Canon imageRUNNER C3200 Copier Logo
Posted on Feb 03, 2011
Problem with the Canon imageRUNNER C3200 Copier In printing colors are 1 mm apart from each to other
3 Related Answers
Anonymous
  • 76 Answers
  • Posted on Dec 09, 2008
SOURCE: Canon C3200 imagerunner
go to service mode By pressing * 28 * and you will see a menu COPIER then MISC
Anonymous
  • 118 Answers
  • Posted on Jul 15, 2009
SOURCE: I have a Canon Color Imagerunner C3220 copier.
the uneven pressure of the fuser rollers cause this problem ,roller ball bearings needs change ,temporary solution try to add a little pressure on the roller by tightening the adjusting screw both rear and front (underneath the yellow cover)
dann jackson
  • 78 Answers
  • Posted on Nov 10, 2009
SOURCE: problem on Canon imageRUNNER C3200 Copier Error
replace black drum it is reaching the end of its life also make sure your machine has the latest software version as drums will last longer if it has have seen drums reach 700-800%
In printing colors are 1 mm apart from each other
www.blueridgecopier.com/...Manuals/.../Color%20imageRUNNER%20C3200%20Reference%20Guide.pdf
Above is your user manual, below is a pay for service manual, a sort of must have to get any chance of a repair, really. http://www.tradebit.com/tagworld.php/copier+service+manual
Below is a free generic, service manual for your series of printer, this will help address your issue. http://printer1.blogspot.com/2009/01/canon-ir-2200-service-manual.html
Connect device to laptop
you need to be able to configure your lap printing drivers to print to the ip adress of the copier.... does the copier have a rip or is it stand alone
ImagePass-C1 Not Printing the Pantone Colors
you need a set of kodak cards to run full colour set up on your fiery print controller then you just follow the intructions
1helpful
Printing double sided color copies.
CHANGE YOUR DUPLEX PAPER SELECTION MOTOR
Canon ImageRunner 3200
there are several steps before reaching the laser i-- clear dc con then take machine off remove plug from outlet then power up machine 2--clean the itb assembly thoroughly 3---change the transfer belt 4 --- change the itb assy. if nothing works then we will go to the laser
C3200 COLOR PROBLEM
3 possibility 1-your secondary transfer is dirty or needs changing 2- your primary transfer sheed is damage or your fixing assy. is damage go with number 1 first try cleaning with a clean dry rag then blow away any lint. for service mode press and hold additional function at same time hold down 2 and 8 then add function again
2answers
Error Code
Called local service technician.
old marine
old marine
ZJ Limited
ZJ Limited
