Question about Sony Playstation 3 (PS3) Console
My son turned his PS3 off during a system update and now everything he tries to play won't let him and says error code 8003051e. What do I do to fix this problem?
Posted by jjatjp on
GameGuru
    New Friend:
  • 6 Answers
Ok what I recommend doing is these steps and you should be gaming again:
1. Start Ps3 and in the title menu to Account Management. 2. Click Account Management. 3. Go to System Activation. 4. DO Ps3 System NOT "Psp System". 5. Choose game then select deactivate ps3. (Why? so that way you can log in as your profile later.) 6. Once done go to System Settings. 7. Go down until you see Restore PS3 System. 8. Click it and select yes. (Once you say yes it will restore your ps3 to factory settings, It will take either 2 hours - 8 Hours. Depending on how much memory it has built in.) 9. Once done Download newest updates and let it download. 10. Once complete you should be playing video games in no time. Have Fun Gaming.
Posted on Feb 03, 2011
  • l3dwaba May 04, 2011
    Heya. Im getting the same error code(8003051e).. when i try to copy anything (mostly videos thou) to the PS3 HDD. Will formatting the drive help.?
I have an error code in the install operation tell me how to fix it
Common PS3 Error Codes and required Network Ports.
Additional PS3 Error Codes:
80010514 - Dead BD lens.
80010516 - Dead BD lens (happens at different occasions, code above is more common).
80710092 - Connection error (usually the connection is dropped), you will be signed out of PSN.
8002AD23 - Unidentified error (cause unknown), happens in Burnout Paradise (when game starts) and sometimes SARPBC.
8002A227 - PSN account suspended.
8002A212 - error returned by the PSN servers during authentication (invalid version).
80029945 - Can't playback burn BDr movie (error in picture above)
80029946 - Attempting to play burnt Dual layer NTSC disc on a Pal ps3
(workarouns is to transfer files to ps3 via TVersity)
(added 24th Sept 2007)
80029301 - An error occurred during the delete operation (attempting to delete some ps2 homebrew from virtual mem card) (added 15sept2007)
80029516 - Sign in to PLAYSTATION-Network (needed for some games or Ps3 processes - have to sign in to use them) (added 04-sept-2007)
80710A06 - An error occurred during the install operation (error when downloading game from PSN - network error occured (added 30thAug2007)
8003041F - An error occurred during the copy operation (using media server) (added27aug2007)
80010006 - An error occurred during the start operation (added 22aug07 - corrupted folding install)
80010007 - An error occurred during the start operation (added 17aug07 - during disc swap tests)
710102 - DNS Error; No DSN server available.
8013030 - System Error due to failed update download
80010001 - Major Error , Game ability stopped
80010017 - Can't start Blu-ray Game
80010510 - Will not play hard drive games - Cause unknown
80010516 - An error occured during the start operation; Ps1 game swapped using the eject function and then play pressed quickly - ps1 game inserted again
80029023 - Exchanging Key Information exchange has timed out
80029024 - "Cannot Obtain an IP address".
80029564 - Downloaded Game will not install - Cause unknown
80030920 - An error occurred during the copy operation. The file may be corrupt or there isnt enough memory. Try copying data from original source.
80031150 - System Settings Fail to Save - Possible Blue Screen "Setting information is corrupted.Pre
80031601 - Error Creating Account
80130203 - PS3 connects to internet but not to network - Typically means that the required ports are
80410418 - DNS Error
80710016 - Playstation Network is down.
80710092 - "An error has occured. you've been signed out from the ps network" -(connection dropped?
80710101 - Conneciton error
80710102 - IP conflict , PS3 Cannot connect to the router with current IP information - Try rebooting your router
80710541 - The connection to the server timed out. press the x button to repair and restore default"
80710723 - Possible Port Error - Try opening ports , TCP port: 80, 443, 5223 and UDP port: 3478, 3479, 3658. or add Ps3 to DMZ
81019002 - Error copying saves from location A to location B not open to connect to store but PS3 can connect to internet.
8001050B - Will not play demo hard drive games, when blue-ray disc is inserted - Cause unknown
8001050D - An error occured during the start operation; Ps3 game swapped using the eject function and then play pressed quickly - ps3 game inserted again
80028EA5 - Unknown?? User cannot connect to PS3 network. Sony told the user to send the machine in.
80028ea6 - Connection error , Possible Proxy error power cord. Then shut off your modem/router, for about 5 mintues, then turn the modem back up first and let it sync, then turn the router back on(if using one) and let it sycn.
