Bosch TDA8340 Iron Logo
Posted on Feb 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Brown water spitting out of bosch steam iron - Bosch TDA8340 Iron
Anonymous
Level 3:
  • Bosch Master 43,501 Answers
  • Posted on Mar 24, 2011
Anonymous
Bosch Master
Level 3:
Answers
43501
Questions
0
Helped
10835315
Points
101584
Brown water and white scale are often the result of the water you use in the iron...
If you have scale, white vinegar will clean that...
For brown water, empty the iron, rinse out the insides with bottled water,
and then use the bottled water instead...
Also check out this tip...
Cleaning a Steam Iron White Scale and Brown Water
heatman101
4 Related Answers
Anonymous
  • 304 Answers
  • Posted on Jul 24, 2008
SOURCE: Brown spots coming from steam iron
Fill with 50/50 water vinegar solution. Get it good and hot and let it sit for two hours. Rinse and repeat if necessary. Buy a gallon of water from the market and use that from now on. This will fix your problem. The Iron is concentrating the iron in you water and this is what is causing the brown spots. Hope you find this helpful. If you do please take the time to rate it fixya and maybe I will keep helping people for free.
George
Anonymous
  • 59 Answers
  • Posted on Nov 15, 2007
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
Anonymous
  • Posted on Jan 31, 2011
SOURCE: Rowenta steam iron also spitting brown steam....it
There are chemicals in the tap water,it sounds like it has too much iron in it.Stick with the distilled water.
Anonymous
  • 43501 Answers
  • Posted on Apr 02, 2011
SOURCE: My Rowenta Expert steam generation iron (seperate
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
My Rowenta Expert steam generation iron (seperate tank for the water type) is starting to spit ever so often brown water out. I only use filtered water. How can I clean the actual Iron, the water tank is...
heatman101
12helpful
3answers
16helpful
Dirty water in my iron
The dirty water coming out of your iron steam holes is caused by the accumulation of 'dirty' tap water: if you look inside an eletric kettle, you will see the same 'dirty' muddy brown mineral residue on the inside. In addition, if your iron is old, it can also be rust. It is a pretty common problem that can be minimized by using distilled water. You can get commercial steam iron cleaning fluid to clean the inside of your steam iron or you an simply use vinegar: 1) with a cold iron, fill the reservoir with straight vinegar 2) Place your iron on top of a metal kitchen rack above your kitchen sink, turn iron on and let it steam out all the vinegar: it should spit out the whitish mineral and muddy brown deposity. 3) Refill iron reservoir with clean water and repeat as of step 2. 4) Refill iron reservoir with clean water, wipe any dirty from the sole plate and this time on full steam, iron on clean layers of Kitchen paper to ensure that all dirt has been removed from the inside of the iron reservoir, if not, repeat from step 1 again.
In the future, try to use distilled or at least filtered water.
Hope it helps: let me know how you go!
6helpful
Iron spitting out brown water
I'm afraid the brown water is rust if it is I would chuck the iron and buy a new one.
If it's just scale then mix "Lime Away" 50/50 with water pour it in the opening where you put the water in for steam, turn it on low and let it sit for a few hours, rinse it three or four times and then try the steam again.
Feb 26, 2009 • Irons
Top Bosch Irons Experts
john h
ADMIN Andrew
ADMIN Andrew
Aron
Are you a Bosch Iron Expert? Answer questions, earn points and help others
