SOURCE: Turns itself off after about 10 minutes of watching, then Blue Power Button Light starts blinking.
I have experienced that and I found out that it was plugged to 110 volts instead of 220 volts. Becaouse I bought mine in the Philippines,it is 220 volts.
SOURCE: no sound on JVC AV-48P575 48 inch rear projection TV
Try going into the menu and find something called, "center channel input." If it is on, the sound will not work. Turn it off, and the sound should be restored.
SOURCE: Need downloadable manual
Click HERE to download required instruction manual of JVC AV-48P575
Thanks.
SOURCE: clicking on the power supply board(no picture or sound)
If you hear a buzzing, humming or rapid clicking noises this could be a problem with your ballast.Might be a good idea though to pull out your lamp just ensure its not damaged.You can find these at discount-merchant.com