Reconnect your power cable and flip the back swtich up again. Then make a new network connnection.
80028F10 - Go to Display Settings then HDMI (or whatever your connection is) and choose Automactic,
80028f17 - Ps2 disc Boot Error , An error occured during the start operation; Ps2 game swapped using the eject function and then play pressed quickly -Backup ps2 game inserted again
80028F18 - Ps2 Disc Error, unsupported disc; eg. Utility discs, BB discs, IQ Remix game etc. ode).
80028F19 - PS2 Disc Error , fsck; the internal PS2 disk got corrupted and I guess that you can use HDD utility disc to fix it
80028F1A - Ps2 Disc Error , invalbnnetcfg; network config error
80029C68 - Corrupt data usually on external device
8002A10D - Unable to Add friend in XMB
8002A4A6 - Cannot load game to play online
8002A515 - Error Signing in
8002A548 - Unable to remain logged in - either to game or server
8002A705 - Unable to connect to server/host. Check router port configuration.
8002a71a - Possible NAT Error , Can log onto Game Server but can't join game and can't host game
8002b241 - DVI has no audio
8002F994 - To many people downloading the update just sit back until the morning around 5am - 11am and you should be able to get it.
8002F997 - Trying to Update the Firmware, copying to a file and installing from a USB drive falied".
8003051E - Game will not Save
8013013D - "A connection error has occurred" - May be to do with the SSID of the Router or signal strength if the conneciton drops Putting the PS3 into DMZ may help - otherwise check WPA key Ps3 can't handle WPA2 only
WPA or none
8013013E - WEP Key error, change WEP key to all numbers (on router homepage) and try agian, or which to WPA. - Otherwise disable security
8013030F - Check Router Page, SSID Broadcasting possibly off.
8013030F - Access Point not detected
80410A0B - Internal PSP error, hardware fault. Send back to be replaced/fixed.
807101FF - An error occurred during communication with the server. This is a DNS error This is a DNS error
8071053D - Hard boot the PS3, turn off the PS3 to stand-by, flip off the back swtich and remove the
80710B23 - PS3 Network is Down or PS3 Network is too busy to respond
80710D23 - Turn the PS3 off for a bit (30 minutes give or take) with the power toggle (not standby mode)
80029513 - Copyright Violation when attempting to install game
8003200D - Server side issue, much like the trophy syncing problems.
8001050F - System Clock Error.
8002A227 - You account has been banned, either temporary or permanently, (Check here for reason why you may have been banned).
80029780 - Unable To Activate System - You have reached the maximum downloads for an unactivated system. This will not affect systems that are already activated on your PSN account.
80010002 Invalid argument.
80010003 Invalid syscall number. A lot of the addresses in the syscall table at 0x2EB128 point to a function that only returns this value.
80010009 Operation not permitted.
8001002B Filesystem mounting failed.
Aug 18, 2012 | Sony Playstation 3 (PS3) Console
Tip
Check Your Playstation 3 Error Code
<span style="font-weight: bold;">Error Code - Meaning/Suggestion/Possible Fix:<br /><br /><span>0710102 - DNS Error: No DNS server available.</span><br /><br />80010001 - Major Error, Game ability stopped.<br /><br /><span>80010006 - An error occurred during the start operation. - Corrupted folding install.</span><br /><br />80010007 - An error occurred during the start operation. - During the (internal) hard drive disk swap tests. suggests a failure with the hard drive.<br /><br /><span>80010017 - Can't start Blu-ray Game</span><br /><br />8001050B - Will not play demo game from the hard drive. When a Blu-ray disc is inserted. - Cause unknown".<br /><span><br />8001050D - An error occurred during the start operation; PS3 game swapped using the eject function and then play pressed quickly. - Insert PS3 game again.<br /></span><br />80010510 - Will not play games installed on the hard drive. - Cause unknown.<br /><br /><span>80010516 - An error occurred during the start operation: PS1 game swapped using the eject function and then play pressed quickly. - Insert PS1 game again.</span><br /><br />80028EA5 - Unknown. User cannot connect to Playstation Network ("PSN"). Contact Sony for resolution.<br /><br /><span>80028EA6 - Connection Error: Turn off PS3, unplug router and modem. Turn on modem and allow it completely boot-up and synchronize. After the modem shows that it is "online", then plug in the router and allow it to completely boot. Lastly, plug-in and turn on the PS3.</span><br /><br />80028F10 - Go to Display Settings then HDMI (or whatever your connection is) and choose Automatic.