Question about Lenovo ThinkPad Computers & Internet
I have a Lenovo SL300 laptop (original windows vista, but i installed windows 7 professional w/ license). My bluetooth connection is no longer working and i cannot find the bluetooth device on the laptop. then there is a problem with microsoft isatap adapters 2 & 3, microsoft teredo tunneling adapter. Then another thing is that it says that the laptop has a power management system problem. Can anybody help me with this? Thanks and hoping for a prompt response on my concern.
Posted by amlv_mart on
Larry Ng
  • Lenovo Master
  • 5,969 Answers
I moved you from HP to Lenovo
HP can not help you,
the error you made is not asking Lenovo if they even support W7
on this L300.
why ask here at all, and not the makers web forum.?
your drivers for key chips is now missing or wrong.
with any XP or VISTA puter
ask the maker how to upgrade first, is best.
some cant.
some cant because some chips do not have w7 on up drivers at all
one cant just demand something that does not exist.
not saying that is the case, just telling you to ask next time
here
https://forums.lenovo.com/t5/ThinkPad-L-R-and-SL-series/SL300-VGA-Controller-Driver-Problem/td-p/122631
Posted on Jun 04, 2017
Mohammed Jamal
    Master:
  • 126 Answers
5 Related Answers
shaggyrat
Christophe Thompson
  • 1224 Answers
SOURCE: Re-install microsoft isatap adapter
reinstall windows vista and when it comes to a screen that says repair new os or boot you want to hit repair this will initialize vista program to install back in what has been taken out and go threw instructions and follow them till completly done
Posted on Jun 01, 2008
Anonymous
  • 86 Answers
SOURCE: EXCLAMATION MARK IN THE DEVICE MANAGER
Regarding the Microsoft ISATAP Adapter error, you can ignore it safely. Please refer to the following link:
On a Windows Vista-based computer or on a Windows Server 2008-based computer, the Microsoft ISATAP adapter appears with a yellow exclamation mark next to it in Device Manager, and you also receive an error message
http://support.microsoft.com/kb/932520/en-us
Posted on Dec 08, 2008
Anonymous
  • 788 Answers
SOURCE: microsoft ISATAP adapter #2
Disconnect your device and any other external devices.
Re-boot the machine in safe mode and check the device manager for flags.
If you see other devices or flags, red or yellow, remove them.
Re-boot the 6000 and allow unit to run a normal boot.
Check device manager again for flags.
If you are running VISTA, type msconfig at search and in center of page, look for add or remove programs. Highlight and hit the lunch button.
Find your TV tuner program and remove it.
Close out the utility and reboot the system.
Check your device manager again for flags.
If OK re-install hardware and drivers.
Reload the program. If you still have problems, check microsoft for updates under drivers
Posted on Aug 28, 2009
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: I saw a yellow exclamation mark on the Microsoft
Re-install the wireless card driver.
You can download any/all the Windows XP or Vista device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Use this link: -
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Posted on Dec 02, 2009
Anonymous
  • 83 Answers
SOURCE: hello, i have a hp notebook which code 31 error on
Microsoft says to Ignore the problem, and the adapter will continue to work correctly. If the message is really annoying maybe you can try turning off IPv6.
Control Panel\Network and Internet\Network Connections
right click your network card>properties
uncheck the IPv6 box
that'll turn off IPv6-then just disable the adapter driver
Posted on Feb 24, 2010
This is a question and answer session to all
Good luck with that, windows 7 is better than vista.
Dec 28, 2015 | Lenovo 3000 Y410 Laptop
I want to save intallation and install it to another computer
If you still have youir Vista license key and it is retail (not OEM), then you will be able to transfer your installation intact. Use windows vista system (not file) backup to a portable HDD. Also make a rescue disk. Then boot to the rescue disk on the other computer and follow the prompts to recover the main backup you made. You will need your license key to activate the new Vista. You may need to tell Microsoft that your old computer is no longer working to transfer the license. If the old license was OEM, you can't move the license (it is for the life of the original computer/motherboard only), and you will have to buy a Windows 8.1 pro license and migrate your data instead. I have done that from windows Vista 32 bit to Windows 7 64 bit. I used all different types of backups (including Mig, vista file backups, copy my whole profile) and carefully put it all back together. Let me know if you want more help with anything specific.
