Question about Panasonic Panafax UF-585 Plain Paper Laser Fax
Can you add a new fax no that shows in the header for outgoing fax?
Posted by peter_gustaf on
Creative Tech
  • 1,719 Answers
To set Outgoing Fax Number/ ID follow the follwing steps: -
- Press FUNCTION, Press 7 (Set mode will appear on display)
- Press 1 (User Parameters Settings)
- Press Set repeatedly until display shows ID
- Enter your Number/ ID (max. 20 digits) by using the key pad
For further information you may refer to User Manual for Panasonic Panafax UF-585 Page 29
Hope it helps! Good Luck!
CreativeTECH
Posted on Feb 03, 2011
We have a FAX-2820. this is a dumb question, but does the fax header line come from the sender when we are receiving the fax? Does a header go out on any fax we would send out?
Yes, The fax header should show you who sent the fax to you. Every fax is supposed to have a terminal ID (senders fax number and Name)
Andrew
Sep 22, 2011 | Brother IntelliFax-2820 Laser Fax
How do I change the name and fax number on the top of my outgoing faxes
The software that came with the printer will have a "setup" or "settings" icon. You can change it there.
If you can't find it or never installed it you can delete the printer software and re-install it and you can start from scratch with the new information you want.
Jan 27, 2011 | HP OfficeJet 6110 All-In-One InkJet...
I need to change the name on outgoing faxes from my HP 6310 Officejet, but cannot find the information in the owner's manual. Can you help?
This "Fax header" information can be changed on the OfficeJet 6310 control panel:
1) Press the <Setup> button
2) Press 4, then press 1
3) Enter your personal or company name
4) Enter your fax number
You may have to use the numeric keypad to enter letters. The number of presses of the key changes the letter.
I hope this helps!
Mar 10, 2010 | HP OfficeJet 6310 All-in-One Printer...
How do you set/change the outgoing phone number on an HP Officejet 6110?
Hit setup. Arrow to fax setup (4). Hit ok.
Arrow to fax header, hit ok. Enter name, ok. THAT should bring you to the phone number.
Jul 17, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Error 20 01 NG: poor line condition on outgoing fax's
My fax shows poor line condition. I have checked all of the connections and everything is ok. Perhaps my settings are wrong
Jan 23, 2009 | Brother IntelliFAX 4100 Laser Fax
Incorrect Fax Number showing on sent Faxes
the solution given is correct. happy faxing OMNIPRESENT
Oct 01, 2007 | HP LaserJet 3050 All-In-One Printer
Panasonic Panafax UF-585 Plain Paper Laser Fax Logo
141 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
