Question about Aastra Telecom Aastra 9316 CW Corded Phone
Phone readout says CHECK LINE CORD - Aastra Telecom Aastra 9316 CW Corded Phone
Posted by jschneide99 on
How can I stop the Samsung gusto 3 from reading numbers of incoming calls.
I believe one of the Accessibility Readout options is enabled. From the home screen, press the Left soft key. Select Menu, then Settings. Go to Accessibility and then Easy-Setup. Check that the following are off: Full Readout, Digit Dial Readout, Alert Readout. (Alternatively, you can look at each of these individually from the Accessibility menu.) There may be other options to check in the Readout options but these seem the most likely.
I hope this helps.
Dec 21, 2017 | Samsung Cell Phones
I've just bought the above phone and connected tomains to charge batteries and handsets show "line chord error" is this because the phone line has yet to be plugged in?
yes, it will either show line cord error, or no line. After phone is charged plug line cord in and it should go away if not check line cord or try another known good cord.
Aug 11, 2015 | Lands Phones
Really bad crackling sound on certain calls
if only happens on certain calls it could either be the handset itself, a week point on all corded phones is the cable between the handset and the body of the phone. whilst talking to someone on a call wiggle the cord where it enters the handset, does it crackle if not do the same where the cord enters the phone body, if no crackle likely not phone.
next select a line if you have more than 1 line note which 1 and dial 17070. this will BT autotest the line. if more than 1 line on system do same for all lines. check with your system admin if there are quick codes to select individual lines, eg dial 9 for any line or 81 for line 1 82 for line 2 etc .
if you get crackle still on 1 of the lines get your maintainer to check the lione at the cable head where lines enter building
Mar 02, 2015 | Panasonic KX-T7731 Corded Phone
Check line cord phone mean
The cord or cable connecting the phone to your pstn line is called line cord. check the connection at the back of phone and the wall jack. if it is ok change the cord and check.
Jul 20, 2013 | British Telecom Synergy 2110 Cordless...
Clock readout indicates power, but nothing else working
In most cases it can be traced to the audio output ic as the problem, because part of the B+ is fed back in the radio. There is a remote chance a fuse has blown located near the ic.
Feb 25, 2012 | Memorex CD Boombox, MP3126PUR Boombox
What is wrong when the phone says Check tel line?
The telephone cord may not be connected correctly.
  1. Unplug both ends of the cord connecting the wall jack to the telephone base.
  2. Insert one end of the cord to the TEL LINE jack on the base.
  3. Make sure that the cord is inserted correctly in the TEL LINE jack on the phone.
  4. When you insert the cord you should hear a click.
  5. Insert the other end of the cord to the wall jack.
  6. Make sure cord is inserted correctly.
  7. You should hear a click.
Feb 02, 2010 | Uniden DECT 6.0 Cordless Phone ID
We are getting a message on the led readout on our phone that syas replace SysBatW/Power. What do we do?
Go to the phone system. There will be a processor card, that will say Partner ACS. On the bottom of that card is a small battery compartment that holds 2 AAA batteries. Change those with the power on, or you will lose the programming.
Nov 04, 2009 | Lucent PARTNER18 Corded Phone
2 line phone rca 25205re1 only 1 line works not the rollover line
Most likely the problem is the cord from the wall to the phone. There are two types of cords and they look almost identical. Look closely at the connector. A single-line cord will have only two gold pin at each end. A two-line cord will have four gold pins at each end.
You need a two-line cord to get both lines from the wall to your phone. Since you have had the problem with several phones, that is the most likely cause.
Jan 14, 2009 | RCA 25205RE1 Phone
RNGOFF KX-T7630
press the button below the readout "rngoff", let go, then rotate the volume control dial. It should raise the volume. The readout will now say "ring"
Jan 11, 2008 | Panasonic KX-T7630 Corded Phone
Aastra Telecom Aastra 9316 CW Corded Phone Logo
141 people viewed this question
Top Aastra Telecom Lands Phones Experts
Marvin
Marvin
k24674
Are you an Aastra Telecom Lands Phone Expert? Answer questions, earn points and help others
