KitchenAid Pro Line Coffeemaker Coffee Maker Logo
Posted on Feb 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The on/off switch is broken. How can I replace it and where can I get the replacement piece?
Anonymous
Level 3:
  • Master 2,382 Answers
  • Posted on Feb 03, 2011
Anonymous
Master
Level 3:
Answers
2382
Questions
0
Helped
859411
Points
7450
Hi, the only distributor for Kitchenaid Pro Line parts is Kitchenaid directly. I would recommend calling their customer service. They have a specific parts department. Their toll-free telephone number is 1-800-541-6390 and they will also help you on how to replace it yourself..
Broken door catch
First turn the micro door upside down and shake it this may dis lodge it make sure its unplugged and rotating table is removed.If you can see the piece try tweezers or needle nose pliers but again make sure it is unplugged during any handling period!
Second UN plug the device remove its cover with phillips driver or what is needed after it is removed go to the safety switch where the piece is located remove it and shake the piece it may come out if not just replace the complete safety switch
My turn lever is broken , on the insu=ide of the steering colume, i cannt find and info or part to fix it.
You have more problems than just replacing the lever. There is still a piece of the broken lever inside the wiper switch, and is nearly impossible to get out. You will need to replace both the turn lever and the wiper switch. Replacing the wiper switch is no easy task, and if you are not familiar with General Motors steering columns, it's probably best to pay a shop to do the repair. The top half of the steering column has to be disassembled, and the wiper switch harness fed up through the column.
Door latch switch failure
no you need to replace the door lock assy
Brake lights don't go offwhen pedal comes up,
hello there:
try checking the fuses if fuses are good you may need to change the brake switch which is located on the brake pedal the are easy to replace you will have a keeper pin that will need to be removed in most cases they look like an r-key and depending on the switch you have you may need to remove a mounting pin or just slide the switch off then you will need to disconnect the wires off the switch and replace in reverse..hope this helps you out best of luck..please leave a review thanks..sincerely D.Jones
Fan switch broken .Need tofind out how to replace the switch
take the grill off
turn the power off
you will see a screw direct center where the fan switch is
remove it
pull the whole plastic piece up you will be able to replace it.
let me know how it goes
2answers
Front Panel switch
Please contact the reseller that sold you the computer
Replaced ignition switch
you have to align it with the key out then adjust the switch on steering column
Broken on/off switch
need to replace the on/off switch for this camera. I have the broken piece that cannot be repaired. How can i find a replacement switch. I can repair the camera myself with the new switch. thanks.
Fan switch broken
replacement switches at home depot for 3 speed fans.There should be instructions on the package of the switch.
Top KitchenAid Coffee Makers & Espresso Machines Experts
ZJ Limited
ZJ Limited
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
