Canon imageRUNNER 2200 Logo
Posted on Feb 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Inherited this 2200 w/ new political office. Was working fine and making clear copies - then error code E000000-0000. Restarted machine - tried Press * Press 2 Press 8 Press * - got nothing. Help.
Nikolay Boychev
Level 3:
  • Canon Master 525 Answers
  • Posted on Feb 04, 2011
Nikolay Boychev
Canon Master
Level 3:
Answers
525
Questions
Helped
315145
Points
1297
E000
Indicates either of the following: the main thermistor (TH1) has poor contact
or an open circuit; the thermal switch (TP1) has an open circuit; the
main/sub heater has an open circuit; the main power supply PCB is faulty;
the DC controller PCB is fatly; the door switch is faulty.
In the case of E000 through E003, the code will not be reset when the main
power switch is turned off, requiring the use of service mode
(COPIER>FUNCTION>CLEAR>ERROR).
However, if E001 or E003 is detected within 3 sec after the front door
switch is identified to have been opened or closed, the code will be reset
when the main power switch is turned off and then on. This consideration is
to prevent a service call in response to an error detected when the switch
operation is not fully stable (as immediately after turning off and then on
the main power switch).
How can solve the error E002 - 0000 in canon 2204
Please follow below link or instructions to resolve this
https://www.youtube.com/watch?v=xm6oU-h7mYc
or
Canon imageRUNNER 2200, 2800 Reset Fuser Error Code Want to know how to clear the E000, E001, E002, E003, E007 messages on your Canon imageRUNNER 2200, 2800 series machines. Below is the instructions to for the 2200, 2800 reset fuser error code procedure.
For safety reasons lots of copiers and printers turn off AC power to the fusing unit when temperature errors occur. This allows for a service technician to come in and evaluate the machine before it is turned back on. The fuser heats up to to 350 and 425 decrees. Due to the nature of the high heat is why these parts are shut off. No manufacture wants to be blamed for their machine burning down a company. It sounds scarier than what it is. These machines have multiple safety features to keep this from happening. The reset feature is just one safety feature found in the machine
The E000, E001, E002, E003, E007 are all related to high or low temperature readings and the 7 is due to fixing film rotation issue. Below is the procedure to reset these errors. Occasionally, the fuser will run too hot or cool. Sometimes, this is a freak occurrence like when the power flickers on and off or just a faulty reading. Whatever the case, the first thing a tech usually tries is to reset the error and see what happens.
1. If the machine turns back on and starts making copies then you inspect the fuser for possible problems and wear and tear. If it checks out then you let it go and see if it comes back.
2. If the error comes back right away then you know you have a more serious problem and it's time to find out what needs cleaned or replaced.
Service Mode Entry
1. Press the User Mode key. (Looks like a little man head. Some people call it the function or additional function key.)
2. Press 2 and 8 on the keypad at the same time.
3. Press the User Mode key on the control panel.
If done correctly the display will read
COPIER
FEEDER
SORTER
FAX
BOARD
Press the Copier Icon
Press the Function Icon
Press the Clear Icon
Press the Err Icon
To exit service mode : Press the Reset key twice to end service mode and return to the User screen
Thanks.
HOW TO CLEAR ERROR CODE E000002-0000 IN CANNON IR3300/2200
http://www.copytechnet.com/forums/canon/24451-canon-ir3300-error-e000002-0000-a.html
Thread Canon IR3300 Error E000002 0000
Quoting:
wilson Technician Join Date Feb 2009 Location PASIR MAS , KELANTAN
what you need to do is just resetting your machine.
1. Press * 28 * on your machine in a quick move.
2. Select copier
3. Select Err.
4. Select Clear then press O.K
5. Turn your machine off for 1 minute and turn it on again.
The error code will not be there anatmoreand your machine will be functioning well.
1helpful
2answers
How to reset canon ir 2204 error e000-0000
or
Service Mode Entry
COPIER
FEEDER
SORTER
FAX
BOARD
Press the Err Icon
Photocopy IR2230 error code 0001/0002
First clear that error from service mode. Press additional function
press 2 and 8 together
press additional function agian
service mode should appear in screen
select copier
select function
select "clear"
select "err"
select ok.
unplug power cord for a few seconds and restart the machine
try to make some copies if problem persist replace the fixing heater assembly
Cannon image runner 2525 error code E0000002
on the control panel press:
aditional function
aditional function
should appear ins screen "#sssw"
search with the left arrow until "CLEAR" appear on screen
press ok
search with the left arrow until "ENGINE" appear on screen
press ok
the screen displays: ERRCLR press ok again
turn off the machine from the main switch (located on the left side of the machine) for 5 seconds
turn back on the machine and try to make some copies
if problem persist replace fixing film assembly
4helpful
The copier stopped working and Error code E000003-0000 came up. I've shut the machine down and restarted, but error code still comes up.
switch on the machine, press *(additional function) 2and8 together and again *, on screen select copier>function>clear>error>ok. switch off the machine and restart.still problem appears then check fuser unit.
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
Error 2200 on Dell all in one Photo 944
Honestly if dell told you to get a new one then that is what you should do.
What is error 2200?
i had error 2200 on my X7170 lexmark....i turned it off.uninstalled the lexmark software in uninstall/add programs in the control panel.restarted my computer.installed the software again....then worked like a charm....hope it works...peace.
old marine
old marine
ZJ Limited
ZJ Limited