<br /><br /><span>80028F17- PS2 Disc Boot Error. An error occurred during the start operation: PS2 game swapped using the eject function and then play pressed quickly. - Insert PS2 game again.</span><br /><br />80028F18 - PS2 Disc Error. Unsupported disc: eg. Utility discs, BB discs, IQ Remix game etc.<br /><br /><span>80028F19 - PS2 Disc Error. Fsck: the internal PS2 disk was corrupted. You may be able to use the HDD utility disc to fix it (use with caution), otherwise, contact Sony.</span><br /><br />80028F1A - PS2 Disc Error. invalbnnetcfg: network config error.<br /><br /><span>80029023 - Exchanging Key Information: exchange has timed out.</span><br /><br />80029024 - Cannot obtain an IP address. DHCP failure. Check network connection, modem and/or router.<br /><br /><span>80029301 - An error occurred during the delete operation: attempting to delete PS2 data from virtual memory card.</span><br /><br />80029513 - Copyright Violation when attempting to install game.<br /><span><br />80029516 - Sign in to PLAYSTATION-Network: needed for some games or PS3 processes. Sign-in is required for current operation/request.</span><br /><br />80029564 - Downloaded game will not install: Cause unknown.<br /><span><br />80029945 - Can't playback burned BDr movie: Error in picture.</span><br /><br />80029946 - Attempting to play burned Dual layer NTSC disc on a PAL PS3. The workaround is to transfer files to the PS3 via TVersity.<br /><br /><span>80029C68 - Corrupt data. Usually on an external device.</span><br /><br />8002A10D - Unable to Add friend in XMB. (Normally because you have reached the limit of (100 friends)<br /><br /><span>8002A4A6 - Cannot load game to play online.</span><br /><br />8002A515 - Error Signing in.<br /><span><br />8002A548 - Unable to remain logged in. Either due to game or server.</span><br /><br />8002A705 - Unable to connect to server/host. If you are using a router, check port/DMZ configuration.<br /><span><br />8002A71A - Possible NAT Error. Can log into Game Server but can't join game and can't host game. Turn off the PS3 and wait for 5 minutes.</span><br /><br />8002B241 - DVI has no audio.<br /><span><br />8002F994 - Too many people currently downloading the update. Server(s) at capacity. Wait and retry</span>.<br /><br />8002F997 - Trying to Update the XMB Firmware: Copying to a file and installing from a USB drive failed.<br /><span><br />8003041F - An error occurred during the copy operation. (Using media server)</span><br /><br />8003051E - Game will not Save.<br /><span><br />80030920 - An error occurred during the copy operation. The file may be corrupt or there isn't enough memory. Try copying data from original source.</span><br /><br />80031150 - System Settings Fail to Save. Possible Blue Screen Setting information is corrupted.<br /><br /><span>80031601 - Error Creating Account.</span><br /><br />8013013D - A connection error has occurred: Causes may include the actual SSID of the wireless access point/router or signal strength. If the connection drops, try enabling DMZ functionality on your router (if supported) for your PS3. Otherwise check WPA key. The PS3 wireless interface [currently] does not support WPA2 - only WPA, WEP or none.<br /><span><br />8013013E - WEP Key error: Change WEP key to *only* numbers and try again, or switch to WPA.</span><br /><br />80130203 - PS3 connects to the internet (you can go a website via the PS3's browser), but cannot connect to the Playstation-Network. Typically this means that the required ports are not open/accessible. Check your router's configuration.<br /><br /><span>8013030 - System Error: Due to failed update download.</span><br /><br />8013030F - Access Point was not detected. Check your router's configuration and make sure that SSID broadcast is enabled.<br /><span><br />80410418 - DNS Error.</span><br /><br />80410A0B - Internal error: "Hardware Fault". Send unit back to be replaced/fixed.<br /><span><br />80710016 - The Playstation Network is down.</span><br /><br />80710092 - "An error has occurred. you've been signed out from the Playstation-Network". Connection dropped? If your PS3 is wireless (least preferred), the association between the PS3 and the access point may have been dropped. You may need to "reboot" your PS3 if your PS3 and router are unable to establish an association.<br /><br /><span>80710101 - Connection error.</span><br /><br />80710102 - IP Address conflict. PS3 cannot connect to your router with it's current IP Address information. Try rebooting your router and PS3. Occurs when two devices on your network have the *same* IP Address.