1999 Saab 9-5 Logo
Posted on Feb 03, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
A saab dealer told me that they can order a belt to bypass the ac compressor ( saab dealer on centre ave in Wilmington N.C.) It comes from euope. part # 4961058. It is for a 1999 saab 9-3 2.0 motor only euopean cars had a no air option I'm sure that other saab had the same option in euope
miles
Level 2:
Sergeant:
  • Expert 197 Answers
  • Posted on Feb 03, 2018
miles
Expert
Level 2:
Sergeant:
Answers
197
Questions
Helped
89720
Points
612
Probably just shorter belt will not go round air-con
5 Related Answers
Anonymous
  • 1010 Answers
  • Posted on Jun 23, 2008
SOURCE: Needing to remove ac compressor to install ac bypass pulley
There are a couple of ways to approach this. I just did one of these for a friend. The A/C pump seized while running. The serpentine belt broke. Crazy things can happen to other components when this occurs. In this case the broken ends of the belt, I think, whipped back around on itself on the crankshaft pulley and one of the other pulleys in the belt circuit and devastation occurred. 1) It snapped the power steering pump bracket in two. 2) It took out the alternator. 3) And not to be left out, GOODBYE cool blowin air conditioning. Time to decide what to do. He had to order the power steering bracket from a dealer (junk yards were cleaned out). He decided to replace the power steering pump with a remanufactured unit and new hoses (parts houses are much cheaper than dealer parts folks). You'll need a pulley remover that you can usually borrow (with a deposit) from some parts houses. He HAD to buy the alternato ya gotta have juice. I have been using the name, "parts houses" . (Can we use specific company names in this forum MR./MS. Editors ? I Feel I need to for the sake of all of us that come here for correct information.) THE ANSWER : DO you want to drop the bucks into fixing your A/C ? NO ? It can be involved and costly depending on how good of a do it yourselfer you are. New pumps are spendy. Then, if you use the older refridgerant you'll need a conversion kit and blah blah blah. YOU have opted for a bypass pulley. COOL ! Errrr...not actually. It's coming out. The bolts that hold the A/C pump to its bracket come out from BEHIND the bottom of the unit. They are long and won't clear the intake manifold,at least not easily. Take the bracket bolts out from the front. Take the hose from the pump to the dryer apart (at the dryer). Do you want to preserve the system for future repair? If so, cover that connection on the dryer to protect it from the world. With a sharp blade, cut the other hose coming off the pump right behind the grill. Or, try to take the fitting apart at the evaporator. Cutting it is easier. Plug the cut off end if ya want. Future repair thing. Rotate the pump forward so you can either take the bolts out,or remove the pump and bracket as a unit, with the lengths of hose attatched to the pump. This gets all that hose you no longer need out of the engine compartment. NOW THE BYPASS PULLEY. He found a pulley from NAPA. IT DOES NOT WORK ! YOU DO NOT NEED IT ! Nothing against NAPA. I have bought good parts from them before. Maybe their supplier does not know. The pulley is supposed to drop into the A/C bracket in the concave recess that the pump once occupied. IT WASN'T EVEN CLOSE. Chevy released THREE versions: Poor Boy-no power steering,no A/C. MIDMan-power steering,no A/C. Rich Guy-power steering,with A/C. SO....... If you have power steering, the A/C pump removal just put you into Midman status. Stop at your local chevy dealer, ask them to print you a belt routing diagram from the computer parts book. It shows all three versions. Go to your local,,,,,,,"PARTS HOUSE", tell them info...year,make,engine size, REMEMBER.. IT NO LONGER HAS AIR CONDITIONING. YOU'LL GET A SHORTER BELT !! IF, they sold you the bypass pulley.....GET YOUR MONEY BACK !!! Use the diagram you got. The belt is routed a little different since you lost the A/C pump and the idler pulley with it's bracket(that you can keep for future repair or trade in for to be made into beer cans) Also remember that without a belt on, the tensioner pulley is swung over to the end of it,s range of motion. When you get the belt routed correctly you have to put a wrench on the bolt on the pulley and turn hard to compress the spring. (COUNTERCLOCKWISE) The bolt is left hand thread so it won't come loose while ya reef on it to get the belt swung onto the ALTERNATOR LAST.<<<<<<GOOD LUCK !!! ADDED NOTE: Would that bypass pulley work on say...an "88" or "89" or "90" ? > I DO NOT KNOW. DID CHEVY change the size of the pump bracket after 87 ? We will be letting the good folks at NAPA know what we ran into and how we fixed it. We also will ask for a refund on the wrong part for the job. IT DOES NOT FIT AN 87! WE DO KNOW THIS..... IF the belt had just broke in half and safely dropped away, then all those parts wouldn't have been needed and the cost of the fix is FOR A SHORTER BELT and a little sweat to remove the A/C pump and bracket. The A/C NEVER WORKED ANYWAY
Anonymous
  • 8 Answers
  • Posted on Mar 01, 2009
SOURCE: 94 park avenue ac compressor locked up can i bypass?
