Question about Olympus Stylus 1000 Digital Camera
The date on my stylus is off by a day, but when I go to the calendar to change it and press "OK", it reverts to the wrong date again. How can I fix this?
Rommel Alilin
    Guru:
  • 2,178 Answers
  • Anonymous Feb 03, 2011
    I had read the manual before I asked the question here, and perhaps I misunderstood something, but I did not find the solution there.
How do I change date on Vivitar x029
Press the MENU button. Select the calendar icon (calendar pad with number "15"). Select "Date/Setup." Use cursor/left-right to move between fields, cursor-up/down to change them. Press SET when done.
Dec 14, 2011 | Vivitar ViviCam Cameras
Tip
How To Set The Time/Calendar For Your Seiko Watch
<span style="font-weight: bold;">Time Setting for Models Without Calendar</span><br /><span style="font-style: italic;">Note: When setting the minute hand of a quartz watch, advance it a few minutes ahead of the time and then turn it back to the exact time.</span><br /> <ol> <li>Pull out the crown all the way. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li> <li>Adjust the time by turning the crown in the desired direction.</li> <li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol><span style="font-weight: bold;">Time/Calendar Setting for Models With Calendar</span><br /><span style="font-style: italic;">Note: The date will change gradually between 9:00 PM and 4:00 AM. For some models, however, it will change instantly when the hands pass the 12 o'clock marker at midnight.</span><br /> <ul style="font-weight: bold;"> <li>For models with date calendar</li></ul> <ol> <li>Pull out the crown to the first click.</li> <li>Turn the crown until the previous day's date appears in the calendar frame.</li> <li>Pull out the crown to the second click, and advance the hour and minute hands until the desired date appears. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li> <li>Adjust the time by turning the crown in the desired direction.</li> <li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol> <ul style="font-weight: bold;"> <li>For models with day and date calendar</li></ul> <ol> <li>Pull out the crown to the first click.</li> <li>Turn the crown until the previous day's date appears in the calendar frame.</li> <li>Turn the crown in the opposite direction until the desired language (bilingual) for the day before the desired day appears in the calendar frame. <span style="font-style: italic;">Note: For Cal. 7009 and 7019, push the crown back in to the normal position and then push it repeatedly to set the day.</span><br /></li> <li>Pull out the crown to the second click, and advance the hour and minute hands until the desired date and day appears. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li> <li>Adjust the time by turning the crown in the desired direction.</li> <li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol><span style="font-weight: bold;">Note:</span> Do not change the calendar between 9:00 PM and 4:00 AM as it may not change properly. If it is necessary to set the calendar during that time period, first change the time to any time outside those hours, set the calendar and then reset the correct time. When the day shifts automatically to the next day, the other language will temporarily appear.<br /><br /><span style="font-weight: bold;">Note:</span> When setting the hour hand, check that AM/PM is correctly set. The watch is designed so that the calendar changes once in 24 hours.<br /><span style="font-style: italic;">Turn the hands past the 12 o'clock marker to determine whether the time is set for the AM or PM period. If the calendar changes, the time is set for the AM period. If it does not change, the time is set for the PM period.</span><br />
on Feb 15, 2011 | Watches
How do you change system date on ds
SOURCE: http://www.nintendo.com/consumer/systems/ds/time_date.jsp
Changing the date
  1. Remove all games from the Nintendo DS.
  2. Turn the system on by pressing the POWER button.
  3. Tap the screen using the stylus when the "Touch the Touch Screen to continue" message appears.
  4. When the main menu appears, tap the stylus on the Settings Menu Panel at the bottom middle part of the screen. icon_settings.gif
  5. Tap the calendar/time icon (the blue icon, second from the left). icon_clockdate.gif
  7. Tap the up or down arrows above the month, day, and year to change the values. When finished, tap the "Confirm" button in the lower right corner.
