Question about HP LaserJet P3005n Printer
Hp laserjet p3005 freezing at times ,at times erroe49.4c02 pops
Posted by tmbizi71 on
Stuart Smith
  • 152 Answers
Hello, 49 errors can indicate a hardware or application error.
The formatters in the P3005 series have been plauged with problems, freezing being one of them.
For more on 49 errors follow the posted link.
Support 49 Errors CLICKHERE
Posted on Mar 05, 2011
I can not power on my hp laserjet p3005 printer
Try plug the powercord in different outlet.
No luck ? Your powersupply i probably defect and needs to be replaced. Contact your local HP repair-shop and have them repairing your product.
Feb 03, 2014 | HP LaserJet P3005 Printer
How to connect hp laserjet p3005 to a network or wifi
Follow this link ,may be it will help you....http://www.hp.com/global/us/en/wireless/printer-setup-help.html
Feb 06, 2013 | HP LaserJet P3005 Printer
Where can I download the latest Firmware upgrade for the HP LaserJet P3005 printer. I am unable to locate it on the HP site
Doesn't look like there is any firmware updates it would be posted on the site you could check if HP Easy Printer Care Software has any options for firmware upgrades.
Mar 18, 2011 | HP LaserJet P3005 Printer
Printer freezing up when i turn it on it just says 008mb****** and wont print anything when we try screen goes blank. and freezes again.
Common issue with the P3005 series. Your formatter board is bad. You need to call HP first and have the serial number of your printer ready. They will tell you if it is covered by their warranty program for the formatter board. If it is then great. If not look to spend between $200 and $300 geting it fixed. I know this is not the best of news, but I have seen this many times on this model of HP. If you don't fully trust me on this just do a google search for HP P3005 formatter and you will see a LOT of people in the same boat as you are. A few people have fixed their own board by "baking" it in the oven for about 5 minutes. I have tried this and it worked for 2 weeks then failed. The only true fix and I even question this, is to get a repaired board from HP. I just think that HP has a design flaw at work here and so even a new/repaired board is doomed to fail eventually. My experiance level here is 27 years servicing copiers and printers. I have personally seen this problem on 4 or 5 of my customers P3005 models.
Good Luck and Thank You for using Fixya.
Sep 07, 2010 | HP LaserJet P3005n Printer
Error 49A What does this mean?
Hi! I will be glad to assist you. If this is your issue, here are the steps you need to do:
HP LaserJet P3005 Printer Series - Service Error 49.0E00 when Printing PDF Files from Mac 10.5
Issue
A Service Error 49.0E00 message appears while printing PDF files from Mac 10.5 with the EconoMode setting enabled from the printer control panel and using the printing presets with the EconoMode setting disabled.
Solution
Recommended action:
Disable the EconoMode setting from the printer control panel (the default setting is OFF ).
Select printing presets with the EconoMode setting disabled.
Try performing a test print from PDF files in the computer to check for the results.
NOTE: If it is required to use a printing preset with the EconoMode feature turned off, ensure that EconoMode is set to OFF from the printer control panel also.
or you can go to this link:
http://h10061.www1.hp.com/ccsearch/search?ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=1846089&productBigSeriesOid=1846087&spid=1846090&pname=HP+LaserJet+P3005+Printer&opname=HP+LaserJet+P3005+Printer&pname_desc=HP+LaserJet+P3005+Printer&st=1&ptype=commercial&stype=pn&qry=Error+49A&translate=&iqry=&ctflag=&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-007%2Cs-005%2Cs-017%2Cz-001%2Cc-002%2Cc-001&spname=HP+LaserJet+P3005+Printer&cqry=&uqry=&product_line_code=PQ
Oct 05, 2009 | HP LaserJet 3055 All-In-One Printer
Error message 52.00
HP LaserJet P3005 Printer- just changed toner and now service error displayed, tried to power on/off still not working??
May 14, 2009 | HP LaserJet P3005 Printer
HP LaserJet P3005n Printer Logo
1,185 people viewed this question
Ekse
efs_perpends
efs_perpends
