Question about Cisco Aironet® 1242AG (AIR-AP1242AG-N-K9) 802.11a/b/g Wireless Access Point
Problem with the Cisco Aironet 1242AG Wireless Access Point , very low signal strength
Posted by it14935 on
Dennis E. Mungai, Lin Jr.
    Scholar:
  • 69 Answers
Please ensure that:
1.The wireless access point is not in close proximity to a source of interference,e.g a microwave transmitter or microwave oven. 2.Ensure that it's not placed in an area prone to physical obstruction, e.g behind a high wall or where people pass through(because our bodies have water which absorbs such waves!).In that case, re-position the wireless access point to another area, e.g a roof top. 3. If the wireless access point is in vicinity of other wireless access point, ensure that CSMA (Collision Sense Multiple Avoidance) scheme is enabled for the device.
I hope these solutions solve your problem. Have a great time ahead.
Posted on Feb 03, 2011
Can get router to work
The Cisco Aironet 1200 access point provides secure wireless connection to your network. Cisco's wireless access design meet the needs of a small to medium size business.
This unit provides secure network access for laptops or Wi-Fi capable portable devices, which you upgrade at any time as your business grows.
A beneficial feature of the Cisco Aironet 1200 is its ability for the administrator to reset the access point remotely.
This resetting process works through your internet browser.
Log on to the System Configuration page by entering your Cisco Airnet 1200 IP address in your browsers web address text box.
Enter your user and password information from the pop up menu.
Click on the "Setup" button from the summary status page.
Select the "Cisco Services" setup option and click on "Manage System Configuration."
Click on "Reset All System Factory Defaults" to reset the router.
The Cisco Aironet 1200 will be restored to factory defaults.
http://www.cisco.com/en/US/products/hw/wireless/ps430/index.htmlCisco Aironet 1200 Series
Configaration Cisco Aironet 1200 Serieshttp://www.cisco.com/en/US/docs/wireless/access_point/1200/vxworks/configuration/guide/bkscgc10.html - wp1016665
May 07, 2014 | Linksys Cisco Aironet 1200 Wireless Access...
IP address Cisco AIR-AP1242AG-E-K9
You want to know what the IP address of your access point? It was probably set dynamically, so we can't tell you.
Apr 02, 2014 | Cisco Aironet 1242AG (AIR-AP1242AG-E-K9)...
How to configure wireless router
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jul 21, 2011 | Cisco Aironet® 1242AG (AIR-AP1242AG-N-K9)...
I cannot find the default ip address for Cisco AIR-AP1242AG-E-K9. can anyone help?
Hi, The Access Point does NOT have a default ip address
below is quick setup guide to the Access Point
http://www.cisco.com/en/US/docs/wireless/access_point/1240/quick/guide/ap1240qs.html#wp41082
May 30, 2011 | Cisco Aironet 1242AG (AIR-AP1242AG-E-K9)...
There is issue of low signal strength showing in Cisco Aironet 1131. how to resolve it?
Signal strength can have a lot to do with where the router is compaired to where you sit at your pc/ laptop. If you have a house with thick walls you should go for a N type router rather than the G (standard router type). but a simple way to boost signal is to put a pice of tinfoil behind the anntenae of the router, directing the signal to where your computer is and not letting it just dissipate into the walls of the house in all directions.
hope this helps, but remessage if I have not been clear enough ;)
Oct 07, 2010 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
How can I change the default management vlan (vlan 1) to another vlan # in Cisco Aironet 1242G wireless AP
create a new vlan (eg vlan 10)
then ensure that the ethernet port is the same bridge group number as the new vlan (bridge-group 10)
do the same for the wireless port
then shut down vlan 1
Oct 06, 2009 | Cisco Aironet 1242ag 802.11a/b/g Wireless...
Hai
May be correct will be Hi!
Jan 10, 2009 | Cisco Aironet 1242ag 802.11a/b/g Wireless...
Cisco 1242ag broadcast multi SSID issue
It stops broadcasting the SSID? Make sure it's configured to broadcast the SSID firstly... secondly, test whether it is actually working but just not broadcasting the SSID.
Set a client PC to the same SSID and get all the parameters identical (encryption, user/pass etc). Try connecting again. If it connects then it's just the SSID that isn't working... if there is no joy, then it is just the SSID that isn't broadcasting, not the whole AP.
Also, enable some debugging for the radio0 while it is not working. It might shed some light.
Feb 05, 2008 | Cisco Aironet 1242ag 802.11a/b/g Wireless...
Cisco Aironet® 1242AG (AIR-AP1242AG-N-K9) 802.11a/b/g Wireless Access Point Logo
435 people viewed this question
Top Cisco Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Mike
Jax Planet
Jax Planet
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