there should be a manual bypass to remove the clutch to the compressor otherwise measure the belt and go about 10 inches or shorter (just a hint to get the belt off use the tire iron wrench and push the tension pulley toward the cab of the car the thread is reversed)
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Apr 09, 2009
SOURCE: can I bypass the AC compressor by buying a
the one without ac has an ac delete pulley that sits where the ac pump would go, so the answer is no, buy the pulley.
Anonymous
  • Posted on Jul 21, 2009
SOURCE: on a 2001 saab 93 turbo can can you bypass the ac
You can bypass both the AC compressor and the middle serpentine idler pulley with a 6PK1790. The middle pulley is bypassed by running the belt straight line from the upper rear serpentine idler straight to the power steering pulley, then over the water pump (the smooth pulley powered by the back side of the belt) and down to the engine drive pulley (harmonic balancer), bypassing the AC compressor) This works fine. On 9.5 models, the same basic idea, but a slightly different sized belt.
Larry Chandler
  • 1149 Answers
  • Posted on Dec 15, 2009
SOURCE: bypass ac compressor 2006 dodge ram 3500 5.9 L
Hi:
The easiest method to do this is to go to an auto parts store and buy a belt designed for a truck with no air conditioning. The belt will be the right size, and you just install it as normal, and bypass the compressor
Testimonial: "a"
2answers
2003 Ford Focus SE 2.0 DOHC. What size belt do I need to bypass A/C, and what is the routing for that.
google 2003 ford focus se 2.0 dohc ac bypass pulley for answer. you will replace ac compressor with this item $40.00-50.00
Can i bypass the ac compressor by shortening the serpentine belt or do i need to replace the ac compressor?
You can bypass but ck the parts store for the proper belt. Or call the dealer & get a belt from them.
1helpful
2answers
2001 chevy venture what size is belt that bypasses a.c. compressor the exact measurements
There is no belt to bypass the AC cataloged, when the AC is not ordered on the car (AC delete) or the compressor is removed for some reason then you must use what is called an AC delete pulley, it bolts in place of the AC compressor and you use the same belt. The pulley is cheap and either the dealer or most good auto parts stores like NAPA (or others) can order it for you, in the aftermarket the pulley's are made by a company called DORMAN
What is the belt diagram for an 04 trailblazer and bypass the air conditioning compressor
You can't buy a belt to do that, you must use the same belt and install an AC bypass pulley where the AC compressor used to be. If the dealer can get it, it will be called an "AC Delete" pulley. It is also made by an automotive parts manufacturer called DORMAN, check with a local auto parts store, not Autozone.
Could smell a burnt wire smell (maybe belt) and lost AC. Was told that I need a AC Compressor kit. Was told that you can't bypass it. Is this true?
because of the way the belt is routed the ac compressor can not be bypassed by using a smaller belt. So that leaves you with 2 options. 1. replace the a/c compressor and enjoy the benefits of a/c during the hottest days of summer. 2. remove the a/c compressor and install a bypass pulley. option one gives the most benefit for the dollar and is also the most reliable repair. option 2 is not as sound of a repair, can be installed incorrectly, has a higher probability of failure, costs less, and makes you rely on open windows to cool off.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
2answers
2000 Mercedes e320 with a frozen a/c compressor what size belt do I need to bypass?
There is no belt to do this, you must install a compressor bypass pulley also known as an "AC Delete" pulley. All cars come with the same belt with or without AC. Contact the dealer on this, but not sure they can help as AC is standard on US models unless you order it deleted, which of course no one does because of the wait time to have the car shipped from Europe due to the special order.
How to remove & bypass AC compressor on 94 ford F250 W/460
You must buy an AC delete pulley assembly, it goes where the AC pump is now and then you use the same belt. You can order it from the dealer or buy them on line from other suppliers.
5helpful
On a 2001 saab 93 turbo can can you bypass the ac compressor or is there a bypass pulley
5helpful
2answers
Eliminating the a/c and shorten the belt
If its a 2.7L you can bypass the AC with no problem. Did it to mine 6 months ago. Left compressor in place. Little hard to find right belt because all sebrings have AC. Went to napa bought 5 took the other 4 wrong ones back. LOL
Top Saab Experts
ZJ Limited
ZJ Limited
john h
Sean Wright
Sean Wright
Are you a Saab Expert? Answer questions, earn points and help others
