Question about Hardware & Accessories
I have the imm24 timer and would like a better quality timer which one will work
Posted by info16655 on
Anonymous
Imm24 timer is 230V 3500amp flush-mount hard-wire 24-hour mechanical-dial immersion heater timer
Following page shows imm24 timer and other brands of immersion timers
http://cpc.farnell.com/1/1/51662-immersion-heater-controller-box-imm24-apt.html
Prices are in Euros and Pounds, so I don't know distribution range of product.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 05, 2011
The timer on my 8100-0600-01 Malibu light transform is not working the on and test part work but I want to set the time on
The electronic dawn dust timers can fail easily in power surge etc.
Manuals, tips and troubleshoot resources on following link:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
I recommend professional grade transformer for anybody wanting better quality and resistance to problems:
http://waterheatertimer.org/Kichler-transformers-and-manuals.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 07, 2017 | Malibu Hardware & Accessories
Timer has no power..but circuit works when operated manually on on t101R
replace it, when the clock motor goes bad you are better off just replacing it cuz usually everything else is ready to go bad for lack of a better way to put it. Wiring Diagrams go here and look for timers u would want. I would personally go with the same thing or something real close. just make sure the timer fits all the parameters. Search here is the specific wiring diagram for ur model. need more help give me a holler
Jun 04, 2016 | Hardware & Accessories
Instructions
Check wiring:
http://waterheatertimer.org/Aube-timers.html
Add a comment and describe the timer you have, and include if this is new timer, or timer that stopped working.
Also add if you are connecting for single pole or 3-way.
Be aware that some aube timers are not compatible with CFL, and work with incandescent only, and require minimum load wattage.
Better choice is ST01C timer
http://waterheatertimer.org/ST01C-program.html
May 08, 2013 | Aube Technologies Aube 7-Day Programmable...
Every time I have a power failure, the timer stops working and I have to reset all the programs. I thought there is a battery built in to protect the programs during power failure. Why it is not working in...
Timer is not identified.
Copy following link to help identify timer
http://waterheatertimer.org/Woods-timers-and-manuals.html
Most modern digital timers have programming back-up that lasts indefinitely in memory until timer is reset.
However current time is sometimes lost with low battery or power outage.
In some timers there is rechargeable battery that protects all settings. This battery is non-replaceable, and can last a few years or more-less.
Since the market is changing rapidly, who knows what remarkable innovation will lessen quality, causing shorter lifespan of product.
Most timers have limited 1 year warranty against defects in workmanship.
Nov 24, 2012 | Hardware & Accessories
Give me properly installation of stand alone dvr with computer all window how sport the dvr send me properly anstallation of standalone dvr
Take one co-axial cable, and connect the "input" port to your cable-company's wall-port.
Look at the connectors on the back of your TV. You could have:
* coaxial input (lowest video-quality)
* S-Video input (better video-quality)
* component input - three cables for video, two cables for audio (better video-quality)
* HDMI input (highest video-quality)
Look at the connectors on the "output" side of the PVR. You could have:
* coaxial output (lowest video-quality)
* S-Video output (better video-quality)
* component output - three cables for video, two cables for audio (better video-quality)
* HDMI output (highest video-quality)
Connect the "outputs" to the "inputs", using appropriate cables.
Turn the PVR on. Turn the TV on.
Use the "source" button on the TV's remote-control to select from the various inputs
(Coax, S-Video, Component, HDMI1, HDMI2).
If your TV has 'PIP' ("Picture-In-Picture") capability, connect more than one output to a second input, so that both tuners inside your TV will receive a signal.
Feb 03, 2011 | Computers & Internet
Copy density is very poor.what is potential control? it should be on or off?
Hello kard,
You have asked a very BROAD question. When your copier is in proper condition (well maintained by servicing) potential control should absolutely remain on. It is the internal system that monitors everything concerning copy quality and attempts to compensate for age of components,dirt, and enviromental conditions that change. Potential control sets a target for optimum copy quality and then automatically adjusts many components in an attempt to reach this target. There are however times where turning potential control off can be helpful. But only when you are troubleshooting a problem or are masking a problem. It can be a temporary fix. But your copier was designed to actively deal with variables that can cause copy quality problrms by using potential control. If you disable it, even if the copy quality gets better, you are limiting its ability to compensate and are truly setting a timer for a service call. I hope this answers your question. Take care. :-)
Jan 22, 2011 | Canon imageRUNNER 5000 Copier
I lost the instructions on how to set the timer where can I find the instructions for Stanley 31200 TimerMax Indoor Weekly Digital Timer White
Check following page to identify timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-week
Without guarantee, I believe Westinghouse 228442 manual also applies to Stanley 31200
http://waterheatertimer.org/pdf/28442_TimerManualEn&Fr.pdf
If this is correct manual, then add a comment and help fixya community continue supplying quality information free of charge.
If this manual varies from your timer, then add a comment and say how it is different.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 04, 2011 | Stanley 31200 TimerMax Indoor Weekly...
JVC AV48WP74 Service mode
Press SLEEP TIMER and, while the indication of (SLEEP TIMER 0 MIN) is being displayed.
press DISPLAY and VIDEO STATUS on the RC simultaneously. Exit: EXIT.
Jul 04, 2009 | JVC AV-48WP74 48" Rear Projection...
Hardware & Accessories Logo
451 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
