Question about Konica Minolta bizhub 350 All-In-One Laser Printer
I have a Konica Minolta bizhub D2510F it gives me this error C0501. after searching around I found out that this error is a Fuser error. I replaced the Fuser and the PhotoConductor but I still get the same message on the screen. does anyone know how to reset this Machine? Thanks
Posted by stevenabdul on
Steve Green
  • 87 Answers
The error has to be manually reset. Here is what I found from the official procedure. Hope it works. How to clear a fuser error code (C0500, C0501, C0510, C0511, C0520, C0521). Solution To clear the fuser error code, perform the following after correcting the cause:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
Note: It is not in the same location as the models 7915/7920.
2. Insert a suitable object into the hole to actuate the reset switch .3. The code should clear and a message to close the front door should appear.
Posted on Feb 03, 2011
  • brandino Jun 22, 2011
    where is the front door and which side is the hole on
Konica minolta 240f error code 18 stands for what
https://printcopy.info/?l=en&mod=erc&brand=Konica-Minolta&model=bizhub%20240F&code=18
Konica Minolta bizhub 240F Error Codes
Quoting from the web link shown above:
Konica-Minolta bizhub 240F Error Codes
Exploded Views and Parts List Free!
Code
18
Description
Fuser Error
(The number indicates the detailed error code) 0 The fuser did not become to the main motor driving temperature in 50 seconds after printing started. 1 The fuser did not become to the paper pick-up temperature in 50 seconds after printing started. 2 The fuser did not become to the main motor driving temperature in 30 seconds after warming up started. 3 The fuser did not become to the warm-up finishing temperature in 30 seconds after the motor started driving. 4 A temperature of 250°C or higher is detected in a mode other than sleep mode. 5 The fuser does not warm after fuser error is solved and the power is turned OFF/ON. 6 A low temperature of 10°C is detected in 10 seconds after printing started. 7 A temperature of 190°C is detected in ready mode after printing finished.
Remedy
1. Turn on the power again, and verify the fuser warms up. If it does not, see step 4. 2. Check the contact between Fusing thermistor and Connect A PCB(P89). 3. Check the contact between Connect A PCB (P80C) and the main board. 4. Replace the Fuser. 5. After replacing the Fuser, verify the fuser warms up when the power is on. 6. Replace the main control PCB.
Apr 07, 2018 | Konica Minolta Office Equipment & Supplies
How to reset error code 3505 in konica minolta bizhub 600
When you reinstalled the upper and lower fused rollers mite have flipped the sensor so it's not riding on the fuser roller
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 31, 2014 | Konica Minolta Bizhub 600 750 Image...
C0501
The 501 code is not for bizhub 350 is for dialta 250/350/2510 and refer to fusing unit error.
Dec 16, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Maintainance call display of konica minolta copier bizhub 211
Maintenance call? from your question it is not clear what is the error code.Please see if there is any code appearing besides maintenance call.Note the error code and tell me again so that i can help you.If it is C0500 or C0501 then press the stop button on the panel and restart the machine do not release the button until the code removes.
Dec 13, 2012 | Konica Minolta KONICA BRAND TN-211 BLACK...
Konica minolta bizhub c350 error codes c-0510
eror code c-0098 meaning ??????????????pls tell me the solution
Jul 31, 2012 | Konica Minolta Bizhub C350 Digital Copier,...
C0501
turn off the machine, press the stop button, turn the machine ON, and keep the "STOP" button pressed, C0501 error code will reset in few moments...............
Aug 03, 2010 | Konica Minolta bizhub 180 All-In-One...
Error code c0520 konica minolta c350
How to clear a fuser error code (C0500, C0501, C0510, C0511, C0520, C0521).Solution To clear the fuser error code, perform the following after correcting the cause:
Jan 18, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
My bizhub has an error code of C0501
C0501 it is a trouble related with the Fusing Unit. Try to power it up with the STOP button pressed. If not, you may need to change your fusing unit.
Jul 23, 2009 | Konica Minolta bizhub 180 All-In-One...
After a power surge it comes up with a C0501 malfunction code and shuts itself down
The C501 code is to do with the fuser section not heating up in a given period of time.
Best guess would be that the surge blew the thermal fuse in the fuser and the lamp in not coming on.
This will nivolve taking the fuser apart, if you are not so inclined, it might be time to Call your local Tech.
May 14, 2009 | Office Equipment & Supplies
C0501
FUSING ERROR ISSUES
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Apr 12, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
1,455 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
