SOURCE: Blank Streaks
streaks are caused either by the toner, drum, lamp or fuser.
If you make a copy and it does not show a streak then it was done by the person sending the fax. BUT, check this,
open door and take out toner cartridge. look for a thin glass that is on the bottom of the machine and wipe it. Toner spills will cause a black streak.
SOURCE: thick black streaks on pages coming through the fax
remove the toner cartridge and you should be able to see the matching black streaks on it, if it is the problem .....don't bother trying to clean it , it is supposed to be self cleaning and you can't improve this look...replace
SOURCE: black streaks on prints
Where the original page that you wish scanned/faxed there will be a device called a "scan part". This device "reads" the paper to be faxed/scanned as it passes. It usually is found very near where the paper to be faxed goes in.
If there is a spec of debris on this part it will cause a fine line straight down the document. If its dirty, the document will be too! Just give it a good cleaning and you should be fine.
Did this help? Click "FixYa" below!
Thanks
Len
