SOURCE: How to make Blitzz BWA711 Router secure?
The minimum security will be WEP, so the wireless receivers on your pc should match the type of encryption. To give you WEP you select security in the routers menu and choose yourself a mixture of 6 pairs of letters and numbers in any column from 1 to 6 if it gives you 6 options. Once the letters and numbers are chosen, note down the chosen leters and numbers, and enable wep and restart router. Now go to your pc's and and go to the software you use for the recievers and select WEP. You will probably have to tell the programme whether you are on a 'Shared network key' or an 'Open network', depending on your network type (try both until one works if not sure). It will then ask for the numbers and letters you chose and wrote down, enter these and click apply and restart system. The pc's should now connect to the router. Some wireless laptops are unable to recognise WPA type security or similair so WEP is better than nothing.
SOURCE: set up password on blitzz bwa711 router
Login to the default router config page from your desktop pc. This is usually plugged straight into the router via a network cable. Go to http://192.168.1.1 in w web browser. Default login is usally "Admin/Admin" or "Admin/Password" keep trying different combos.
You may also need to press the "Reset" button on the back of the router.
SOURCE: How do you reset a Blitzz BWA711? We are unable to
Remove the power cord and press the reset button with a small pin or paper clip. The reset button in recessed in a small hole just below where you would plug the modem cable in.
SOURCE: need drivers
Router doesnt require driver to be installed on a computer to work. For getting into the settings or web configuration page type http://192.168.1.1 on the address bar of Internet explorer or any available web browser and you can configure it.