  8. Wait for the the confirmation message to disappear, then tap "Go Back," then "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
Apr 15, 2010 | Nintendo DS Lite
I need to change the date on casio cash register SE-5300 that has been set wrong
I Suppose that is Casio SE-S300 Model :
To change Date,
1. Key turn to PGM
2. Press [1] [Subtotal]
3. Input today's date, eg : 8 March 2010
Press [1] [0] [0] [3] [0] [8]
4. Press [X/Date/Time]
5. Key turn back to REG
6. O.K.
Feb 28, 2010 | Casio Boss Business Organizer
Ultronic lcd clock with a stylus tucked in back of clock
This thing set under my bed, lifeless til I was looking for something else and decided it was time to get this clock working!
(Use the stylus pen for best results) After putting in two fresh batteries (or hit the reset button if your batteries are fresh). This will reset the clock and the 'clock' icon in the upper lefthand corner will be blinking. Now press and hold the display area where the hour of the day is displayed. The entire time will start blinking. Now start tapping on the blinking hours to increment the clock slowly to the correct hours (it will cycle all the way thru military time and regular time, so choose what you desire). Press and hold with the stylus to increment quickly. Do the same with the minutes, that are blinking too. When time is correct, tap the 'clock' icon once. The 'clock' icon will still blink, which I believe is correct operation.
To set the date, tap on 3rd icon down from the top left (it looks like a little calendar). This will put you into the date section of the clock (if you do nothing, it will cycle back to the clock, after ten seconds, as a default). Before it cycles back to the clock, press and hold with the stylus pen right below the word 'DATE', until the the entire displayed date starts blinking. Tap the first two digits of the year to go down in years and tap the right two numbers of the year to go up in years. Tap on the month number to increment; do the same with the date number. When all date entries are correct, either tap the 'calendar' icon, or let the clock sit for ten seconds: it will cycle back to the clock.
I guess you can set the alarm in a similar method.
Hopes this helps!
ExitKC
Nov 03, 2008 | RIM BlackBerry Pearl 8100
I can't set the date on my new citizen's eco drive BM8080-59A. I don't know if I'm doing it wrong or if the date setting function is broken. I have tried to change the date by pulling the winder to the...
Yes that is ok its right by pulling the crown winder in the mid level or half level,that is for calendar date.To check if function is ok or broken,just pull full the crown and set the time,see if the calendar date is changing or moving.Then if moving then its ok,the next step you do set is the calendar date,by pulling the crown half pull,then turn the crown counterclockwise for date and for the day turn clockwise.Feel free to post whatever the result of the setting...
Hope it may helps you;
Regards,
VOTIT
Sep 23, 2008 | Citizen Watches
Change date on wii fit
You may have to eject the disk and erase the memory blocks and start over.
Aug 11, 2008 | Nintendo Activision Guitar Hero World Tour...
Canon MP11DX
press the date/time button
press and hold the = button
once blinking set the date
press the = button again
once blinking set the time
the "x" button changes A / P
press the + button again
Feb 29, 2008 | Canon LS-100TS Calculator
Nintendo ds
Setting the Time and Date
Changing the time
  7. Tap the up or down arrows above the hour and minute to change the time. When finished, tap the "Confirm" button in the lower right corner.
Changing the date
Dec 30, 2007 | Nintendo DS Console
How do you set the clock/calendar on the Canon MP25DV?
on the bottom of your calculator is a reset button, with a paperclip or a pen press that button. Then, press the calendar, clock key. next, press the equal sign key until the date is flashing type in the date using 11172006. press the equal sign again and the date is set. Next press the calendar, clock key again the time should show up (12-00-00)press the equal sign again until the time starts to flash. enter in the time using 0903 (9:03) press the equal sign again. Time is set. to display the date and time when not using the calculator, press the calculator, clock key 2x's. to go to compute mode press the red CE/C button.
Nov 04, 2006 | Canon MP-25DV Calculator
Olympus Stylus 1000 Digital Camera Logo
41 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you an Olympus Camera Expert? Answer questions, earn points and help others
