Question about Insignia IS-LCDTV32 32 in. Television
Have a Magnavox model 32MF330B/F7 it does not have full picture it has a black border. It only has a 24" screen
Posted by wbowman87 on
jairo sanchez
    Sergeant:
    Champion:
  • 276 Answers
This desconfigurado enters to the menu put option way of screen norman changes the opcion of narrow long width and normal escoga the option and the screen opens normally
Posted on Feb 03, 2011
'Black box' appears on JVC TV screen/blocks picture
Any chance of a model number to enable accurate description?
What could be wrong flat screen has a bad picture seems to be no black color??
I will tell you this, it will be cheaper to replace it than try and repair it.
NO Picture, have sound
Check and replace the back-light inverter board as card basis. Contact any service technician. Gopakumar Gopalan Google
I have a Magnavox 32 inch flat screen, model # 32mf338b/f7. We used some generic universal remote, now it is stuck on 4:3 screen ratio. I cannot figure out how to get it back to the normal 16:9 ratio. ...
32MF338B F7 Magnavox
Go to above link and download the user's manual. Follow instructions to change to 16:9 setting.
You can also press the format button on your remote to change to 16:9 format.
Semper Fi,
Z
2helpful
3answers
Screen resolution change = black border around small screen
Once you change the resolution to a smaller size and you see the black border, go into the monitor's menu and there should be settings for the Horizontal and Vertical size/position. Adjust those until it looks correct.
I hope this helps :)
Best Regards,
James
Picture not centered on my philips 47'' lcd tv
NOTE:(Edited and copied from another thread on Fixya.com, c7carl)
Picture is not centered on monitor leaving a 2 1/2 inch; black border on Philips LCD
By dmorrow54 on Nov 13, 2007
Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The wide-screen/ full-screen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, super-zoom, wide-screen, full-screen. Help, please. posted 3 years ago
Guest
  • Rank: Guide
  • Rating: 0%, 0 Votes
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Add a comment
    • c7carl
    • 5 minutes ago
    WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are! Reply
    Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
    Comment:
Insignia IS-LCDTV32 32 in. Television Logo
Top Insignia Televison & Video Experts
Ekse
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
