Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Posted on Feb 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does LT mean on a washer - Whirlpool Cabrio WTW6600SBT Top Load Washer
  • Karisa Arb
    Karisa Arb Apr 28, 2016
    Did u figure out what Lt means? Mines says that too
  • Anonymous Mar 25, 2018
    So far, no one seems to know what an LT code is and they are even denying it happens. I clearly see an L and a lower case t. And, my Whirlpool Cabrio starts right back up into another cycle after roughly 5 minutes of this code displaying when the machine has completed its prior cycle. If I'm not careful, the washer will run all day on the same load.
    Anyone have any ideas?
Anonymous
Level 3:
  • Master 15,935 Answers
  • Posted on Feb 04, 2011
Anonymous
Master
Level 3:
Answers
15935
Questions
19
Helped
5036578
Points
35540
LT is not an error.
Perhaps LF?
CLICK HERE for the error code list.
Thanks!!
  • Pablo Flores Garc?a
    Pablo Flores Garc?a Jan 11, 2014
    I get the same Lt code when mashine stops and if I'm not near to hit stop or open lid it starts sicle again.
  • Samantha Edwards
    Samantha Edwards Jun 26, 2017
    Mine is doing the same thing.
Samantha Edwards
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 26, 2017
Samantha Edwards
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1836
Points
What is Inlet valve part number?
Do you mean the Admiral top-load washer ATW4475XQ0? If so, the inlet valve is part 18 on the Controls and Rear Panel diagram here: https://www.searspartsdirect.com/model/2d42bqbzai-001810/admiral-atw4475xq0-washer-parts . The original part number was W10311458 . The current replacement is WPW10144820 and is <$90 from this vendor.
I hope this helps.
tip
Sony Ericsson Secret Code
<span><br />IMEI number: * # 0 6 #<br /><br />Software version: &gt; * &lt; &lt; * &lt; *<br /><br />Default Language: &lt; 0 0 0 0 &gt;<br /><br />Enter to phone menu without SimCard - after Wrong PIN: press NO: * * 0 4 * 0 0 0 0 * 0 0 0 0 * 0 0 0 0 #<br /><br />Information about SIMLOCK: &lt; * * &lt;<br /><br />Sony Ericsson Secret Menu: -&gt; * &lt;- &lt;- * &lt;- *<br /><br />(-&gt; means press joystick, arrow keys or jogdial to the right and &lt;- means left.)<br /><br />You'll see phone model, software info, IMEI, configuration info, sim lock status, REAL time clock, total call time and text labels.<br /><br />You can also test your phones services and hardware from this menu (main display, camera, LED/illumination, Flash LED, keyboard, earphone, speaker, microphone, radio and ******** tests)<br /><br />IMEI Number: *#06#<br /><br />Lockstatus: &lt;- * * &lt;-<br /><br />Shortcut to last dialed numbers: 0#<br /><br />Shortcut to sim numbers: On main menu type a number and press #<br /><br />If you change the language from default to any other language, then it may be difficult to switch to default language. The shortcut is very simple. Just press &lt; 0000 &gt; . &lt; stands for left arrow button or joystick and &gt; stands for right arrow button or joystick.<br /><br />note! Try these codes at your own risk! We don't accept any complaints. Some of these codes may not work in your mobiles.</span>
on Jul 11, 2011 • Cell Phones
2answers
Zanussi washer zwh8 100se. Message EH0 and E40?
Zanussi Washing Machine Error Code = E40
?Error Code Definition = The washer door is either open or not properly closed.?
What To Check or Repair = Check that the door is completely closed. Check that nothing is blocking the door from closing.
Zanussi Washing Machine Error Code = EH0?
Error Code Definition = The electrical supply is not stable. Wait until the mains supply is stable.?
What To Check or Repair = Check electrical circuit breaker. Unplug the washer for 10 minutes to reset.
3.7l V6. What do DTCs P0201 and P0301 indicate?
RTM
https://eautorepair.net/Marketing/Default.asp
the jeep manual (USA)? is 100% accurate on this.
301 is federal USA code for #1 cylinder misfire.
means actually weak COMBUSTION #1
fuel weak or spark week , both or far worse (burned valves)
next comes where is #1 well on any V6/v8 it is the farthest front cylinder #1 (SEEN FROM ABOVE) AND FRONT MEANS CAM DRIVE END OF ENGINE.)<< MY RULES. FWD/RWD SAME.
201 means
iNJECTOR #1 IS FAILING SEEMS THIS WINS AS MUST IF THIS FAILS.
buy a new injector,.
bad wiring to same
or bad PCM. <<< 99.% not true. as in rare. but is logically correct and electrically correct to be in the list.
1helpful
My cabrio whirlpool washer automatically restart new wash
Well, is it LT, or LF? They mean completely different things.
Idk wat the symol <:L>
In HTML (2.0) < means "less-than sign"
> means "greater-than sign" >
I would expect L> to render as; L>
As far as I know there is no specific L> symbol.
Washing machine won't drain. What does the hour glass symbol mean. It is defined in the owner's manual
From <http://support-us.samsung.com/cyber/popup/iframe/pop_troubleshooting_fr.jsp?idx=419733&modelname=WF409ANW&modelcode=&session_id=V5mMmkpq72BqyQB5Lny5vwblqvWTyT6hLbGQypLMbhMpMhlQBdfJ!-943087853!1669102353!1442424460210&from_osc=&homeid=2217>: "The hour glass is displayed to let you know the washer's timer is counting down. This is normal, and does not require service."
Audio on some TV channels/shows goes off. It varies by channel, sometimes national feed is silent, but local break-ins have sound. I have to set the Audio from A.F.D. to Movie to get audio. Sometimes I...
Not sure what this means: "The audio comes to the Cable box through coax cable." From where does audio come TO the cable box? The cable box is a source of both audio and video. Perhaps you mean the TV broadcast "containing the audio and video" comes in on coax.
Has this ever worked correctly? <<<<<<<<<<<<<<<<<<<<<<<<
Try this: disconnect the HDMI that goes from the cable box to the Video 2 on the receiver. Leave the optical audio cable in. How's the audio now?
Then try the reverse: reconnect the HDMI and disconnect the optical audio. You shouldn't need BOTH for audio into the receiver.
Now what happens?
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
