Picture is nice but has an over powering green color. I suspect one of the colors is not working. Cables are connected according to instructions and cable ends look good (no bent pins). Help! Also tried the reset but no change. Bad cable?
usually a single color is caused by a bad connection to the display I would guess that a connector inside the TV has come partially loose causing this this is quite common on the computers at my work due to vibration before taking the TV apart I suggest replacing the external cables to the VCR
When you see the a picture with missing color, but the television is capable of showing colors on screen you have a cabling problem from the device sending the picture to the TV.
If you are using component video, three separate connectors red, green, and blue, and they are all matched to correctly colored termal on each end, be sure all cables fit tight. If the cables are tightly connected to the terminal of matching color at each end you will need to replace the cable.
Component Video Cable on Amazon.com(with a picture)
If you are using S-video, older connection type where the cable end is a ring with four tiny metal pins plus a plastic square, one of the bins is either bent or broken. If you are unable to adjust the pins to fix the cable replace it.
S-Video Cable on Amazon.com(with a picture)
have you connected up correctly, have you selected correct EXTERNAL inputs, you do NOT "tune" a Channel to see picture, you choose external AV input on set. Must connect color to color. 3 for Composite Video AV.Yellow, Video, Red & White Audio. and 5 cables for Component 3 for Video , & 2 for Audio Blue, Green, Red, Also Red & White, Audio.
AV
Looks like you are using Component cables. There are five cables. The first three cables are Green,Blue and Red. These are the ones that are molded next to each other and are the Video signal cables. The other two cables are Red and White and they are the audio cables.
First to correctly hook up these cables you need to Connect (Match) Color for Color. (Green to Green, Blue to Blue, and Red to Red. To tell if you have correctly connected the Video cables is to look at the screen. If the picture looks ok (Normal with no colors missing then you have connected the video cables correctly). If you see a missing color meaning red, then switch the Red cables. The picture should be ok now. The remaining two cables are the Red and White cables. The "Red cable" is for the "Right" audio input and the "White" cable is for the "Left" audio Input". If all is connected correctly then you should have a good picture and Left and Right audio.
The 37" Vizio I just bought has a very confusing feature where the same input can be used as either the Y channel of the component or the full video channel for composite. If you plug a component source into the TV and then select the composite input ("AV" on the remote), you will see a black and white version of the full component signal (makes sense as the Y channel is just the luminance component). As sad as it is, I was stumped by this for a while until I happened to hit "COMP" and got full color. FWIW, the manual warns about this, but it really doesn't emphasize the point. I wonder how many returns they get because of this.
RCA cable connectors (red,white, yellow) are usually for an analog setup. You could still use these for "component" setup, but know the difference with color stamps as follows:
Component color stamps are "blue, green, red" ( blue is marked Pb, green is marked Y, red is marked Pr)
RCA color stamps your using are "red, white, yellow"
Here are the proper hook up method for "Component" using your "RCA" connectors:
On both the TV and DVD component setup:
Plug the red RCA fitting in the component port marked "Pr (red)
Plug the white RCA fitting in the component port marked "Pb (blue)
Plug the yellow RCA fitting in the component port marked "Y (green)
Be sure this setup is the same for the TV's component input ports, and the DVD's component output ports.
i-Note:
For optimum picture quality you may want to purchase component cables as the gage is thicker giving better impedance match resulting in better picture and sound quality.
Check settings first to make sure no one changed anything out of the ordinary. Are the shadows that of a color or darkened shadow? It could be out of convergence, which can be corrected in the menu - or it could be low quality video cables to. Also, if there is no green, does a white color show up when you're in a menu mode (Red+Blue+Green = White Image)? If so, then the green picture tube is working and it's just a color adjustment, otherwise you may have to invest in a new green picture tube.
Are you using component cables (red/green/blue)? Check your connections to see that they are all seated properly. When using component cables, if only the green is plugged in, it will give you a black and white picture. You will get color once you plug in the red and blue.
What kind of sources are you using? what kind of cables are you using? Need these kinds of specifics to ehlp you out.
Hi, I had the same problem and I wrote an email to Nu. They wrote me back that I should use the Factory reset feature which you have to go through the Factory Menu to get to. Instructions to do this are as follows. I got to the menu my first try but it has been a pain to get back to it. I hope it will be easier to access for yours.
Hope this helps
-Nate
Page 1
You will need to display a gray scale picture which varys from black to white
You will need to display a gray scale picture which varys from black to white.
Displaymate 16 grays pattern is good or something like the picture to the right.
Press and hold SEL/AUTO and press the power button. Then release the SEL/AUTO button.
Press the MENU key to display the factory menu.
Sencore 11 gray Pattern
Press the and select FACTORY2 menu. Factory2 is at the bottom.
Press SEL/AUTO to select the FACTORY2 menu.
Press the to select AUTO COLOR.
5
Press the to run AUTO COLOR. Wait until finished.
You will see the colors changing and then become stable when finished. About 10 seconds.
6
Press the and select COLOR UPDATE.
7
Press the to run COLOR UPDATE. It will finish quickly. < 1second.
8
Press MENU to exit the menu. Power off/on.
