers
Replaying a time recording program. Why does it replay in Spanish not English
Well, it seems like it is already in English, but the spanish wasn't translated because of malfunctions that who knows what happened, for setting caption should be off unless you want text, voices of blind people sounds like the program on t.v. you recorded.
When Im done recording and replay it, there are parts that have glitches and repeat itself. What do I do? I checked everything and everything seems to be ok. Im not sure how I can fix it.
Do you mean you're hearing reverb (echo) of recording? If your recording music or vocals make sure playback speakers are off when doing so. If you leave them on, you're recording multiple times IE: ECHO
I have a TASCAM PortaStudio 424 mkiii 4-track tape recorder-mixer. When I record a new track and listen back to it, everything sounds great. After a couple times of listening to it, and overdubbing other...
It is probably a hard to find record electronics problem and possible that the record bias is staying on partially. This will erase partially the audio and apply the clicks. You are going to need a good Technician for this. Try this guy- I have confidence in him.
New Jersey Factory Service, Inc.
16 Chestnut Avenue Suite 103 B
Emerson,New Jersey 07630
201-967-0060
Fax 201-967-0062
Mon- Thurs 8-4 Closed Fri Sat by appt.
My action replay is not working
When you have the cheats in front of you ,you must check in the box.That will activate the cheat and it may take a few seconds to work in the game...
All led's light up in my mixing desk
I moved the sound card to another slot in the PC and it seems to have worked although I cannot get my vocals to record if you can help I would be grateful.
Alan
1helpful
2answers
Problem with memory
The problem is simple to fix...shut off radio replays. Thought they are supposed to make you aware of low memory..the replays seem to automatically replace "loved" songs.
4helpful
Magnovox MWR20V6 will not begin recording when it should.
This is more a work-around than a solution, as the unit is failing to function normally; however, having the identical problem I observed that the unit is failing to power on at 2:00 minutes before beginning recording, a necessary step to record to DVD.
My work-around is the following:
1) Set up the timer, inputting necessary date, time, etc. as normal. With the unit still powered on, start the timed recording mode by pressing timer set, as normal. You will see the red clock icon and the DVD logo iluminate on the VFD.
2) Press the Standby-On power button. This will power the unit on in VCR mode. You should at this time be unable to switch from VCR to DVD mode since the DVD is still in timer mode. LEAVE THE UNIT POWERED ON in this manner. The timer will function and the DVD will record normally.
I have no clue why my unit suddenly forgot how to power up on its own in order to record to DVD. If anyone has an answer for that one please post!
Tom Gee
Microsoft webcam VX 6000. Buzz on video capture
I took the cam apart, removed the mic from its seat and gently separated the red and black wires - ran the red one over top the lens and the black one underneath. Replaced the mic, screwed it all back together and the problem is gone. For now. One tip is to record sound using Windows Sound Recorder while you're doing this, watch the input line and when it goes flat you know the buzz is gone. While it buzzez, the line will be active.
High sound when recording
Hi, I'm having problems with the telephone recording using a digital cordless phone. Once the hanset is picked and conversation is going on, the unit does not record???
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
