SOURCE: XMicro Wifi USB Problem
hi you will need the right drivers try this link look for your model number on back http://www.x-micro.com/main-support_download.html
SOURCE: Netgear Wireless USB Adapter wg111t; installation
need help to install the product to my computer
SOURCE: Need working Windows 7 driver for Linksys WUSB54G V.1.0 Adapter
This driver should work with Vista, and based on the FAQ it should work with 64-bit although it wasn't designed for the 64-bit OS.
http://downloads.linksysbycisco.com/downloads/WUSB54G_dr,0.exe
If the link doesn't work, let me know. I'll direct you to the download page to retrieve the driver.
SOURCE: after install of driver into windows, xp doesnt
Hi, please check the status of the adapter using the steps below:
1. Click Start and go to 'control panel'.
2. Double click on 'system'.
3. Click on 'hardware'.
4. Click 'Device manager' button.
5. Under 'Network Adapters' you will find the name of Netgear adapter.
Check if it shows installed properly or shows with an error code.
You may try installing the adapter on another machine to isolate the issue further.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
SOURCE: Belkin Wireless USB Adapter not detected!
This device is well known for the high level of current draw that it requires in order to work. I would suggest that you remove all other unnecessary USB devices and try the device again. It is more than likely that your system will find the device.
The quickest way of ensuring continued usage, when you have numerous USB devices, is to purchased a powered USB hub and ensure that the Wireless adapter is connected to one of the powered USB ports on the hub.
Hope that helps.
If the resource CD does not work then I would recommend you to download the installation software for the adapter from the below link:
http://kb.netgear.com/app/answers/detail/a_id/17393
Install the adapter using the software available on the link above.
Regards
Anand