<br /><br /><span>807101FF - An error occurred during communication with the server. This is a DNS error. It occurs when your PS3 tries to perform a DNS lookup to connect to the server.</span><br /><br />8071053D - Hard boot the PS3. Turn off the PS3 via your controller (this is stand-by mode), Turn off the PS3 switch on the back of the PS3 and remove the power cord. Next, turn-off/unplug your modem (and router if applicable) for about 5 minutes. Then turn on the modem and wait for it go "online". If you have a router, turn it on and wait for it go "online". Then turn your PS3 back on and make a new network connection.<br /><br /><span>80710541 - The connection to the server timed out. This is usually due to: high traffic (between you and the server), high traffic at the server [itself] or you have a "poor path" to the server. Depending on result: Press the 'X' button to repair and restore default.</span><br /><br />80710723 - Possible Port Error: Try opening ports. Configure your router to pass the following ports to your PS3:<br />TCP ports: 80, 443, 5223<br />UDP ports: 3478, 3479, 3658<br />Another option is (if your router supports DMZ functionality) to configure your router's DMZ functionality to pass traffic to your PS3.<br /><br /><span>80710A06 - An error occurred during the install operation. Error when downloading game from the Playstation-Network. An error occurred.</span><br /><br />80710B23 - Playstation-Network is down or Playstation-Network is too busy to respond.<br /><span><br />80710D23 - Turn the PS3 off for a bit. For 30 minutes give or take. Make sure that you either unplug or actually turn off the switch (located on the back of the PS3). "Stand-by" mode is when you see the red LED on the front of the PS3. If you see the red LED on the front of the PS3, your PS3 is *NOT* off.</span><br /><br />81019002 - Error copying saves from location "A" to location "B" not open to connect to store but PS3 can connect to internet.</span>
on Feb 21, 2011 | Sony Playstation 3 (PS3) Console
Tip
PlayStation 3 ERROR CODES
Complete PS3 Error Codes:<br /> <br /> <br /> 0710102 - DNS Error; No DSN server available.<br /> <br /> 8013030 - System Error due to failed update download<br /> <br /> 80010001 - Major Error , Game ability stopped<br /> <br /> 80010006 - An error occurred during the start operation (corrupted folding install)<br /> <br /> 80010007 - An error occurred during the start operation (during disc swap tests)<br /> <br /> 8001000B - it happens when trying to establish wireless connection<br /> <br /> 80010017 - Can't start BlueRay Game<br /> <br /> 8001050B - Will not play demo hard drive games, (when blue-ray disc is inserted) - cause unknown<br /> <br /> 8001050D - An error during the start operation; Ps3 game swapped using the eject function and then play pressed quickly - ps3 game inserted again<br /> <br /> 8001050F - Hardware failure. Cannot update firmware or connect to internet.<br /> <br /> 80010510 - Will not play games installed on the hard drive<br /> <br /> 80010514 - Possibly reading blu-ray disc problem<br /> <br /> 80010516 - An error occurred during the start operation; Ps1 game swapped using the eject function and then play pressed quickly - ps1 game inserted again<br /> <br /> 80023101 - Unknown<br /> <br /> 80028E07 - which pops up when i try to update to 1.93 and says that i have been disconnected from the server<br /> <br /> 80028EA5 - User cannot connect to PS3 network<br /> <br /> 80028EA6 - Connection error , Possible Proxy error power cord. Then shut off your modem/router, for about 5 minutes, then turn the modem back up first and let it sync, then turn the router back on(if using one) and let it sync. Reconnect your power cable and flip the back switch up again. Then make a new network connection.<br /> <br /> 80028EA8 - Seems to mean unable to authorize isp account details<br /> <br /> 80028F10 - Go to Display Settings then HDMI (or whatever your connection is) and choose Automatic,<br /> <br /> 80028F17 - Ps2 disc Boot Error , An error occurred during the start operation; Ps2 game swapped using the eject function and then play pressed quickly - Backup ps2 game inserted again<br /> <br /> 80028F18 - Ps2 Disc Error, unsupported disc; eg. Utility discs, BB discs, IQ Remix game etc. ode).<br /> <br /> 80028F19 - PS2 Disc Error , fsck; the internal PS2 disk got corrupted and I guess that you can use HDD utility disc to fix it<br /> <br /> 80028F1A - Ps2 Disc Error , invalbnnetcfg; network config error<br /> <br /> 80029023 - Exchanging Key Information exchange has timed out<br /> <br /> 80029024 - "The attempt to obtain an IP address has timed out".