Question about Gateway FPD1975W 19" LCD Monitor
Please send driver fpd1975w - Gateway FPD1975W 19" LCD Monitor
Posted by aliraza57349 on
Bud Martin
  • 11,361 Answers
XP and Vista: http://support.gateway.com/s/MONITOR/7005574R/7005574Rsl.shtml
No Windows 7.
Please leave rating if it helps.
Posted on Feb 04, 2011
FPD1975W TFT LCD monitor my monitor blinks a blue power light and flsahis a white screen but it does not turn on ?
A flashing power light indicates a failure of the power supply, this will also cause the white screen. Here is a link to a page showing what parts need to be replaced to repair the power supply board and get your monitor back running again.
http://www.ccl-la.com/blog/index.php/gateway-fpd1975w-monitor-repair/
I hope this helps, if so please rate my solution,
BuddyMc
Hello, i just bough the gateway monitor FPD1975W but i can not to connect because it asking for passcode. what i culd do? thanks
This is bad news, you will need to get it fromt he original owner and you alos need to contact GATEWAY, please see below:
http://www.fixya.com/support/r4558549-gateway_lcd_monitor_eztune_theft
I need a driver for a FPD 1975W LCD Monitor
Please mention the serial number of your monitor or visit below page to download the driver for it.
http://support.gateway.com/support/drivers/dlcenter.asp?Tab=My
Let us know further.
Thanks for joining us.
Have a nice day.
2answers
My monitor just died. no picture no nothing. whats going on is it fixable or thats all i'm going to get from it.
franccoperez
I would try your monitor on another computer to see if it works and/or try a CRT monitor on your computer and reinstall the video card drivers. I have seen a big issue with this lately where the video card drivers are getting corupted. When this happens the computer sends a signal out of range to the monitor causing it to turn off so it does not get damaged.
If your monitor does work on another computer and you need help reinstalling your video card drivers let me know.
Issken
Fpd1975w display flashes on and off
what resolution are you setting your screen to? if you are setting it too high or to a resolution/frequency that your monitor doesn't support, it will do this. Try setting it to 800 x 600 w/ 32 bit color and a frequency of 60Hz. If you do this and the monitor still blinks, you may just have a bad DVI cable.
My gateway fpd1975w tft lcd monitor does not work. the power button just flashes blue and nothing comes on. i put an old monitor to my computer and it worked fine, and i hooked my monitor up to an old...
Restart the PC and get into SAFE MODE. Hit and release F8 many times right after turning on PC. If it works, then go into your video setting and either change the settings or remove the video driver. Restart the PC and you'll get 800X600 screen, then reinstall the video drivers. IF it won't go above 800X600, screen internals are bad, LCD toasted. I've seen that happen with LCDs and older monitors.
FPD1975W monitor issues
Check your video card. it may be a bit lose in the port. Also, you should reinstall your video card drivers as well. make sure your monitor is plugged into the correct video card AVI/dvi input port.
2answers
Power supply for Gateway FPD1975W 19 inch LCD
try replacing the crystal on the power supply 8 out of 10 times it is the problem
Gateway FPD1975W 19" LCD Monitor Logo
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Jessie Goss
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
