Question about Wolf Range Ovens
Wolf oven turned itself on and locked the door. Went on and off several times and now we have pulled the breaker because we don't know what else to do.
Harjeet s. bola
  • 49 Answers
YOUR OVEN,S POWER SWITCH IS SHORT,TRY REPLACING IT.
Posted on Feb 03, 2011
  • sullytigs May 24, 2011
    I purchased a Wolf 6 burner range about 1 year ago. The igniter system for the burners has been replaced by an American unit (not cheaper Chinese version) and now the oven turned itself on the other day (gas smell obvious) and then turned itself off again a few minutes later while I was standing near the stove. Scared the daylights out of me so now have to call in repairman again? What the heck, this is a high end range!
I used the self-clean for the first time and my oven door is still locked and the display doesn't work at all. Model #YKESS908. What can I do to unlock the oven door? I have checked the circuit...
Hi
You can set the unit on self cleaning and then after 15 minutes stop the cycle, let it cool down for an hour and then open the door. If the issue remains then you'll have to replace the door lock assembly, then you can open the door with a coat hanger by pulling the latch towards you. Hope this helps...please post back for further assistance.
Daniel
Sep 09, 2011 | KitchenAid Ovens
I opened the door while cleaning was in setup and now F-9 flashes and I cannot turn on my oven.
Hello, welcome to Fixya.
The timer is just indicating the "monitor" switches where interrupted while the sensing of their position was taking place.
Have you tried turning off your breaker at the home service panel ( or unplugging it for several minutes ) ?
If not, turn off your breaker and turn it back on. This should initiate a restart of the component`s back to factory default including the lock monitor switches.
Once you switch the breaker, allow it to go through the start-up process ( don`t open the door or touch the clock ) where the processor (onboard watchdog) checks to make sure all functions are in working order and all switches are in the default position, ready to use.
If it works for you please take a second and rate the answer favorably, if not let me know and we`ll go from there.
good luck
macmarkus :)
May 08, 2010 | Frigidaire 30 in. Electric Gallery Series...
I have a frigidaire mef352bgwd electric oven- after a power outage the lock engaged (door open) and now blinks continually. Tried shutting off breaker for 30 minutes- no change.
There is a pin that tells the oven the door is open, you need to push it in an hold it. It is pretty stiff, you can't use your bear hand. It will be in the upper left of where the door closes.
Jan 07, 2010 | Frigidaire GLEB27S7A Electric Single Oven
Gerangeoven door won't open
Is it in time bake?
Oct 04, 2009 | GE Ovens
Older Kenmore oven- door locked by itself
We had a quick power outage and when the power came back on it locked our older (1991) Kenmore electric oven model # 40889 / 40881. Went throought the manuel and nothing pertains to this problem. We have turned off the circuit breaker and turned back on, but nothing seems to unlock the door. Any suggestions would be GREAT!!!!!!!
Nov 21, 2008 | Ovens
Whirlpool oven accubake system
I have a whirlpool accubake wall oven. Half-way through baking a pie ,unknown to me, the oven went to the self-clean mode , the door locked and the pie started to burn. I tried to turn the oven off but it would not cut off. I immediately ran to the house's main power and turned off the oven breaker. I waited for a short time to let the oven cool enough to open the door and get the burned pie out, then went back to turn my breaker back on and the oven (even though in the off mode) started heating again with the bottom unit turning red again. I had to then go back and pull the power. We tried this several times trying to push the off button but the oven will not go off until we throw the breaker. Help please!
Jul 01, 2008 | Whirlpool RBS245PDS Electric Single Oven
My oven is locked and I have a oven mitt inside how will it come out?
control reading door locked?? or door just stuck in locked position, try turning off hte breaker to the oven for a few secs , reset nad see of the door lock mech reeales itself. if ** you can try to put the unit into a clean cycle, and then 5-10 secs after he door "locks" press hte cancel button. both ways will cycle the door lock/latch assy
Mar 10, 2008 | KitchenAid Architect Series KEBC107KSS...
F9 code
I hit the same F9 problem when trying to self-clean, except that the door was locked OPEN.
After much trial and error, I found the following fix: 1. Switch circuit breaker off. 2. Switch circuit breaker on. 3. Press Bake button. 4 Press the small/inside button which indicates that the oven door is closed.
The lock mechanism opened and the oven now works fine.
Nov 22, 2006 | Amana AOCS3040 Electric Single Oven
Oven stopped working, door stuck in lock position
Tuck, sounds like your Thermal cut out opened on the back of the oven. You will have to get at this in the back of the oven. Part number 4451442. Look it up on the net so you know what your going after. This is a common deal on built ins. Going to need some help in pulling the oven out so far, removing the back panel and changing the TCO...Catriver Post back.
Oct 21, 2006 | Whirlpool RBD306PD Electric Double Oven
Ovens Logo
396 people viewed this question
Top Wolf Range Ovens Experts
Harjeet s. bola
Harjeet s. bola
ray gallant
jenifer ronan
jenifer ronan
Level 1 Expert
Are you a Wolf Range Oven Expert? Answer questions, earn points and help others