<br /> <br /> 80029301 - An error occurred during the delete operation (attempting to delete some ps2 homebrew from virtual mem card)<br /> <br /> 80029501 - connection<br /> <br /> 80029509 - When the PSN network is down for maintenance.<br /> <br /> 80029513 - This content cannot be accessed on your account (80029513)<br /> <br /> 80029516 - Sign in to PLAYSTATION-Network (needed for some games or Ps3 processes - have to sign in to use them)<br /> <br /> 80029564 - Downloaded game will not install<br /> <br /> 80029751 - warhawk wont start but eveything else seems ok<br /> <br /> 80029945 - Can't playback burn BD movie<br /> <br /> 80029946 - Attempting to play burnt Dual layer NTSC disc on a PAL ps3 ( workarounds is to transfer files to ps3 via TVersity )<br /> <br /> 80029C68 - Corrupt data usually on external device<br /> <br /> 8002A10B. It shows up when I try to view my friends trophies, profile etc.<br /> <br /> 8002A10D - Unable to Add friend in XMB<br /> <br /> 8002A4A6 - Cannot load game to play online<br /> <br /> 8002A515 - Error Signing in<br /> <br /> 8002A524 - connection<br /> <br /> 8002A548 - Unable to remain logged in - either to game or server<br /> <br /> 8002A705 - Unable to connect to server/host. Check router port configuration.<br /> <br /> 8002AD23 - Unknown<br /> <br /> 8002AD3D - Cannot Log into PSN - Is the PSN down? Try manually configuring your PS3 IP info. Try disabling medai server connection in the PS3.<br /> <br /> 8002B241 - DVI has no audio.<br /> <br /> 8002B71A - Possible NAT Error , Can log onto Game Server but can't join game and can't host game<br /> <br /> 8002F994 - Too many people downloading the update (download it later on)<br /> <br /> 8002F997 - Can not update XMB firmware<br /> <br /> 80030001 - Deleting messages from inbox<br /> <br /> 8003041F - An error occurred during the copy operation (using media server)<br /> <br /> 80030517 - It seems to happen when you copy large media files.<br /> <br /> 8003051E - Game will not save<br /> <br /> 80030920 - An error occurred during the copy operation, the file may be corrupt or there isn't enough memory (Try copying data from original source)<br /> <br /> 80031150 - "Setting information is corrupted.Press the x button to repair and restore default"<br /> <br /> 80031601 - Error Creating Account<br /> <br /> 8013013D - "A connection error has occurred" - May be to do with the SSID of the Router or signal strength if the connection drops Putting the PS3 into DMZ may help - otherwise check WPA key Ps3 can't handle WPA2 only WPA or none<br /> <br /> 8013013D - connection<br /> <br /> 8013013E - WEP Key error, change WEP key to all numbers (on router homepage) and try agian, or which to WPA. - Otherwise disable security<br /> <br /> 80130203 - PS3 connects to internet but not to network - Typically means that the required ports are not open to connect to store but PS3 can connect to internet.<br /> <br /> 8013030F - Access Point not detected<br /> <br /> 8041040F - Communication with the server failed. A dsn error has occured.<br /> <br /> 80410418 - DNS Error<br /> <br /> 80410A0B - Internal PSP error, hardware fault. Send back to be replaced/fixed.<br /> <br /> 80710016 - Playstation Network is down.<br /> <br /> 80710092 - "An error has occurred. you've been signed out from the ps network" , "Media Server Error: A network error has occurred (80710092)"<br /> <br /> 80710101 - Connection error<br /> <br /> 80710102 - IP conflict , PS3 Cannot connect to the router with current IP information - Try rebooting your router<br /> <br /> 807101FF - An error occurred during communication with the server. This is a DNS error - This is a DNS error<br /> <br /> 8071053D - Hard boot the PS3, turn off the PS3 to stand-by, flip off the back switch and completely remove the power cord. Shut off your modem/router, for approx. 5 minutes, then turn the modem back up first and let it sync. Then turn the router back on (if you're using one) and let it sync. Reconnect your power cable and flip the back switch up again. Then make a new network connection<br /> <br /> 80710541 - The connection to the server timed out.<br /> <br /> 80710723 - Possible Port Error - Try opening ports , TCP port: 80, 443, 5223 and UDP port: 3478, 3479, 3658. or add Ps3 to DMZ<br /> <br /> 80710A06 - An error occurred during the install operation (error when downloading game from PSN - network error occured<br /> <br /> 80710B23 - PS3 Network is Down or PS3 Network is too busy to respond<br /> <br /> 80710D23 - Turn the PS3 off for approx. 30 minutes with the power toggle, not standby mode<br /> <br /> 81019002 - Error copying saves from location A to location B not open to connect to store but PS3 can connect to internet.