Jan 14, 2014 | Microsoft Windows Vista Ultimate Edition
Bluetooth peripheral for windows 7 not installed
check device manager if there are drivers that were not properly installed, usually with (!) symbols or reinstall drivers using vista drivers.
http://support.lenovo.com/en_US/detail.page?LegacyDocID=migr-63572
navigate down to the modem/bluetooth drivers, try to use VISTA drivers.
Mar 31, 2013 | Lenovo 3000 N100 Notebook
Downgrade windows 7 to windows vista
Pl note that only Windows 7 Ultimate or Professional supports downgrade rights to Windows Vista Ultimate, Business or Windows XP Professional.
You can do a downgrade as long as you have a full version Windows Vista license.
If you are referring to Windows 7 downgrade rights, this option is specific to the manufacturer, computer model and the edition of Windows 7 you have installed.
Jul 18, 2012 | HP Computers & Internet
Lenovo Thinkpad T500 windows not genuine
You should just contact Microsoft and tell them what happened. They should help you out.
Jun 12, 2012 | Lenovo ThinkPad T500 Notebook
I have installed windows 7 in lenovo 3000 series Y 410 7757-92Q laptop but my blue tooth is not working . i want driver for that which is Compatible.
Hi shaunak198.
I have checked all the information online.
According to the information online, the Bluetooth Driver for the Windows 7 Operating System has not been released.
However, let me provide you the alternate options to resolve the issue.
1) You may first download the Windows Vista Bluetooth Driver from the below link:
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles/l2bth01us24.exe
2) Then, download the Universal Extractor Application from the below link:
http://www.filehippo.com/download_universal_extractor/download/1b5e29e6ef4b7345359a86bed150d4fd/
3) Once you have downloaded the Universal Extractor Application, please install it by following the on-screen instructions.
4) Once the Application is installed successfully, please locate the Downloaded Bluetooth Driver.
5) Right-click on the downloaded Driver and select the "Uni-extract Files" option.
6) Then, press "OK".
7) This will extract the files inside the .exe Installer.
8) Once the extract is complete, please look for another Setup(.exe) file inside the extracted folder.
9) Double-click on the Setup file and follow the on-screen instructions to install the Driver.
10) As we have extracted the Files before installing, the Bluetooth Driver should be installed successfully.
Please follow the steps which I have mentioned above.
This should resolve the issue.
Hope this helps.
Please feel free to ask further questions.
Aug 20, 2010 | Lenovo 3000 Y410 Laptop
Bluetooth not working with windows 7
hi rlgupta2006, the reason being is that our bluetooth drivers were designed for windows vista and xp. You can try this link for higher Y series versions so that the bluetooth would work on windows 7.
click this link:
consumersupport.lenovo.com/us/en/DriversDownloads/drivers_show_2002.html
download the software and click I agree in the license agreement.
Hope this help...
Apr 28, 2010 | Lenovo 3000 Y410 Laptop
Bluetooth problem in lenovo 3000 G430 laptop
i am using lenovo 3000 g430, and i am fall in problem about bluetooth,
i am already install xp and vista, but when i install the bluetooth driver
one warning message show me "bluetooth device not detected"
my bluetooth device switch is on but indicator led light still off,
please help me , how can i use bluetooth in this laptop.
Dec 13, 2009 | Lenovo 3000 Y410 Notebook
My lenovo brand laptap needs bluetooth peripheral device to be install
You can download the drivers from Lenovo support site. Just check the back of your notebook for the serial number. Lenovo support downloads ask for that. Then, get the drivers. Turn on the bluetooth first.
Download the XP drivers for Windows XP. For Windows Vista and Windows 7, download the Vista drivers. Be sure to install the Chipset drivers first and then the sound drivers. Only then can you install bluetooth drivers properly.
Oct 22, 2009 | Lenovo 3000 Y410 Laptop
Bluetooth not working after OS re-install on Lenovo 3000 Y500 lap
if you install xp then find out the xp drivers in www.lenovo.com > select country > support and downloads > model number> etc. After downloading file >install the driver > after installation reboot your computer > after machin on you just switch on the wifi or bluetooth switch (near you laptop hinzes) and try it.
Mar 17, 2009 | Lenovo 3000 Y410 Notebook
Computers & Internet Logo
102 people viewed this question
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
