You can do it by following these simple steps as below to Uninstall Calendar Creator 12
* 1Close all programs.
* 2Click on "Start," then "Control Panel." Click on "Classic View" in the left column.
* 3Double-click on "Add/Remove Programs" in Windows XP or "Programs & Features" in Windows Vista or Windows 7.
* 4Find "Broderbund Calendar Creator" in the list of installed programs. Double-click it.
* 5Follow the on-screen prompts to complete the uninstallation
The traditional method --- uninstall Broderbund Calendar Creator with windows add/remove program 1. Start-->Control Panel-->Add/Remove Programs. 2. Find Broderbund Calendar Creator in the program list and right click to choose Delete. 3. Follow the panel wizard and reboot your PC when it finished. In fact this way can not remove all the components of Broderbund Calendar Creator. Registry keys of Broderbund Calendar Creator still remain on your computer. It is advised to clear up registry entries of Broderbund Calendar Creator or you are likely to encounter problems like uninstall or install error, registry error and so on. Guaranteed Method -- Uninstall Broderbund Calendar Creator with a professional uninstall tool A third party uninstall program can force uninstall Broderbund Calendar Creator while windows add/remove program fails. Moreover, a third party uninstall program can clear up all the registry entries of Broderbund Calendar Creator. Among so many uninstaller tools, Perfect Uninstaller enjoys high reputation. Perfect Uninstaller can remove Broderbund Calendar Creator completely in 4 simple clicks. 1. Free download Perfect Uninstaller form its official website. 2. Install Perfect Uninstaller on your computer 3. Browse for Broderbund Calendar Creator folder with Perfect Uninstaller. 4. Click REMOVE to uninstall Broderbund Calendar Creator from your computer. It is important to uninstall Broderbund Calendar Creator thoroughly from your computer, as its remained components will have a side affect on your current antivirus program. Are you tired of trying various methods to uninstall Broderbund Calendar Creator? Do you want a certain effective way to uninstall Broderbund Calendar Creator? What you really need is a third party uninstall program. And before you search for a great uninstall program, have a look at Perfect Uninstaller and then compare it with the other one
Read more: http://www.articlesbase.com/software-articles/how-to-uninstall-broderbund-calendar-creator-thoroughly-from-your-pc-now-3769861.html#ixzz1CrBj3PaU
Under Creative Commons License: Attribution
SOURCE: I HAVE A NEW COMPUTER WITH WINDOWS 7. I CANNOT
Check to see if the cd is compatible with windows 7. It might not be. If it isn't check the website of the manufactorer to see if they have a download. If they do you can make that download compatible on a windows 7 machine.
If you have windows 7 professional version you can install xp and then put the disk on the xp part of windows 7.
SOURCE: Will Calendar Creator 12 work with Windows 7
Yes and no. Calendar Creator 12.1 will work with Windows 7 - 64 bit, but the PDF converter will not. So you can't save your files in pdf format and have them printed externally.
