Question about Akai LCT2715 27 in. LCD Television
Akai Lct2721ad wont turn on. red light flickers when i attempt to turn on
Tyler Bearor
    Champion:
  • 367 Answers
Any luck getting this fixed?Please let me know.Thank You very much!
Tyler
Posted on Apr 20, 2011
Akai lct2721ad wont turn on red light in on
Whn you try to power it up does it attempt to power on before going red or does it just stay red? If it just stays red then its definitely a case of faulty power supply board. The easies way to resolve this problem would be to replace the power supply board, which can be obtained for about 50-75$ from shopjimmy.com. So let me know if you wish to fix it yourself
Feb 03, 2011 | Akai LCT2721AD 27 in. LCD Television
Blinking red light
change all 1000mf-16v & 470mf-16v cap in power supply.possibly blow.
May 06, 2010 | Akai LCT2721AD 27 in. LCD Television
Akai LCT2721AD TV just has a red light on. it wont power up at all.
I had the same problem with mine. I took the back off of it and found 3 blown 1000uF capacitators in the power supply. I replaced them and now it works fine. Cost me about $1 compared to $100 at the shop.
Nov 20, 2009 | Akai LCT2721AD 27 in. LCD Television
TV will not start easily. Akai LCT2721AD
You only have to unplug it for 30 seconds. Also, make sure it does not have a DVD in it when you turn it off as the TV will try to default to the DVD all the time. Resetting the power (I use a surge protector) allows it to turn back on normally. Based on the comments I've seen this TV has terrible sound with DVD, doesn't want to turn on, and is hard to mount on a wall.
Nov 18, 2009 | Televison & Video
TV won't power up unless I unplug it and then pluc it in again.
Follow this guys advice. I did it and it worked. My first TV fix and I did it. http://www.fixya.com/support/t1661054-akai_lcd_tv_power_light_stays_red_turn
Apr 21, 2009 | Akai LCT2721AD 27 in. LCD Television
Tivo DirecTV Remote-Program AKAI LCT2721AD
Try this: On the Tivo remote press and hold the TV Power button and the Directv/TIVO button at the same time. Hold both buttons down for about 4 seconds or until remote light stays red. Then press the channel up button until the tv turns off. You may press the button over 100 times. You need to go slow. When the TV turns off press the enter button (or select button).
Dec 09, 2007 | Tivo DirectTV Remote Remote Control
sounds like the pwr supply is suspect....
Oct 23, 2007 | Akai LCT2721AD 27 in. LCD Television
Akai lct2721ad flashing red light
I would bet on the power supply....these (and other Akai LCD) are notorious for filter capacitors. Look for electrolytic capacitors with a dome-like bulge on the top of them. They are usually located at the top of the power supply board where the power output lines run out.
Hpe this helps you out....
Sep 23, 2007 | Akai LCT2721AD 27 in. LCD Television
Akai LCT2715 27 in. LCD Television Logo
109 people viewed this question
Top Akai Televison & Video Experts
Ekse
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