on Feb 06, 2011 | Sony Playstation 3 (PS3) Console
Error code for sony 3 807
"Hey, here is a list and a reason of some of the error codes you may encounter whilst connecting your PS3 online, also the required ports need to be opened in order to play online.
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation 3 Error Code List
8002b241 - DVI has no audio.
80028EA5 - Unknown
80029024 - The attempt to obtain an IP address has timed out
80031150 - System Settings Fail to Save - Possible Blue Screen "Setting information is corrupted.Press the x button to repair and restore default"
80710092 - "An error has occured. you've been signed out from the ps network" - (connection dropped?)
80710102 - PS3 Cannot connect to the router with current IP information - Try rebooting your router
80710B23 - PS3 Network is Down or PS3 Network is too busy to respond"
http://community.us.playstation.com/thread/2996553?start=0&tstart=0
Apr 17, 2011 | Sony Playstation 3 (PS3) Console
Sony PS3 ERROR CODE 80710092?
here are some of the ps3 error code that might help you in the future..
80023101 - Unknown
8002AD23 - Unknown
Mar 01, 2011 | Sony PlayStation Portable (PSP) Console
When we play ps3 and we try to change the options in the game the error 8003051E comes and the file does not save. even during the play the game cannot authomatic save. so everytime we need to start from...
HI,
Things You'll Need:
* PlayStation 3
* External hard drive
Unplug any external hard drive that may be attached to the PS3.
Restart the PS3, including unplugging it and plugging it into the power supply again.
Format the file you are trying to save to be less than 2 GB in size. The main reason you are getting this error (game will not save) is due to the large file you tried to save.
Connect the external hard drive to your PS3 again and save the file. The error should not occur again.
Oct 11, 2010 | Sony Playstation 3 (PS3) Console
PS3 error code downloading patches. Prior fix-ya advise inop. Need help fixing router problem. Conflict with Ps3.
0710102 - Error DNS, DNS server not available.
8001050B - Don't start demos on the hard disk when you have a Blu-Ray added. Unknown cause.
80010510 - Don't start games on your hard disk. Unknown cause.
80028EA5 - Unknown.
80029023 - Exchange of key information timed out.
80029024 - The Attempt to obtain an IP address timed out.
80029564 - Game downloaded does not install. Unknown cause.
8002F997 - You cannot upgrade the XMB firmware.
8003051E - Game does not write.
80031150 - The settings are not be save. Possible System blue screen "Setting information is corrupted. Press the X button to repair and restore default".
80130203 - PS3 connects to the Internet, but not to the PSN. This could mean that the ports needed to connect to Store are not configured.
80710092 - "An error occurred. You were disconnected from the Playstation Network" - (the Internet connection lost?).
80710102 - PS3 can not start the connection with the information configured with the IP router. Try renice the router.
80710B23 - PSN is offline, or the PSN is too busy to respond.
80710D23 - Off the PS3 for a while (30 min) with the AC switch (not standby mode).
80029024 - "Could not get an IP address."
80028EA5 - Unknown - User cannot connect to PSN. Sony said user to take to get the PS3.
8002F997 - Trying to update the PS3 firmware, downloading the update file for USB and attempt to install failed.
80710016 - Playstation Network is offline.
8013013E - WEP keyError, replace WEP key for all the numbers and try again, or to replace WPA.
8013030F - Check page of the router, off SSID Broadcasting.
8002F994 - Many people are making downloading updates. Please try again later.
80028F10 - Go to Settings and choose presentation HDMI (or whatever your connection) and choose Auto, not Custom.
8002A705 - Unable to connect to. Server. Check the router settings doors.
80030920 - An error occurred during the copy operation. The file may be corrupt or there is a lot of memory. Try copy of its original location.
80010514 - total failure of the Bluray drive.
May 06, 2010 | Computers & Internet
Sony Playstation 3 (PS3) Console Logo
421 people viewed this question
Top Sony Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Lee Hodgson
Lee Hodgson
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
